Question about E-Machines M2000S 15.4" LCD Monitor
MONITOR On my monitor, the contrast box continues to automatically "pop up". I don't activate it with the monitor menu, it just automatically "pops up". Sometimes, I can get it to disappear and sometimes it just disappears on it own. HELP!!!!!
4 Suggested Answers
SOURCE: Monitor Screen Bright with horizontal white lines
I have an emachine 17" Flat Panel Monitor and I accidently touched the Standby Mode on my keyboard and now my menu won't work right. I can't adjust the color enough. If there is anything I can do to fix my problem it would be appreciated.
Posted on Dec 20, 2007
SOURCE: monitor menu
I have the same problem with the emachines E14Te monitor. I have emailed emachines support several times and no responce. Iave tried calling, and vet the computerized maze of press the number for X department. I have yet to talk to anyone in their support problem area.
Posted on Jun 14, 2008
  • 57 Answers
SOURCE: emachine T3504 monitor controls locked out
The problem is not one easy... The IC with controls system is down... sorry but u must go to an expert to fix the bug! Rate me if this help's you Thanks!
Posted on Sep 14, 2009
  • 30 Answers
SOURCE: Emachines contrast menu popping out
sounds like youve got a button that is sticking try to coax it out with your finger nail
Posted on Jun 24, 2011
0 characters
1 Points
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
Apr 17, 2016 | Princeton Digital VL173 Monitor
Contrest & brightness menu always pops up and
there is a problem in micro controller chip in the monitor replace that biggest chip in the monitor problem will be solved
Feb 28, 2010 | ViewSonic VP920b 19" LCD Monitor
Contrast window pops up and dims the screen.
You are not alone. I have a Viewsonic monitor that does exactly the same thing. Wasn't sure if it was the monitor or a "bug".
Dec 10, 2009 | ViewSonic VX910 19" LCD Monitor
HCL Monitor Screen Display Problem with Contrast menu showing up.
my hcl 17inches monitor is displaying contrast,brightness etc automatically
in the middle of the screen.even if i press the menu buttons it
disappears for a sec and comes again and again.what should i do to
solve this?
Sep 13, 2009 | Computer Monitors
My monitor pops up the contrast menu without doing anything.
Actually the button for setting the contrast is a bit loose thats why whenever their is a **** os little movement in the moniter opf ur PC then the contrast button get pressed automatically and the pop up comes up
Sep 07, 2009 | ViewSonic VA721 17" LCD Monitor
On start, monitor contrast option automatically gets activated
if nothing works and you cannot access your monitor settings via the menu button on the monitor then you have no way of correcting it. as far as i am aware the only thing you can change with the monitor from within your operating system are its resolution, refresh rate. so i think you need a knew monitor.
Apr 23, 2009 | IBM E54 15" CRT Monitor
Contrast pop up
Is the OSD button stuck on the front of the monitor? Can you control the OSD menu with software or firmware? It may be the button interface/hardware.
Jan 03, 2009 | Computer Monitors
Contrast problem
my monitor IBM e54 have a problem its like the right button from the monitor automatically activates. so everytime i work contrast box appears. how can i solve this problem?
Jan 25, 2008 | IBM E54 (Pearl, White) 15 in.CRT...
Dell Ultrasharp 21' monitor
I had the same issue. I pressed and hold the + button and the monitor did an auto adjust and the pop up stopped.
Aug 23, 2006 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Computer Monitors Logo
20 people viewed this question
Top E-Machines Computer Monitors Experts
buzz flewhart
buzz flewhart
Ricky Ostrom
Ricky Ostrom
Brian Sullivan
Brian Sullivan
Are you an E-Machines Computer Monitor Expert? Answer questions, earn points and help others
