Question about HP Photosmart C5180 All-In-One InkJet Printer
Paper jam how to remove paper tray to free paper jam?
  • lamontagne1 Nov 16, 2008
    thank you, were all set now printer is back in working order.
    thanks for all the help
    Roger
  • 35 Answers
Hi...
- click this site to... to help you on how to clear paper jam
- http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00702180&dlc=en&product=1153481
Posted on Nov 16, 2008
Says paper out or paper jam which nither are happening
  1. Unplug the power cord.
  2. Check to see if the print carriage moves freely from one side of the printer to the other. ...
  3. Remove the print cartridges. ...
  4. Gently move the print cartridge to the far right of the printer.
  5. Remove the paper from the paper In tray, but do not remove the drawer.
  6. Step one: Clear the paper jam from the output tray
    1. Carefully remove any loose paper from the output tray.
    2. Check the rollers in the output tray for jammed paper.
    3. Use a flashlight to see the rollers in the printer.
      Figure : Use a flashlight
    4. Gently remove any jammed paper or bits of torn paper from the output tray rollers. Use both hands to pull out any whole sheets of paper to avoid tearing them.
    5. Remove any bits of paper or torn pieces of paper from the output tray rollers.
    Step two: Clear the jam from the input tray
    1. Press the Power button to turn off the printer.
    2. Disconnect the power cord from the rear of the printer.
    3. Remove all paper from the output tray.
    4. Raise the output tray.
      Figure : Raise the output tray
    5. Grasp any jammed paper in the input tray with both hands, and then pull the paper slowly but firmly toward you to remove it.
      CAUTION: Remove paper from the tray as carefully as possible. If any torn pieces of paper remain inside the printer, more paper jams are likely to occur, and this could damage the print mechanism.
    6. Lower the output tray.
    7. Reconnect the power cord to the rear of the printer.
    8. Press the Power button to turn off the printer.
    If you are not satisfied with this answer then for detail answer please read here > http://www.brotherprintersupportnumber.com
Feb 14, 2016 | Epson WorkForce Pro WP-4540 Color Ink-jet
Error e03, but there is no jammed paper
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Paper jams
Please check the following steps:
1.Turn the printer off and on to see if it can automatically clear some or all of the jam.
2. Turn off the printer. Remove any paper trays. Look for damaged paper.
3. If necessary, remove the toner or ink cartridge.
4. If you find a piece of jammed paper, remove it.
7. If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
8. Replace the toner or ink cartridge and paper trays.
9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
**If this works please rate else let me know in case of further help.**
Jul 05, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Paper jam message does not clear after paper jam has been removed
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your copier
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the copier
5. Close all doors and put back all trays
6. Turn on your copier
NOTE: Please rate our help to keep this free service online.
Jan 08, 2010 | Canon imageCLASS D480 Black and White...
It say paper jam and ther is no paper jam
1. Turn off your printer
4. Repeate the above step for all buttons that you can find to access the inside of the printer
6. Turn on your printer
Dec 31, 2009 | Samsung SF-335T Plain Paper Inkjet Fax
PAPER JAM PRINTER SAYS PAPER JAM IN INPUT TRAYS BUT PAPER DOES NOT SEEM TO BE JAMMING
Dec 11, 2009 | HP LaserJet 4050 Printer
Machine says there is a paper jam when there is no jam. Shows jam in exit but the paper never even starts to get picked up from the main paper cassette but it will feed fine frome the mp tray. any...
Dec 08, 2009 | Samsung SCX-6320F All-In-One Laser Printer
Paper jam
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Dec 26, 2008 | Canon PIXMA MP150 All-In-One InkJet...
My hp 1315 all in one had paper jam
1. Remove any loose paper
a. remove any loose paper from the In tray and Out tray
b. press the cancel button (x) on the product control panel to clear the paper jam
2. Clear the jam from the back of the printer
a. press the Power button to turn off the product
b. unplug the power cord from the back of the product
c. remove the rear access door. turn the knob one quarter turn to the left, and then pull the door away from the product
d. gently remove the paper
3. Clean the rollers with a lint free cloth that is moist with water
4. Try printing again
Aug 07, 2008 | HP DeskJet 5652 InkJet Printer
Paper jam
hey, give this a shot
alternative :
Oct 19, 2007 | HP OfficeJet G55 All-In-One InkJet Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
188 people viewed this question
Seeker5211
Seeker5211
