Question about Dynex 4-Port Ethernet Broadband Router (DX-E402)
No internet connection threw Dynex DX-E402
When I try to hook up the Dynex 4 port router, I have connectivity to Xbox and PS3 but not the computer. Tried to refresh IP, tried to enter 192.168.1.1 and get nothing. Called tech support, had me refresh, release, renew, default gateway was blank, so they said call microsoft. They wanted 80 dollars to help. Please help
  • 1 more comment
  • cheri_mcinty Nov 16, 2008
    the connection is wired. Using Windows XP.
    Followed steps, made sure Obtain IP automatically and DNS servers were both checked. Still no good. Checked ip address it was the 192.168.1.1, checked the light, all good. Right click on internet connection and it says connected. Open up internet explorer and says page not found, type in 192.168.1.1 into the address and nothing. Other systems hooked up through the router work. PS3 and Xbox both have internet connection, but not the computer.
    Computer is hooked up to connection 1 on the router.
    When i check the IP address under local area connection, the default gateway is blank. Should it be?
  • Jannette Amandy May 11, 2010
    How is your computer connected to the router? Wired or wireless? What is its Operating System?
    Scholar:
  • 132 Answers
  1. Go to Control Panel on your computer. Then Click on Network Connections. Look for Local Area connection. RIght click on it and click properties.
  2. Look for Internet protocol TCP/IP. Select it and click Properties. Make sure that Obtain IP address automatically and Obtain DNS servers automatically.
  3. Then, check the IP address of your computer by doing a right click on Local area connection again, but this time click on Status then click support. The IP address that your computer should have is in the range of 192.168.1.x
  4. You may also check if the Ethernet light on your router is on for your computer's connection.
Hope this helps!
Posted on Nov 16, 2008
After connecting my Dynex DX-E402 wifi router to my desktop computer and running the Quick Setup on the router website I still cannot connect to the internet nor will my Netflix-ready DVD player connect to...
Typically wireless routers have one port labeled WAN and four additional standard network ports. The WAN port should be connected to your broadband device, typically a cable modem or DSL modem. You can configure your router with a direct connection to any of the standard ports connected to your computer. Your router must be configured to DHCP automatically with its connection to the modem through the WAN port. So to repeat, outside world to MODEM, then WAN port on router, the wired or wireless connection to your computer.
Nov 03, 2017 | Dynex DX-E402 Router
How to connect a dynex (dx-e402)router to linksys (befsr41) router
Configure the dynex on another computer that is not connected to the linksys router.
Assuming that your linksys is currently setup as 192.168.1.1
Turn off DHCP on the dynex and setup the IP to 192.168.1.2 subnet mask 255.255.255.0 gateway 192.168.1.1
use a cross over cable and plug each ends to the LAN port on port routers.
you should now be able to ping 192.168.1.2 (dynex router) from your other computers on the linksys router network.
any computer that is connected to the dynex should be able to get a dhcp address from the linksys router.
Mar 01, 2011 | Dynex 4-Port Ethernet Broadband Router...
When i connect my modem directly to my computer i get internet access. when i connect to my dynex router, i get no access on my computer or xbox
You can go here and download the quick setup guide and manual for your router http://www.dynexproducts.com/products/computers/DX-E402.html which will walk you through the setup.
The most common reason it won't connect is that you must have the router's IP number (the one listed as default IP in the manual) set as the GATEWAY address on your computer network settings and your xbox settings, otherwise they can not talk to the router.
Feb 18, 2011 | Dynex DX-E402 Router
Cant hook this up, will this work two computers
You will need to use two standard ethernet cables. Each computer will connect to each of the LAN ports on the rear of the router. If you would like to connect the two computers to the internet, you will need to connect another ethernet cable, one end to your modem (assuming you already have one) and the other end to your router's WAN port. There are additional settings you need to configure on your router if your ISP requires a login.
Aug 01, 2010 | Dynex 4-Port Ethernet Broadband Router...
Will not give internet to my console but has worked before
you could try to run the quick the quick the quick setup again and it might work
Mar 29, 2009 | Dynex 4-Port Ethernet Broadband Router...
Cannot connect to internet using Dynex Wired Router
First, power down all equipment.
Second, plug in power to modem, let all the lights come on and boot up
Third, plug in the router power and let that boot up and the lights come on
Fourth, Plug in each pc to the ports labeled 1-4
The WAN port should be connected to the Modem also.
Mar 19, 2009 | Dynex 4-Port Ethernet Broadband Router...
Can  Dynex 4 Port Router DX-E402 be used to connect internet on a notebook without using cable to notebook?? i.e. Can it be used like a wireless g router??
Unfortunately, the DX-E402 is not a wireless router, so it can not transmit its signal without a physical cable connecting the router to your computer. If you want a wireless router that can also connect to your ISP, check out the Dynex Enhanced Wireless G Router:
http://www.dynexsupport.com/product/?pid=DX-WEGRTR
Nov 28, 2008 | Dynex 4-Port Ethernet Broadband Router...
Dynex 4 port ethernet router
When the TCP/IP is set to dynamic or "Obtain Automatically", the default gateway is supposed to blank. The default gateway address of your network is actually the router's IP address.
What is the IP address that you get when you performed step 3?
Nov 17, 2008 | Dynex 4-Port Ethernet Broadband Router...
No connection
Try resetting the router to factory , should have a button on the back to do this .
you will have to log back into it with the default factory password
see their site for more info.
Jan 26, 2008 | Dynex DX-E401 Router
Dynex 4-Port Ethernet Broadband Router (DX-E402) Logo
597 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
