Question about HP Office Equipment & Supplies
My HPOfficejet Pro L7680 All-in -One paper and printing mechanism is not aligning properly.
  • HP Master
  • 4,338 Answers
Read this document from HP about the Alignment problem:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01451117&cc=us&lc=en&dlc=en&product=2512009
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 15, 2008
Alignment failed when run
If Printer heads health condition is not good, alignment wont completes..
Four individual cartridges & Two print heads, each print head prints two colors.. Black& Yellow, Cyan & Magenta.. Verify which color is not printing properly(Color missing Or white bands)..
Perform 2 or 3 times print head cleaning through printer menu..Try for alignment.. If success end.. if no, replace the print head which is not printing properly.. Before replacing the printer head ensure that cartridge ink should be above 30%...
Oct 07, 2012 | HP Officejet Pro L7680 All-In-One Printer
Doc feeder is not working right. Paper jams. If you lift the lid up the document will pass through OK, just won't copy right.
This seems to be fault in the transport of the paper in the rollers. So if you have used any adhesive sticker printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction.
Oct 28, 2010 | HP Officejet Pro L7680 InkJet Printer
Alignment failure HP L7680
Check the quality of all your cartridges. Some printers are very fussy over alignment pages - if cyan is not coming through and is needed for example, the alignment will fail.
Feb 18, 2010 | HP Officejet Pro L7680 All-In-One Printer
My officejet pro l7680 is printing with words
if the ink level is more than half then try to clean the cartridges and the contacts on the printer with a lint free cloth and from printer options as well..
on printer..
press setup button > go to tools > try to clean cart / align the cart and then try to print..
if it doesnt help try with another set of cart.
Oct 29, 2009 | HP Officejet Pro L7680 All-In-One Printer
I had a paper jam , cleared paper, and still won't print.
check any alignment sensor. How aggressively did you clear the sheet of paper.
Jun 24, 2009 | HP Office Equipment & Supplies
HP all-in-one not printing cyan color
Place a soft clean tissue paper over the cartridge print head and leave for about eight minutes. You can secure it with the aid of a rubber band. It should be held firm ok. If the tissue paper is not dampened by ink then the cartridge would have gone bad or the ink dried. You also know that they have expiry date and could go bad while yet in the packaging b/c it has expired. Good luck
Jun 02, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Officejst Pro L7680 All in one
Printer gives repeated "clear paper jam" messages and even though there is no paper anywhere in the paper path it will not clear.
Oct 10, 2008 | HP Officejet Pro L7680 All-In-One Printer
88 people viewed this question
Ben Johnson
