I have a rainbow effect on my television screen.
The top of the screen is blue at the top, green in the middle and red at the bottom. This affect appears when it is on a channel without a picture. When it is on a channel with a picture the picture is good at the top, purplish in the middle, and yellowish at the bottom. Is it worth it to get this fixed?
    Champion:
  • 252 Answers
The deguesing is not working of your tv.or maybe you have a load speaker near the tv. take it away near the tv it damage the color of your tv set.
Posted on Nov 16, 2008
Rainbow colors from bottom of screen to top corners
Check its degaussin posistor. Replace it. This component can be located at the main power regulator section.
Picture of the suspected component attached.
May 23, 2012 | RCA TruFlat 27F520T 27" TV
The picture is showing multiple images with red, green and blue rainbow effect. The picture is also bowed on the top and bottom
This is whats called a convergence failure. You will need to call in a repair shop or goto sites like www.TvRepairKits.com hthat ave the parts to fix this yourself. Its a common failure on projection TV sets.
Aug 07, 2011 | JVC AV-56WP74 56" Rear Projection...
I have a red rainbow affect on my screen/seems like a bulb?
You have lost your convergence. Red,Blue and Green not aligned. Too complicated repair for non-electrician.
Oct 24, 2009 | Philips Televison & Video
The screen has a rainbow of red blue and green on bottom
The specs say this is a CRT type projection system, so it could be related to the display or to the TV. Since this has an SD card, it might be good to plug in the memory card with some pictures on it, and see if the problem persists with a source other than the tuner. That might at least narrow down whether you have a display failure/adjustment issue or something else.
Jul 04, 2009 | Panasonic PT-56TWD63 56 in. Rear...
Video distortion
You need to take your tv in and have the picture deflector re-aligned.  This doesn't cost much, My dad had to do that to his a few months ago and it cost 30 bucks.
Mar 21, 2009 | Mitsubishi VS-60705 60" Rear Projection...
RCA Projection TV Model #p46921, Has bowing effect of pictures
Go to Menu then setup look for convergence if you do not see convergence on menu then you have a open FUSE FL231 it is on right side of FBT flyback transfomer there is 3 of them small brown rectrangler looking caps it will be the one in the Middle.
Jan 31, 2009 | RCA R52WH73 Projection Television
Tv screen is squeezed only straightens out if i bump the top of tv
This is likely your convergence IC solder connections. Does it look bowed and rainbow colored? The red, green, and blue will be mis-aligned causing a shadow effect. If you can bump it then the ICs (chips) are still ok, it just needs resoldering.
Dec 06, 2008 | Mitsubishi WS-65809 65" Rear Projection...
No picture, just red-blue-green lines through the middle of the screen very faint.
The PT-53WX54 is a standard projection set and does not have a bulb. It has 3 separate picture tubes. If you have lost the picture completely, not even on-screen menu, then something has stopped working in your set. It could be a video processor, vertical deflection or possibly a convergence problem. The set should be serviced by a qualified tech familiar with the Panasonic projection sets.
Aug 22, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
Convergence bad,rainbow affect,deleted from menu not listed in menu after circut breaker fuse blew.
I dont understand the question. Please ask in plain english whats not working and why its not or how it started not to work please!! Whats deleted from the menu and not there??explain rainbow effect as does it move up and down the screen or side by side or sits there and looks like red green and blue lines??
Apr 07, 2006 | RCA P56950 56" Rear Projection Television
Televison & Video Logo
188 people viewed this question
Top Televison & Video Experts
