We have a GVD Audio DP-406 6 CH power Mixer and cannot work the mikes property
2 Suggested Answers
technical114
  • 1851 Answers
SOURCE: how do we connect an m audio fast track pro to my
All you have to do is to connect with 2 cables your mixer's output to the two 1/4” TS plus in the front side of the Fast Track Pro and a usb cable from the rear panel of the Fast Track Pro to your pc's usb port. I suppose that you have installed the drivers for Fast Track Pro at your pc.
Anyway in case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Posted on Feb 25, 2010
Ch. 1 on Behringer pmp4000 not working
A short on the XLR input board, or possibly a short within the XLR connector itself.
Nov 14, 2017 | Behringer Europower PMP4000 Powered Mixer
Hi i need to connect a microphone to the mixer and output sound to a tv monitor to hear audio across a cctv camera. hope you can help. adrian
INPUTS:
Mic into CH 1
Camera audio output into CH 2
OUTPUTS:
Mains L/R>>>>>>>>>>>>>>DVR/Tape
Control Room>>>>>>>>>>>>audio monitors.
Sep 14, 2011 | Phonic AM220 2 MicLine 2 Stereo Input...
I have a condenser mic, and it needed phantom power to work, so I bought the Ultra Di-100, but I don't know how to make my mic work with it.
Sorry, but the DI-100 can OPERATE on phantom power, not supply it. If you have a mixer that has phantom power then you have no need for the DI box. DI boxes are to convert unbalanced signals to balanced to send via XLR or TRS cables.
If you don't have a mixer that has built in Phantom power or a source of Phantom power, then you need a mic preamp that can supply the phantom power.
Here is an example device, but DO shop[ around as you should find some even less expensive. Make sure they have phantom power.
http://www.amazon.com/M-Audio-Audio-Budget-Microphone-Preamp/dp/B000CZ0RZG
Dec 21, 2010 | Behringer Ultra Di-100 Active Direct Box...
Where or how to connect 4 ch nexxtech mixer to the amp
it it a dj setup or incar audio setup your running ?
Dec 20, 2009 | Audio Players & Recorders
Behringer pmh mixer manual. 20 channel 800watt powered mixer no speaker output. I need to test the power supply and the amp modual. Thanks
Are there lights or effects windows lit up? If so, the power supply is likely OK.
If neither speaker is working, that is bad however make sure all your trims and sliders are right to send audio through. Some have a standby switch.
This probably has an HCA2400 amp board in it and those can burn up for various reasons including loose speaker cables.
Nov 28, 2009 | Behringer POWERED MIXER, 20 CH, 400 WTS...
I need a service manual for a behringer pmh500 powered mixer
If LED's or other indicators are lighting, then the power supply is likely OK.
If nothing lights, then the supply has fried and LIKELY fried as a result of one of the power amps shorting.
Correct wiring for a ASTATIC TEARDROP MIKE to a RANGER RCI 2950DX
here is the info you asked for the following is the correct wiring.
Mic Wiring Info
Stock Mic Wiring
1. Ground Shield
2. Audio Yellow
3. Transmit Red
4. Receive Black
5. CH. Up White
6. CH. Down Blue
Turner 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Black
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Turner 6-Wire MIC. Wiring
1. Ground Shield & Red
2. Audio White
3. Transmit Blue
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 6-Wire MIC. Wiring
1. Ground Shield & Blue
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Mar 11, 2009 | Connex 3300 240-Channels Base CB Radio
Using the dp-01 as a interface mixer
If you're asking about being able to use the DP-01s knobs and sliders to control the virtual knobs and sliders on some PC recording software the answer would be 'no'.
But if you just want to use the DP-01 to act as a mixer for incoming signals (like microphones and or guitars or other instruments) the answer is 'kind of'. The DP-01 cannot act as a usb interface for your PC, but it can sit in front of a usb interface or sound card and act as a mixer of sorts to mix input from instruments through the monitor outs and then into your computers sound cards or usb interfaces audio-in jacks. You are however limited to two simultaneous inputs though as that is all the DP-01 can handle.
Cheers.
bd.
Oct 20, 2008 | Tascam DP01 All-In-One Recording Package...
282 people viewed this question
 Grubhead
Grubhead
