Question about Akai LCT3201AD 32 in. LCD Television
Akai LT3201AD where is the on button? Remote control only?
Has "stand by" on side and that is it. Volume, Channel, but no on/off
Stand by is the ON/OFF switch.
Posted on Nov 26, 2008
How to change kickstand spring
this depends on design of side stand - usually the easiest way is to remove the side stand pivot bolt remove side stand from channel., attach spring to both ends. pull side stand into pivot hole and reinstall bolt. there is less tension and easier to install if you orient side stand in retracted position..
Jan 08, 2015 | Motorcycles
I have a Peavey 8600D can I safely run 1 main
When you unload one amplifier you stand the chance of killing the amp's output transistor. If you must use only one speaker, you have to bridge the amps.
Feb 09, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
I bought a XENYX 1832FX and only one channel is working on the main volume.. The led's on left side don't light up.. I have tested leads,speakers,and amp with an old mixer and they all seem to work fine...
There's a button named "Stand By" this is probably the cause of your mixer issue, just take the button cover up and insert the spray cleaner pipe inside and give it 2 or 3 shots, then push it in-n-out several times and re-check the mixer outputs, let me know a bit more to improve help.
Oct 17, 2013 | Music
How do i get it off stand by timer?
Your tv has a power issue,to check it, do a self-diagnostics. Press Display,Channel,5,press the - on the volume,then power.This should tell you what has failed. ....hope this helps...
Mar 06, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How do I tune TV channels on my Sharp CX48G4 TV without a remote control? There is no tuning / settings panel on the TV itself which is very strange.
press the preset button on the front panel once then (TV should be on) the on the screen there should be words the likes of (Auto VHF 1 60.00mhz) now the Auto stands for auto tuning VHF stands for its frequency where its going to search the 1 stands for the channel where its going to start with 60.00mghz stands for the lowest signal to which its going to start now that you have understood all that just press the volume up button then it will automaticly locate all your working channels leave till it stops for when does it will start from channel 1 to which I believe that you be able to see the channel working so press the up button on the channel button to check the rest of your channels hope this will solve your problem!
Jun 01, 2009 | Televison & Video
People cannot hear my voice very well (volume is too low) when I am speaking.
On the side of the phone there are two arrows, one stands for plus volume, the other stands for Minus volume... Try It!!!
May 21, 2009 | LG Vu CU920 Cellular Phone
TV is not working
If it's 3 weeks old bring it back if you can. There should be at least a 30 day warranty. When the channel and volume buttons on the TV don't work it sounds like something failed.
Oct 19, 2008 | Televison & Video
Samson G-track
It's supposed to only record on the left side. When it's in "INST/MIC" mode the left channel has your mic on it and the right channel has your instrument, so you can mix them separately. Just configure your recording software to put the left channel on one track and the right channel on another track.
Jan 10, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
My Onkyo 7.1-Channel Receiver
Take out all the cables unplug from mains for an hour ,plug it back in with no cables connected ,turn volume to full if it turns off its faulty ,if it stays on turn volume to minimum,unplug from mains,connect all cables,turn back on.
Sep 23, 2007 | Onkyo TX-SR604 Receiver
Front panel timer/stand by blinking light
did you clear the code by hitting display channel 5 volume up then power then press 8 enter or look at sony blinking codes to reset to factory settings
Sep 10, 2007 | Sony KP-57HW40 57" Rear Projection...
Akai LCT3201AD 32 in. LCD Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
