Black ink cartridge reported to be empty when newly replaced
Scanner cover reported to be open when closed
  • 1,326 Answers
It depends on what kind of copier it is? Is it a Canon desk top copier? Need some more info. on make and model
Posted on Nov 16, 2008
How to change ink cartridges on an Epson CX 3800
Be sure you have a new ink cartridge before you begin. Once you start replacing a cartridge you must complete all steps in one session.
1. Make sure the Epson CX printer is on.
2 Make sure the document cover is closed, then open the scanner
Caution: Do Not open the scanner when the document cover cover is open.
3. Press and release the " ink " button. The ink cartridge moves to the check position and the
" On " and " ink " lights flash. If one of the cartridges is low or empty, the printer moves the
cartridge to the _ink out mark.
Note: Don't hold down the " ink " button for 3 or more seconds or the printer starts cleaning the print head.
Caution: Do Not move the print head by hand; this may damage the printer, always press the ink
button to move it.
4. Press the " ink " button again
a. If more than one cartridge is low or empty, the next cartridge moves to the_ink out position.
b. If all of the empty or low cartridges have been identified, the print head moves to the ink
cartridge replacement position.
5. Open the cartridge cover.
6. Squeeze the tab at the back of the empty/low cartridge and lift it straight out.
7. Before you open the new ink cartridge package shake it four or five times, then remove it
from the package.
Caution: Do Not remove or tear the label on the cartridge; otherwise ink will leak.
Do Not touch the green chip on the front of the cartridge, this can damage the
ink cartridge.
8. Place the new ink cartridge into the cartridge holder and push it down until it snaps into
place.
a. Replace any other cartridges that need to be replaced.
9. Close the ink cartridge cover and press it until it clicks into place.
10.Close the scanner.
11. Press the " ink " button The print starts charging ink and the " On " light starts flashing. This
takes about one minute. When it's finished the " On " light stops flashing and remains on.
and the " ink " light goes out.
Caution: Never turn off the printer while the " On " light is flashing or you'll waste ink.
Note: If the " ink " light stays on ( not flashing ), the ink cartridge may not be installed correctly.
Press the " ink " button again and reinstall the ink cartridge until it clicks into place.
Feb 09, 2011 | Epson Office Equipment & Supplies
Replaced ink cartridge still shows ink low needs to be replaced but is printing? Can it be reset?
  1. Remove your current empty cartridge from your Dell printer. Turn on your printer and lift the cover and top half of the unit. You can suspend it in place by lifting the blue plastic lever and securing it to hold up the top of the printer. At this point the ink cartridges should move to the center of the printer and be easy to access. Follow the instructions locate on your printer to remove the cartridges. You can do this by pressing on the blue tab to remove the colored cartridge or the black tab to remove the black cartridge. Once you press the tab, the cartridge cover will pop open. Carefully pull out the exposed cartridge from it’s setting. Save the empty cartridge so it can be refilled.
    Remove the sticker from the newly refilled Dell ink cartridge. Follow the directions on the opened printer to insert the cartridge. Hold the cartridge so the writing is on the top and the ink spot is on the bottom. Gently push it into the opened setting until it is securely in place. Close the cover of the cartridge holder by pressing down on it gently until it clicks into place. Remember that the black cartridge goes into the black setting and the color cartridge goes into the blue setting. Close the top of the printer. You will hear the ink cartridges move back into place.
  2. Test your newly refilled Dell ink cartridge and load your printer with paper.Print a document so either in color or black and white (depending on the type of cartridge you had refilled). Review your printed document to make sure the color is consistent and you are pleased with the outcome.
    Repeat whenever you run out of ink.
Apr 30, 2010 | Dell V305w All-In-One R840635AU InkJet...
I have replaced all the ink cartridges and my printer says "no cartridge, open scanner cover"
It is probably best to replace cartridges individually as necessary. Let me explain. The printer display will tell you when a cartridge is "xx near empty" and when "xx empty" (where xx is the cartridge color).
1) Near Empty - you can continue to print. This message is to remind you to get a new "xx" cartridge and have it on hand.
Replacing the cartridge when "Near empty" will cause the machine to report "xx Empty" when it is not. It will not register that you have replaced it at "Near empty." Wait to replace the cartridge when you get the "xx empty" message.
2) XX Empty - you may not be able to continue printing. Replace cartridge "xx" now per your manual.
If you have replaced or reseated more than one cartridge, and you get the "no cartridge" error, you need to find out which one the machine "thinks" is problematic:
1) With the scanner cover open and locked in the "Up" position, the message may change to "Change cartridge, install xx" (xx refers to the color )
2) After changing the suspected cartridge and closing the scanner cover, be sure to notice the display. It will say, "Changed XX? 1. Yes 2. No" Press 1.
If all this explanation does not work, keep it in mind for next time. Brother says to unplug the machine for at least 10 seconds, then plug it in again. If the display shows the date and time, problem solved. If not, you may need to contact brother support.
Jan 22, 2010 | Brother MFC 420CN All-In-One InkJet...
How do u change the ink in the epson 6000?
Things You'll Need:
  • Replacement cartridge (black, cyan, magenta, or yellow)
  1. Step 1 Turn on the printer and press the Color button.
  2. Step 2 Lift up the scanner and wait for the ink cartridge holder to move into position. Remove the ink cartridge holder's cover.
  3. Step 3 Push the tab at the back of the empty ink cartridge to free it from the cartridge holder. Lift the empty cartridge out and dispose of it.
  4. Step 4 Prepare the replacement cartridge by shaking it gently while still in its packaging. Remove the cartridge from its wrapper, taking care to hold it by the sides.
  5. Step 5 Insert the replacement cartridge into the appropriate slot of the ink cartridge holder. Push down on the replacement cartridge until it clicks into place.
  6. Step 6 Close the cartridge cover and lower the scanner until it clicks into place. The printer is now ready for operation
Nov 15, 2009 | Epson Stylus CX6600 All-In-One InkJet...
I don't know how to change the ink bought this printer from a guy at work no manual
Lift the scanner cover from the right-hand side of the MFC until
it locks securely into the open position.
If one or more ink cartridges are empty, for example Black, the
LCD shows Ink Empty Black and Cover is Open.
Pull the ink cartridge hook toward you and remove the ink
cartridge for the color shown on the LCD.
Open the new ink cartridge bag for the color shown on the LCD,
and then take out the ink cartridge.
Remove the cartridge covers.
Each color has its own correct position. Keep the ink cartridge
in an upright position when you insert it into slot. Press down on
the ink cartridge until the hook snaps over it.
Lift the scanner cover to release the lock. Gently push the
scanner cover support down and close the scanner cover.
If you replaced an ink cartridge while Near Empty was
displayed on the LCD, the LCD may ask you to verify that it was
a brand new one. Example: Did You Change Blck? 1.Yes
2.No. For each new cartridge you installed, press 1 on the dial
pad to automatically reset the ink dot counter for that color. If the
ink cartridge you installed is not a brand new one, please be
sure to select 2.
If you wait until Ink Empty message is displayed on the LCD,
the MFC will automatically reset the ink dot counter.
If the Install message is on the display after you have
installed ink cartridges, check that the ink cartridges are
installed properly.
Hope that helps you!
Aug 12, 2009 | Brother MFC 420CN All-In-One InkJet...
Epson CX7450 Black Ink Won't Work...
I was having the same problem. This fixed it:
Lift up the scanner bed (top part) of the printer to expose the cartridges.
Push the red triangle button once. Wait for the cartridge carrier to move to the middle. On the housing of the printer (the non-moving part), there is an arrow that will point to the empty cartridge.
Push the red triangle button again to see if the next cartridge is empty. Repeat this step, noting which cartridges are empty, until the cartridge carrier moves to the right. Now you can replace each cartridge that is empty.
After replacing the empty cartridges, push the red triangle button again, and the carrier will begin moving back and forth (cleaning itself). Once it stops, it should be positioned on the far right side.
Lower the scanner bed to "close" the printer. The ink light should go off and you should be able to print.
Feb 17, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Black ink cartridge doesn't work.
Have you tried
  1. Taking out all the cartridges
  2. Power down the power
  3. Power up the printer
  4. Open the scanner Cover
  5. Close the scanner cover
  6. Message will ask you to put the ink.
  7. Put in Black
  8. Close scanner cover
  9. It may ask you whether the Black is being changed.
  10. Open the cover.
  11. Install Cyan.
  12. Repeat step 8-10 for the rest of the 2 colours.
  13. It should resolve the Black ink empty message.
Let us know if this works.
Thank you.
Dec 11, 2008 | Brother DCP-110C All-In-One InkJet Printer
Reinstalling ink
I put a new magenta cartridge in the printer. It says to open the scanner cover, then reinstall ink cartridge. when i open the scanner cover nothing happens and i dont know how to install the ink.
Oct 03, 2008 | Brother DCP 115C All-In-One InkJet Printer
Epson stylus cx4200 all-in-one?
1. Make sure the printer is turned on.
2. Make sure the document cover is closed, then closed, then open the scanner.
(Do not open the scanner when the document cover is open).
3. Press and release the ink button. The 'On' and 'Ink' lights flash.
If one of the cartridges is low or empty the printer moves that cartridge to the 'ink out' mark. Go to step 4.
If no cartridges are low or empty the ink cartridge holder moves to the ink replacement position. Go to step 5.
4. Pree the 'ink' button again.
If more than one cartridge is empty or low the next cartridge moves to the 'ink out' mark.
Once the printer identifies all the empty or low ink cartridges the print head moves to the ink cartridge replacement position.
5. Open the cartridge cover, squeeze the tab at the back of the empty cartridge and lift it out.
6. Before you open the new cartridge package shake it four or five times and remove it from the package .
(Don't remove or tear the label on the cartridge otherwise ink will leak out) .
(Don't touch the green chip on the front of the ink cartridge - you could damage the cartridge).
7. Place the new ink cartridge into the cartridge holder and push it down till it clicks into place.
8. Replace any other cartridges that need replacing.
10. Close the scanner.
11. Press the 'ink' button. The printer starts charging ink and the 'on' light starts flashing . This takes about a minute . When it's finished the 'on' light stops flashing and remains on and the 'ink' light goes out.
You'll see all the above, with helpful pictures, at
this Epson support page
Mar 19, 2008 | Epson Stylus CX4200 All-In-One InkJet...
18 people viewed this question
jasbo
jasbo
