Question about Dishwashers
The dishwasher tower arm is broke
I have a GE Potscrubber 1200. No manual or guides with it. About a month ago i noticed the dishes weren't coming clean. I got down and looked inside and found the tower arm is broke apart and laying inside my dishwasher. I am trying to figure out how I could get this fixed so that I may use the thing agian. the model number is GSC1200x08.
    Scholar:
  • 131 Answers
If the spray arm assembly is still in one piece(what i mean buy this,is that the bottom of it has'nt snapped off in the pump)it should be a simple matter of plugging the arm back into the pump & tightening the clamp(this is located on the neck of the pump)you will need to pull the unit out to gain access to this(it's under the tub)if this is not the case the arm itself is under 20$,as the sleeve & clamp assembly is under 10$hope this is of some help.thanx for using fix-ya.please rate all replys
Posted on Nov 15, 2008
Ge potscrubber 600 the washer arm is not cleaning dishes on top shel
Remove the arm and clean it. It is surprising how much 'stuff" gets in to them and blocks the holes.
Aug 12, 2014 | Dishwashers
How do you remove the sprayer arm from a GE potscrubber 600
Thought I had a problem with the spray arm or pump because water was not flowing enough to spray the upper rack. But it turned out it was a simple part missing: the "check valve" that is in the lower neck of the spray arm assembly. It's a $10 part. Part #WD1X5488 for GE Potscrubber 600.
May 20, 2013 | Dishwashers
My GE Potscrubber 950 dishwasher is making a lound grinding noise when I turn it on. The noice continues through the entire time that the dishwasher is on. It does still get my dishes clean but the noise...
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the spraying arm or the pressure pump can be defective .It is important that you look for the noise with a good inspection lamp. Manually turn the spraying arm and the motor and listen for the noise, if so the motor bearings, the arm shaft and fittings must be checked. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
For replacement of spraying arms check for tips on this visual link:
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
Thank You for using fixya
Aug 24, 2011 | GE Blenders
Hello, my 1992 GE potscrubber 630 is not cleaning well at the moment. Could vinegar or a little bleach help if it something is clogged with hardwater or food particles. thx.
My GE Potscrubber 630 dishwasher leaves a white film on all of the dishes. Is there a filter that can be cleaned out?
Aug 07, 2010 | GE Dishwashers
Problem with heating element?
HI Put the dishwsher in the dry cycle and after a mineute or so feel the element if its hot its ok. If not you need a electrical meter to check it
Feb 27, 2010 | GE Dishwashers
My GE Potscrubber 1200 cuts on perfectly and
probebly you dont have enough water coming in start the dishwasher,when it starts washing dump a bucket of water in the tub.if it starts moving replace the intake valve
Feb 26, 2010 | GE Dishwashers
Water not coming into dishwasher
Without knowing the model number of your GE dishwasher, but some dishwashers don't notice when the float / float switch is stuck. That could cause the dish washer to move through all the cycles but never have water flow into the dishwasher. That would be the first place I would look. But please post back here with what you find (plus the model number of your dishwasher) before ou rate me level of helpfulness, OK?
May 09, 2009 | Dishwashers
GE POTSCRUBBER 1200 DISHWASHER
I have a Ge Potscrubber 1200. Fairly new I guess as I bought it with the house that I purchased 1 1/2 years ago. Sometimes it drains and sometimes it does not. Today there was two inches of water! About to remove the bottom panel. Sounds like the drain valve it blocked but not sure. Any thoughts?
Apr 14, 2008 | Dishwashers
Dishwashers Logo
235 people viewed this question
Top Dishwashers Experts
