Question about Panasonic KX-T7730 Corded Phone
No dial tone for panasonic kx-t7730
Hi
no dial tone when i pick up the handset.
when i push speaker phone, the intercom button is lit and still no dial tone.
please advise.
  • Anonymous Nov 19, 2008
    set tone mode
  • Carl Navarro
    Carl Navarro May 11, 2010
    A Panasonic analog phone requires 4 wires to work. The voice pair is on the RED/GREEN and the data pair is on the BLACK/YELLOW. Guess which pair you don't have? Take a single line non Pana phone and plug it into the same jack. When it works, your Pana phone should work. Look for a broken wire somewhere, but first go back to the phone system cabinet and test your Pana phone.
5 Suggested Answers
cnavarro
  • 2460 Answers
SOURCE: change the ring tone of Panasonic KX-T7730
I think it can be done. Just exchange the phone for a 7633 and change out the TA for a TDA-50.
Piece of cake.
Carl
Posted on Aug 25, 2008
cnavarro
  • 2460 Answers
SOURCE: Panasonic KX-T7730 Speed Dials - Please Help!
So I guess that means you're not programming SYSTEM speed dial numbers. Those are programmed from the system manager or operator's station. Personal speed dials are 1-0 and are programmed per set.
Carl
Posted on Sep 03, 2009
cnavarro
  • 2460 Answers
SOURCE: I NEED TO STORE NUMBER ON MY PANASONIC KX T7730
The mechanics of storing a speed dial number on Panasonic phones is the same, even if the phone can be connected to one of 18 different model Key Service Units. It involves pressing PROGRAM a button, an access code, the number, and STORE. In the U.S. our access code to get an outside line is "9". You may be using something different, like '0'.
The differences are if you can dial "9" on the intercom and get a dial tone, which collumn of buttons you press, and/or whether you want this to be PERSONAL numbers or SYSTEM numbers.
In a TA-824, lines are accessed high to low. If you have 2 lines on a basic system and dial "9" to get an outside line, you will land on line 3 if you have not told the system that line 3 is disabled (system program 400). So, the fast answer is press PROGRAM, a button on the right side, dial 9+your desired number and STORE. If it's a left side button, dial 29 instead of 9.
System speed dials requrie access to system program 001.
If this does not work on your system, please comment back with your actual system model number.
Carl
Posted on Nov 09, 2009
  • 569 Answers
SOURCE: how to program handset to the base? Panasinic KX-T7730
I have uploaded the user manual for you.
Go here and download. This manual covers the 7730.
http://www.easy-share.com/1909338845/Panasonic KXT7700-User-Guide.pdf
Posted on Feb 19, 2010
SOURCE: Own model KX-TG6031CM. Handset display is lit up
need access code to retrieve messages for kx-tg6031cm panasonic phone
Posted on Feb 20, 2010
When my MIC/HFAI button is lit (green) - I can hear people that intercom to me - but they cannot hear me unless I pick up the handset. How do I fix this?
Turn up the volume on your speaker phone. You also have to push a button to turn your intercom speaker on.
This prevents somebody from listening in on your office conversations without your knowledge. Consult your phone manual.
Mar 03, 2015 | Lands Phones
Our KX-T7735 phone system is not working, yet our phone service is live. Is there a code we need to unlock?
Have you tried pushing to CO button and then dialing out?? Otherwise unplug the phone from the wall and power, pull batteries and wait half hour and reconnect.
Nov 13, 2013 | Panasonic KX-T7735 Corded Phone
ON PHONE KX-T7420 NEED TO CHANGE HANDSET RINGTONE . WE HAVE FOUR IN ONE OFFICE AND ALL SAQME RINGTONE.
The phone has 8 ring tones. From the idle phone, press PROGRAM and dial 99. Press the intercom or a CO line button TWICE and dial 2-8 on the keypad (1 is already default). When you're satisfied with the tone, press STORE. You have to do this for each line and the intercom you want to change and you need to do this at each phone. Pick up the handset and drop it back down to exit programming.
Carl
Aug 11, 2011 | Panasonic KX-T7420 Corded Phone
How do I use the intercom function on a KX-T7731 phone??
Panasonic analog phones plug into analog KSU's and have extension numbers beginning with 101. In additon, you can dial 0 to reach the phone programmed as Operator, and it's usually extension 101.
With the intercom dial tone (press INTERCOM or pick up the handset or press SP PHONE) you can start dialing codes defined in your number plan. You can also program left side buttons to monitor are directly select other extensions or dial codes to page all idle speakers in a 77xx phone.
Note this is specific to TA series systems, but the operation is similar in all Panasonic models.
Carl
Apr 19, 2011 | Panasonic KX-T7731 Corded Phone
How do i use the intercom on this phone? My boss is wanting to use them but we don't have the manual and can't figure it out
Wow. The Partner 18D phone has two buttons on the lower left of the faceplate in the middle of the phone that are seperate from the 5 rows of 4 buttons. Those are your 2 intercom buttons. If you press one of those and pick up the handset, you'll get intercom dial tone. Your extensions are numbered 10 to whatever. By default, dialing zero will ring extension 10 and you can see what extension called in the display.
Carl
Oct 21, 2010 | Avaya 700340193 Corded Phone
If you want to "make an announcement" using speaker phone using intercom, how do you do it
When you intercom the extension, insert a STAR ("*") before the extension number.
EX:
Dial intercom 12, will ring 12.
Dial intercom*12, will page the phone and go straight to speakerphone.
IF the far end user has their "MIC/HFAI" button lit, they will need to do nothing, they can just talk.
IF not, they will need to lift the handset, OR, press the "MIC/HFAI" button, to be head.
Oct 05, 2010 | Lucent PARTNER18 Corded Phone
HOW DO I GET THE INTERCOM TO HAVE A TONE ALERT
It's done in programming so the AUTO ANSWER button can control it. It needs to be dark and you need to tell the phone it's a TONE CALL. In a TA series that's done via (without picking up the handset) press PROGRAM 41 STORE. (42 is VOICE CALL and the button becomes the MUTE key).
Now, the AUTO ANS button toggles between ringing on the intercom and Voice Announce with Handsfree Answerback when lit.
Carl
Sep 28, 2010 | Panasonic KX-T7730 Corded Phone
Intercom use
We have the 25414RE, so I can tell you how ours works and hope it helps solve your problem...
You first have to assign each phone a "number". Push the menu button, and go to phone options (you scroll by pushing the review button to the left or right), choose set phone id (once you are on that option push the select/save button just above the review button) - I started with the first phone I plugged in and made it number one, and so on (we have a total of 5). Once the phone ids are established, simply push the intercom button and the corresponding number on the right speed dial/intercom numbers - it should dial the phone you want. It also has an option (again we have the 25414RE) to have the phone auto answer the intercom - so if you are paging someone in a room that isn't near the phone, or the phone is shared by several users, it picks up without anyone having to push anything. Otherwise, the phone that you are calling has to either have the handset picked up or the speaker button pushed. Hope that helps you!!
Mar 10, 2009 | RCA 25404RE3 Corded Phone
Instruction manual for older style corded GE speaker phone
Here are the quick instructions on how to program the phone numbers.
You can also download a copy of the User's Guide from: http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=c96e9c823d0df43989039e5385bef04a&q=GE+29322GE1
Just enter the 4 digit captcha code and you will be able to download the User's Guide.
Please let me know if yo have any questions.
Good Luck!
STORING A NUMBER IN MEMORY
To program priority keys:
1. Make sure the telephone is properly installed. Pick up the
handset and listen for the dial tone. If you don’t hear the
dial tone, recheck or repeat the installation steps.
2. Press the SPEAKER button or pick up the handset.
3. Press the store button.
4. Dial the number to be stored.
5. Press the store button again.
6. Press the A, B or C button.
7. Press the SPEAKER button or hang up the handset.
To program frequently called numbers:
1. Press the SPEAKER button or pick up the handset.
2. Press the store button.
3. Dial the number to be stored.
4. Press the store button again.
5. Press one of the 10 memory location buttons 0-9.
6. Press the SPEAKER button or hang up the handset.
Aug 11, 2008 | GE 29322GE1 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
1,660 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
