Question about Onkyo TX-8511 Receiver
I have an Onkyo TX-8511 Receiver. The unit has power because the standby light is on, but nothing happens when I press the power button or try and turn it own with the remote.
  • 734 Answers
As follows to our chat session, please rank me for the solution..
Posted on Nov 16, 2008
  • santkarki200
    santkarki200 Dec 24, 2012
    Hey futureloginn, can you please help me with the solution
Onkyo tx-ds656 stand by power light comes on volume control knob rotates to max but display or unit wont start
Try factory reset: while holding the(CD) button on front panel,press (POWER) button.
After "Clear" is displayed the unit should be back to its factory default. :) If this dont work for you take the unit to be checked by service . :)
Jan 24, 2014 | Onkyo TX-DS656 Receiver
Is it odd that my TX-SR606 Onkyo Receiver wont go into stand-by? It turns off but the standby light never lights.
try reset. push and hold vcr1 and then press power button while unit is on this will reset back to factory default
Apr 24, 2010 | Onkyo TX-SR606 Receiver
I must have hit some buttons on the remote unintentionally - all of a sudden I lost the sound out of the left speakers on my Onkyo TX-8511
Reverse left and right speakers at back of unit
to verify if a speaker/wire problem. Also check
all functions for same problem!
Jan 30, 2010 | Onkyo TX-8511 Receiver
I have an Onkyo TX-8511 Receiver. The unit has power because the standby light is on, but nothing happens when I press the power button or try and turn it own with the remote. I have Onkyo HTS907 that...
You have two devices that won't power on. Doesn't that suggest a source power problem? Did they ever or never work where you are now or anywhere else? Or did you just come back from overseas and forget to set them up for U.S. power?
And you're not daisy-chaining the two units together, are you? That's a no-no. There's a wattage limit to what can be connected to the convenience outlets. Power amps are not usually supported.
Try isolating the two units and shoot each bug separately. Plug them in somewhere else. Disconnect speakers and try again.
C'mon back with the results.
May 08, 2009 | Audio Players & Recorders
I have an Onko TX 8511. It will not Power On
as follows to our chat session, please rank me for the solution.
Nov 15, 2008 | Onkyo TX-8511 Receiver
Onkyo tx-vs515pro won't turn on
doubt that reset will fix your problem---but here it is if you want to try:
hold down the cd button and press the power button [at the same time]
test will [should] appear on screen for about 5 seconds--you need to unplug the set during this 5 second period. this resets the cpu chip.
hope it helps solve your problem.
barnesmar
Nov 10, 2008 | Onkyo HTR500 Receiver
Power up problem
try powering the unit right down by disconnecting from the mains supply. fire up after 5 mins and see what happens. There is a separate transfomer for the standby supply(small red light) An internal fuse may have failed or the thermal fuse inside the transformer. If fuses blow as sson as you fire up = output transistors hay be short circuit.
Dec 07, 2007 | Onkyo TX-8511 Receiver
Will not turn on...
try unplugging overnite
Nov 20, 2007 | Onkyo DTR7 Receiver
Onkyo TX-8511 Receiver Logo
477 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
