Question about Oreck XL Professional Air Purifier
Red light keeps blinking
On my tower, the red light keeps blinking. How can I reset it? I took the tower to the Oreck store and they did not know how to reset it. They put a brand new collector cell init and it still did not stop blinking. Can someone please tell me how to reset it? Thank you!
I take mine apart when red light comes on and the filters and inside good. It goes off when the unit is screwed back in and turned back on
Posted on Jan 06, 2009
Blinking 'Check Collector Cell' light
which model XL series do you have? There is obviously something shorted or arcing on the plates of the cell. look at the plates and see if they are laying flat and the wires are all still attached across the front of the cell. A loose, sagging, broken or bad contact on the end plates will cause the bad cell lights. clean off the area where the cell makes contact inside the unit. The metal strips that run across the ends of the cell make contact with the plates inside the cell and get their power from them, dirty contacts in any part of these contacts will cause the problem. Even a bad contact from the end cap to the plates inside the cell will cause this. Try wiggling the cell around, kind of push on it on edge to get the plates to shift slightly and clean the points where the plates touch the outer strips on the sides. Check for arcing with the lights turned off,
Oct 20, 2014 | Oreck XL Professional Air Purifier
Red light reset
you mus read your owner manual for reset the light. Normally you must disconnect the power cord from outlet, by 45 seconds, and connect again. or download the i.manual from www.manualslib.com
God bless you
Oct 08, 2013 | Oreck XL Professional Air Purifier
Reset oreck XML professional
The reset button is power button,look at what it says under cell check button, hold(symbol) button t reset.
Jan 27, 2013 | Oreck XL® Air Purifier
The red CHECK COLLECTOR CELL wont shut off?
hi well is the check collector cell wont go off thats telling u the cell is dirty or check the wires ... if all wires are good then deppending on what modle you have reset the unit only on air professional push and hold air revitalizer button down untill check cell light blinks if tha dosnt work it may need service or repair if so call us at 562 924 5200 oreck of cerritos
Mar 24, 2011 | Oreck Air Purifiers
How do i stop the red lite for the collector cell to stop blinking ?
By changing the Collector Cell. The flashing light is an indication that it needs cleaning.
Here is a link to model you listed above. It has all the information you need, on how to clean the Collector Cell. You can download and print it for future reference.
http://www.oreck.com/PUG/3323-8889-Rev-K-AIR8.pdf
Hope this helps you solve the problem.
Mar 21, 2011 | Oreck XL Professional Air Purifier
The red light will not go off after I have cleaned the unit.
Hold the button down for several seconds, it will start blinking, then it will go off. I had this problem too. Hope I helped you.
Dec 09, 2010 | Oreck XL Professional Air Purifier
Red Light
slow blinking light means the unit is in DRY MODE.. flast blinking light means some sort of arcing or bad power supply..
if in dry mode let the unit run for an hour and it will stop blinking ..
Jun 28, 2009 | Oreck XL Professional Air Purifier
Oreck XL air purifier (Tower Model)
Is this purifier wet at all, or been in any heavy areas of moisture. This purifier is very undependable with moisture. It may just have to dry out. Let me know if this solves your problem or we can explore further options.
Please keep me updated, thanks
Apr 13, 2008 | Oreck XL Professional Air Purifier
Collector cell light always comes on
We purchased one of these in April 2009. Same issue appeared with us. Cleaned the cell and the "clean collector cell" still stayed illuminated. Checked the manual and the trouble shooting section stated to hold down the "air revitalizer button" till the "clean collector cell" light blinks three times. After this operation the light went out and all was fine!!!! Hopes this clears your issue!
Feb 02, 2008 | Oreck XL® Air Purifier
Red light when swith on power button ?
cell is dirty, or you have a broken wire in the cell.
Dec 22, 2007 | Oreck XL® Air Purifier
Oreck XL Professional Air Purifier Logo
3,634 people viewed this question
Top Oreck Air Purifiers Experts
brian kossman
Level 1 Expert
Are you an Oreck Air Purifier Expert? Answer questions, earn points and help others
