Question about Gateway 835GM (835GH) PC Desktop
I have a gateway 835gm desk top
I push the start button the fans start and then shut off nothing else happens. Just the the fans start to rotate and then stop. Will not boot had no problems just out of the blue will not start up??
  • Gateway Master
  • 4,806 Answers
There are a number of things that could be wrong here, firstly reset the cmos on the motherboard, if you cannot find the cmos jumper then remove the battery for 10 minutes (make sure the power cord is removed from the back) press the on/off button a couple of times, this will drain any remaining power from the board and properly reset the cmos, while the battery is out remove the memory, clean the contacts and repace, put the battery back in and connect power, if the machine turns on, job done, if not then it could be something far more serious, check the power suppy if could be faulty, the processor may have blown or the motherboard itself may have blown, the only way to check all the components at once is to get a working motherboard which supports your processor type, the same model would be an advantage
Posted on Nov 15, 2008
    Sergeant:
    Champion:
  • 334 Answers
It may be the power supply but i think its the motherboard.
How do i check to see if the hard drice is working on my gateway 835gm desk top
HARD DISK MONITORING From this website you can download a software program to check your hard disk health. First you download a trial version and install after downloading. Then run the program then scan by clicking the hard disk test with your having problem drive. The said program are capable of detecting errors and defect so you can easily see there that your hard disk surface.
Feb 15, 2015 | Gateway Computers & Internet
Where can i get a free diagram of the motherboard layout for the Gateway 835GM?
There are many things to be considered by having a problem with your boot up. First common factor is infected with the virus of your operating system or corrupted, then possible your hard disk drive is having a mechanical trouble due to improper shut down or by hanging up. If this is the case, you have to reformat your computer operating system and or change you hard disk drive in order to fix the said problem.
Jun 01, 2014 | Gateway 838GM (RB838GM) PC Desktop
Gateway gt4016 wont turn on you can hear the fan and light flicks on for a second but then nothing changed the power supply nothing
try rebooting your coumpter is in sleep mode it takes a long time but you will get it back on .... keep pushing the power button aventally it will start up
Jun 30, 2012 | Gateway GT4016 Desktop PC
Need help with my gateway 835gm replaced memory ram
Does your motherboad support the ram and is it the same as the other one (if any)
Feb 02, 2012 | Gateway 835GM (835GH) PC Desktop
Fan works randomly....when it's not working plug
Hi, If the computer is hot near the electrical plug in the back of the computer then the power supply needs to be replaced. This will also cause overheating problems if the fan does not exhaust enough air. You should not run the computer in this condition because the power supply can short out and take other components with it. Also there is a risk that it will burn up. Power supplies are very inexpensive and can be changed by anyone with basic computer repair knowledge. Hank
Jul 26, 2010 | eMachines T5212 PC Desktop
835gm powers up, but monitor power button goes amber, screen stays black and fan stays on high rpm. Had problem in past, usually solved with restart, but have had this computer in storage for awhile, now...
1. It could be bad connection of Memory, CPU, Graphic-cards etc. Try to reseat them aswell.
2. Have you tried replacing the power-unit?
3. Some BIOS es are a bit 'stupid', do you have a fairly new and working monitor plugged in directly (bypassing KVMs)?
Worst case is 'BGA-slip', the bridge-chips and/or onboard GPU has some broken solderings, typically happens to Laptops.
Jul 18, 2010 | Gateway 835GM (835GH) PC Desktop
Gateway M675 will not boot. When I push the start
This might have something to do with the battery.
Have you tried to boot it up without the battery in it?
Regards.
Jul 03, 2010 | Gateway M675 Notebook
Gateway 500xl pc will not turn on power button is lit up yellow
A LOT of Gateway computers will go into this catatonic state because of a dead battery. The battery is on the motherboard -- it looks like a metal disk about 1" in diamter. Check it or replace it. This applies to laptops too (not the actual laptop battery, the CMOS battery -- a laptop will have one on the motherboard too)
Hope this helps
Mar 13, 2009 | Gateway 500XL PC Desktop
Gateway 835GM (835GH) PC Desktop Logo
199 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
