Question about Kohler 1209-LA-0 Hourglass Whirlpool with Integral Apron, Flange and Left-H
Kohler whirlpool 5' tub
How to replace jets?
  • 33 Answers
Here is the link to the Kohler 1209-LA jets exploded view:
Kohler 1209-LA
Hope this helps!
Posted on Dec 05, 2008
3 Suggested Answers
PartsCenter
  • 125 Answers
SOURCE: kohler whirlpool will not shut off and sounds like about to blow
Sounds as if you may need a new switch to turn the tub on/off. You can find one on our site www.uspartscenter.com
Posted on Mar 04, 2009
PartsCenter
  • 125 Answers
SOURCE: Kohler K1338 spa tub controls messing up
no it is not damaged. that is the way it is operated. it always resets to the bottom jets first.
How do I change jets in bathtub?
Do you wish to change the jets in the tub or just the trim?
If you just want to change the trim then you need to go the your local Kohler showroom and they can match up the correct replacements for you.
Rod
US Parts Center
Nov 25, 2013 | Kohler 1107-R-0 ProFlex Bath Tub with...
Where the filter is located
There are no filters on jetted bathtubs. There is a screen with dozens of holes located in the footwell of the tub. that is the suction cover. the water flows through that screen into the front of the pump and then out through each of the water jets.
US Parts Center
Aug 21, 2013 | Kohler 1014-H2-96 Portrait 5' Whirlpool...
We have a Kohler Purist Air Bubble Massage tub... the last couple days the dial has randomly started lighting up with the green light tracking down the middle and you can hear the motor or the jets on the...
This is sounding like a relay not working on the circuit board inside the control box. You will want to have a Kohler service center send someone out to have it checked. You most likely need a new control box.
Aug 14, 2011 | Kohler K-1110-AH-0 Purist whirlpool with...
We can't turn the jets off on our whirlpool! pushing the button all the way in and nothing..it's just running and running!!!!!!!!
button works neumatically..(has a small ball like bubble) burst on the on position...u can twist off the ring around it and take apart..and replace..(need make n model of whirlpool)
Nov 19, 2010 | Kohler 1112-LA-0 Windward 5' Bath...
I have a 1980 kohler jacauzzi tub with 6 jets. Looking through the access cover, at the end of the tub, I can see water dripping from some of the jets. Can I fix this without tearing out the walls around...
no not really the only way to fix it right is to open up the walls. this is a common problem with these units, the best thing you can do is contact the manufacture who made it and ask them what to do.
May 18, 2010 | Kohler 1221-H-0 Seadream 6' Whirlpool Bath...
My Kohler whirlpool started on its own with no water in it. We turned it off with the switch and it hasn't happened again. Is there a danger of it starting a fire if we are away from home and it does it...
Most Kohler tubs have a water sensor or water level sensor. Is this an air bath tub (holes in the floor)? or a jetted tub? If it is an air bath, the tub will purge after using it 15 to 30 minutes ater it is drained. If it is programable it will come on every 24 hours if it has been programmed. If it is a jetted tub, there may have been water on the sensor and caused it to start up. If it is a single on/off button the switch could have gotten water and caused it to start up, or there is a problem with the control box. It usually will not start a fire if it comes on, most of the newer pumps have run dry seals. If you leave the house for vacation or weekends, I would advise unplugging the tub or turning off the breaker.
Aug 28, 2009 | Kohler 1014-H2-96 Portrait 5' Whirlpool...
Kohler Whirlpool tub motor wont turn on
Kohler Whirlpool tub turns on and shuts right off. Reset gfi and motor turns on and shuts right off. Help
Mar 15, 2009 | Kitchen Appliances - Others
Mar 04, 2009 | Home
Kohler whirlpool will not shut off and sounds like about to blow
Feb 28, 2009 | Kohler 1221-H-0 Seadream 6' Whirlpool Bath...
How do I install a whirlpool bathtub?
here is a link to the some installation and operating instructions.
basically you need to put a 2" x 2" runner under the lip of the tub along the three sides of the tub that touch the walls to support the lip of the tub. that pretty much covers it.
Feb 22, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Kohler 1209-LA-0 Hourglass Whirlpool with Integral Apron, Flange and Left-H Logo
313 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
