Question about Fuji FinePix S602 Zoom Digital Camera
Card not initialized
This error message came up on my camera it is referring to a card that i had used dozens of times with no problem i searched for the error message and it did not come up (why is it that electronic manufactures will create error messages and not even explain what they mean on their web sites?????????? - but that is beside the point) how do i get this card 'initialized'?
  • 6 more comments
  • RadrianO Nov 03, 2007
    I have the same problem. Isn't there any other way of fixing it, without loseing the photos on the memory card? :-|
  • jjp288 Nov 13, 2007
    I plugged my e550 into my mac to load up pictures, but the batteries died halfway through, and now I'm getting the same message. I know how to format the card, but is there any way to get the pictures off first? I would really like to recover them...
  • bergayse Nov 20, 2007
    Fuji FinePix f410 Digital Camera
  • superstarloz Nov 21, 2007
    hey i have the same problem it says card not INITIALIZED!! and i really need to fix it because its not my camera and i wasn't supposed to use it in the first place!!! and now i'm desperate to find out how to fix it!! please help!! =( Lauren xxxx
  • cedez Dec 02, 2007
    my camera which ive had for about 9 months now!!!
    im trying to take a pic but it says card error and it wont let me
    and when i take the card out and try and take a pic it does but then it doesnt go on the comp. it juss says no card!!!!!
    i really need 2 take pixs help plz..
  • murrrrrry Dec 29, 2007
    so i wanted to get the pictures and videos up on the computer and it didnt work the first time so i tried again. it finally worked but then the computer wouldnt take the pictures so i took the memory card out. then i turned my camera back on and it just said 'card not initialized' and there was nothing stored in the camera anymore. im afraid that all my pics are gone. HELP!!!!
  • bracegirl Apr 01, 2008
    card not initializing. Instruction book not very helpful. I need step by step instructions as to what to do
  • Anonymous Sep 30, 2008
    my 1g compact flash card was reading fine i took about 400 pic and yesterday when i went to put them on my computer now its saying card not initialized i cant find no photos and it wont read the card for the recovery programs ive tried 2 can someone please please please pleeeeeeeeeeeeease help me
I had a similar issue with an XD card in my Fuji FinePix S3000.
I had used the several times for a couple of years without problem.
The issue appeared right after dowloading pictures from the card inserted in my notebooks' card reader - an operation I have done several times in the same notebook without any problem.
I have fixed the issue going to Menu, Option, SetUp, Format and choosed OK.
Deleted all the pictures (make a copy before if the card is readable in the pc as it was my case) but made the card readable again.
Posted on Oct 17, 2007
Fine Pix F601z >> I always forget how to initialize my smart card... uggh! Here are the instructions:
Go to MENU button, click
Select ERASE (trash can), click
Scroll down to FORMAT, click
FORMAT OK? will come up, click OK
You are now ready to take pictures...
Now who ever thought to put the FORMAT key in the trash can and not in SET UP???? I don't get it.
Posted on Oct 25, 2008
Ok, I have the same problem and this is what I have so far. I have spoken to Lexar (card manufacturer) and they have nothing in their knowledge base regarding the sudden failure of my card (a 256 mg CF card 40x wa compatible) to be read in one device and not others. My card will not initialize in my camera, but will format and read in my PC in more than one reader. Also, I have tried to use a different CF card in my camera and after it took a while to reformat it to its own standard it worked fine. Calling Fuji support (In Edison NJ) got me little info. The first tech said in effect that if the camera read a different card it was the first card and not the camera. Telling him the card read everywhere except the camera got me nowhere. Heres the good part. There is a firmware upgrade for the camera. There is a possibility that the cards have been formatted in such a way that the camera can no longer recognize it (a kind of low level format comes to mind) You might try reformatting your card in a Non-XP system (win 98-2000) and see if that yields results. I don;t have access to an older system that supports a USB connection so I can't try this myself. Also, try another CF card and see what happens Ed
Posted on Dec 05, 2006
  • Edward Zuccarelli Apr 15, 2007
    This is what this turned out to be. The number one pin in the camera was disconnected from the circuit board.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
Try these solutions to fix the SD card not initialized error message:
Remove the card from the camera and then re-insert the card back to its slot and see if the problem is solved or not.
Second, clean the memory card, particularly the metal parts of the card and make sure it contact properly.
If both above solutions fails, then the last option to fix the issue is to format the card.
The above solution is brought to you by:
How To Fix SD Card Not Initialized Error
Posted on Dec 04, 2017
I printed some photos off at a kiosk and when i took my memory card out it said "card not initialized". i have about 1000 photos on the memory card and some which i really need and dont want to lose, any ideas? when i put the camera onto my computer it doesnt do anything, its like the computer doesnt recognise it?
Posted on Jul 31, 2010
I have a FujiPix F700.
I rec'd this message, after I used the card in another camera..or
perhaps a PC, I forget.
Anyway,
Press Menu
Then use the cursor pad, or joypad to go over to the
right to Setup.
Select , then choose Format, and you will have to select Yes, next.
It will Format the card, and then you are set.
This works every time, no guess work.
Posted on Dec 18, 2009
I had this problem after my boyfriend uploaded pictures onto his Mac. It was fixed by going to MENU on the camera, then SET, FORMAT, and click yes. It will erase all of your information, but fix the problem instantly. Hope this helps!
Posted on Sep 12, 2007
Format it as fat on xp, and then format it from within the camera. I noticed it worked much faster when formated from the camera.
Posted on Aug 15, 2007
THANKS ED! I tried formatting my 4 G card on a back up PC running Win 2000 and unlike XP it gave me a choice to format FAT, NTFS and FAT 32... I tried formatting with FAT and it worked like a charm! Thanks again for the tip! doug
Posted on Jul 01, 2007
My card reads again,after reformat in another fuji 2easy =thankx
Posted on Aug 25, 2009
Memory card error on fujifilm finepix series s4800
Eject the bad memory card and try another one. It is possible that the card in the camera right now has corrupted. You can try some of the online recovery tools to try and rescuse what is on the card if you have not already transfered the pictures off the camera.
Dec 10, 2014 | FUJIFILM Cameras
Sdhc card was workin/g and it said card not initialized
  • turn off you camera and remove the memory card
  • reinsert the card and turn on your camera
  • re-format the card (low level) using your camera . / or under menu search for format or initialize
Aug 27, 2014 | Cameras
My camera keeps saying card error? It wont let me take pics or even look at ones already on the camera?.... Just keeps saying card error. What should I do??
Welcome to Fixya.
There are two possible reasons why your caemra keeps on displaying CARD ERROR.
First reason is not formatted for use in the camera. The solution there is you just have to format the memory card. In order for you to format the memory card you just have to click on this link and refer to page 89 in formatting memory card.
Second reason is memory cards need to be clean. You just have to clean it with soft and dry clothes. If the message is repeadted. That's the time that memory card needs to be replaced.
I hope this information give you a relief on your problem.
Thank you for using FixYa.
Apr 04, 2011 | FUJIFILM FinePix Z80 Digital Camera
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
After taking dozens of pics all day my camera all of a sudden won't take a pic, zoom, etc and after a short time it says card reader error.
The memory card may be full. Transfer the pictures from the camera as normal (or directed), and once sure they are on your computer or printed out, delete all the pictures (erase) from the memory card.
Try to take pictures again - if the error is still present (or you are unable to transfer the pictures to the computer) , there may be an issue with the card. You may not be able to use the card anymore - but before discarding, see if it works in another device or "stand alone memory card reader". If it works in either of those devices, there may be a problem with your camera. Try using another memory card to see if you get the same message when trying to take pictures with the new card installed. if you do, it looks more like a camera problem than a memory card problem. Hopefully, it's the memory - and not the camera.
Please rate this reply if helpful - good luck!
Jul 08, 2010 | Samsung SL202 Digital Camera
Canon Legria HF200 SDHC Initialization problem
This totally sucks. I have a similar issue with my Canon Vixia HF R20 and I'm using a Lexar Pro 64Gb 133x SDXC card. When trying to initialize the card, its fails and says "Process terminated with error." It also says "check the memory card" when I first put it in. Write-protect is off. My other SanDisk class 4 SDHC card seems to work ok.
I could have sworn it worked before and I was able to transfer videos to my Mac on 10.6, but I can't remember for sure if I was using the SDXC card or just the built-in memory. Very frustrating.
Apr 12, 2010 | Canon Legria HF200 Flash Media Camcorder
Is there a size limit for the memory card for the SD630. I put a 4 GB one in it, and it say memory card error
This camera only supports up to 2GIG or memory card so that's the reason why the 4 GIG wont work with it....
Jul 31, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Fuji FinePix S602 Zoom Digital Camera Logo
3,624 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
KJ Soni
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Fuji Camera Expert? Answer questions, earn points and help others
