Question about Pioneer VSX-818V-K Receiver
Connecting media center to receiver
I'm connecting my media center to this receiver with a optical digital audio cable, but I'm only getting sound out of 2 speakers. I ran the MACC surround setup and the speakers are all connected correctly.
  • Hanick Jan 05, 2009
    I have the audio cables from the cable box going to an auxiliary input and the video going to the tv. You could use DVD or CD or any of the inputs. I have a DVD player in my media center, so I use the DVD inputs, and turn that on for cable audio.
  • cindy_spitle May 11, 2010
    Would you mind sharing w/ me how you hooked up your cable box and tv to your pioneer receiver? Bought my husband this receiver for Christmas and we cannot get the speakers to work. The MACC gives an error message and there is no indication that the receiver is getting any signals.
  • 3 Answers
Hey there,
Okay let me start with your pc setup. What type of sound card are you using? Are you using onboard? You have to check and see if the sound card or device you are using supports SPDIF passthrough. Basically this does just what it says...passes the surround sound signal through your hardware with no onboard decoding and uses the decoder found on your stereo. I use a soundblaster Audigy and i had to enable passthrough in the audio console. I also had to enable spdif as my default audio playback device. This is in Windows Vista. You also need to go into properties and set the formats your receiver supports. Once that is complete you need to adjust the audio settings in media center and select toslink as your audio output and select 5.1 audio.
Things should work now...BUT...you will only get surround sound audio when watching a source that has dolby 5.1 or DTS. You will not get surround sound in games =( When i watch ota hd shows that have dolby audio, the blue light kicks on in my receiver and i get 5.1 audio. Same goes for watching DVD's. I hope this helps you out
Posted on Mar 01, 2009
  • aaron jones Mar 01, 2009
    Hey there,
    Okay let me start with your pc setup. What type of sound card are you using? Are you using onboard? You have to check and see if the sound card or device you are using supports SPDIF passthrough. Basically this does just what it says...passes the surround sound signal through your hardware with no onboard decoding and uses the decoder found on your stereo. I use a soundblaster Audigy and i had to enable passthrough in the audio console. I also had to enable spdif as my default audio playback device. This is in Windows Vista. You also need to go into properties and set the formats your receiver supports. Once that is complete you need to adjust the audio settings in media center.
How to correctly set up a media center computer. I have set scene 1 there is a digital line from computer to receiver I get sound from Win media center when playing music and analogue television but...
At the rear of the Yamaha, on the left side, you will see 3 connectors for Digital input - the 2 one is specifically set for an HD tv / DTV. Buy a optical cable like
http://www.amazon.com/AmazonBasics-Toslink-Digital-Optical-Meters/dp/B001TH7GSW/ref=sr_1_2?s=electronics&ie=UTF8&qid=1297066417&sr=1-2
and connect it between the tv output and the receiver then select it as a source from the menu . Now you will have sound.
Feb 07, 2011 | Yamaha RX-V363 Receiver
I am using a JVC RX6000 video audio receiver, and i hooked 5.1 BMB brand home surround speakers to it, and connected my ASUS media player that has optical output and used optical cable to connect to the...
This is a common problem. Each input will default to analog. Even though you have plugged an optical cable into the inputs of the Receiver, you have to change that input to digital.
For example, if you connect a CD player RCA cables to the Receiver. The receiver will recognize the Analog signal at the CD input. If you unplug the Analog RCA Cables and plug in the Digital optical, the receiver will still be at it's normal default input for the CD player which is Analog. You then have to switch the input, using either the remote or it may be able to be done with the buttons on the front.
As soon as it is changed to Digital, you will get nice sound.
Hope this helps,
Happy New Year,
Mark
Dec 31, 2010 | JVC RX-7000V Receiver
Connecting cable to receiver
Do you mean 5 RCA audio outputs marked as FrontLeft, FrontRight, RearLeft, RearRight, Center? Unfortunately this receiver doesn't have discrete 5ch inputs (as yamaha calls it on its webpage).
But the cable box should have also digital audio SPDIF output - that is either optical (square connector) or coax (RCA usually orange). You can use this for connecting to receiver.
Mar 07, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Got a Kenwood vr405 surround receiver, a Sanyo plasma TV, hd cable box and an insignia blu ray player. Both the cable box and the blu ray player are connected via hdmi to the TV and the TV is connected to...
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
Jan 14, 2010 | Kenwood VR-405 Receiver
Digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Sep 16, 2009 | Technics SA-DX930 Receiver
Optical audio from cable box to receiver
Do you mean the optical digital audio output from the cable box? This is so you can listen to Digital sound from cable tv broadcast, First go to the cable box remote control, select setup or menu to find audio, then select audio output, check digital audio, not mts or stereo, this should enable to optical output instead of the typical 2 channel red and white left and right RCA analog audio outputs, sometimes different cable boxes vary, but most require you to enable the optical output via the method listed above.
Jan 28, 2009 | Yamaha HTR-6140 Receiver
Cant get the wiring figured out.........
TV is HD correct? Use the Y/CB/CR from the Sat to the TV. Use the Digital optical cable for sound from the sat to the receiver. Use the s-video from the dvd player to the tv and the l/r to the receiver for sound. I would suggest upgrading to another set of Y/CB/CR cables to connect your dvd to the TV and benefit from better picture. Also, buy another optical cable for dvd sound (so you can enjoy surround sound). Your receiver has two optical inputs so youre covered there.
Sep 03, 2008 | Kenwood VR-407 Receiver
Sony STR-DA5000ES 7.1 Receiver
its for digital decoding of the sound source. You need to connect a digital cable (ie optical) from the DVD player to the optical input in the receiver. The receiver should then decode the source into multichannel components ie 5 channels for example
Jul 23, 2008 | Sony STR-DA5000ES Receiver
Pioneer VSX-818V-K Receiver Logo
178 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Dennis McCollum
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
