Question about Maytag Legacy Series Top Load Washer
Maytag Legacy Toploader Leaks under the tub
I have a used 2003 Legacy top loader. Used it for 2 months then last night after a load finished, found the heart pine floor in the laundry room soaking wet. Tried a small load this afternoon with the front panel off. As soon as it started agitating in the wash cycle, it began leaking under the tub. Stopping the machine produced a near drinking-straw thick stream of water from under the tub. I then went to spin and checked the hoses and flow from the hoses. They were dry and appeared to be fine. I'm surprised the leak developed so quickly. Is this fixable? I'm pretty handy but have never taken on a washing machine. I have no schematic.
Thanks for any help.Save
  • coryandloral Nov 20, 2008
    i have a leak under the washing machine. i took the front panel off to see where it's coming from, and it leaks during the spin cycle from underneath the middle. help!
Mine developed a hair line crack in the plastic tub on the very back. It is right where the water hits it when it is filling and I am thinking that might have had something to do with it since I have extremely hard water full of minerals which can be very abrasive. I thought that the tub was leaking from the bottom but close inspection showed that the crack was allowing water to run down the side and right onto that bottom metal plate and drip out. Im going to try and find a replacement or a way to patch the plastic, cant afford a new washer at the moment. If I find a solid way to repair it I will post it here when I am done.
Posted on May 20, 2010
After looking at various posts on your site, it seemed to me to be a gasket issue under the tub and the unit was going to have to be dismantled. I bought the set used, so I thought this would amount to more than I payed for the unit itself...maybe more than the both off them. So I did what I should of done when I bought these: I went to Lowe's and picked up a new sratch and dent set. They deliver this afternoon.
This is a great sight, but I hope I don't have to visit in the near future with a washer dryer problem. Thanks!
Posted on Nov 16, 2008
I have water leaking on maytag legacy. 9 years old. getting worse over 3 months. removed front and rear panels, dried out and looked for leaks. only water was on agitator base. im thinking tub bearings and...
Look for splatter signs along all of the inter panels, including the ones removed, splatter marks will be just below the line of the tub. Pleazer Appliance...
Apr 14, 2014 | Maytag Legacy Top Load Washer
Washer leaks during fill up from underneath
It is going to either be the tub hose that goes to the pump or the pump itself. If both of these are ok then you would need to replace the tub seal. To replace the center tub seal you remove the tub and motor from the washer by getting the 2 springs off there and taking the hoses off. Unplug the motor harness and the whole thing comes out. Here it some photos of how it all goes down.
Single belt top loading maytag washer tip by TheMobilian
Jul 10, 2011 | Maytag Legacy Series Top Load Washer
We have a Maytag top-loader model A482 which is probably 25 years old. I found water on the floor under the machine when the last load finished washing. What's the first place to look for the leak? I'm...
The most common thing that will cause a leak is the tub seal. If the tub seal is leaking water will be comming from the center of the tub where the transmission meets the tub. This page will show how to replace the seal. http://appliance-repair-it.com/Maytag-tub-seal.html
There is also an air-gap that will often leak. If this is the case the water will be comming from the left hand side at the top. The air-gap is in line with the water inlet. This page will tell more http://www.appliance-repair-it.com/Maytag-washer-leaking.html
If they are not the problem you will have to look for a leaking hose or something to that nature.
Sep 28, 2010 | Maytag Washing Machines
I have front loader MFW9700 Maytag washer. Water
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
Feb 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
Replacing lid on old Maytag toploader
pull the lid back at angle and they will fall into tub.put one side in wet the other side and try to put ball on lid and slide it back into slot for lid ball.may be a hasssle but it will go into place.
Mar 09, 2009 | Maytag PAV2300 Top Load Washer
Maytag leaks water in the spining cycle and makes a loud noice.
how old is your maytag top loader ? pump do not leak that often on maytag top loader you may need stem&seal kit &tub bearing kit
Feb 18, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Leaking Washer Machine
this is joyce
This sounds like a center seal kit, they run around $80.00 they are complecated to install so I would suggest getting someone to install for you.
thanks,
joyce
Feb 06, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag legacy series washer top load-squeaky during wash and rinse
very possible if squeaks in agitation top springs that hold tub needs greased under spring & plastic shield under spring. had same problem on big front loaders whirlpool
Aug 31, 2008 | Maytag MAH2400A Front Load Washer
Maytag MAV7700, Grinding and water leak
open the front with a puttyknife there are 2 clips about 4" in on each side this wil open the top so you can remove the 2 screws holding the front panel on once removed you can see the guts of the unit..Let me know if you need more help
Jan 28, 2008 | Maytag MAV7600 Top Load Washer
Spins really fast and loud and is leaking at bottom of tub where shaft goes in
buy a new washer .specifically a direct drive whirlpool,no belt. maytag washers are not what they use to be.
Jan 04, 2008 | Maytag Legacy Series Top Load Washer
Washing Machines Logo
175 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
