Question about Akai LCT2715 27 in. LCD Television
Blinking red light
The LCT2715 is over 2 years old. It hasn't been used that much until recently. Last night, the TV's picture went blank and was making an awful sound. Unplugged to make it stop. Plugged in the power cord again, nothing. Only a blinking red light. You can used the power switch to turn the blinking light off and then back on again. This light used to be either solid red when off or green when on. So what does this blinking red light mean. Is the power supply bad?
  • 2 more comments
  • Anonymous Nov 20, 2008
    tsnk you
  • Anonymous Nov 24, 2008
    I have the same problem except I can hear the speakers popping with the blinking light.
    Yes! Same problem. Popping in speakers and will not even come on anymore. So this $600 three year old AKAI junk sits in the corner in the bedroom while we watch our 14 year old $99 Sharp. Not funny.
    Guest
  • marge1958 Dec 07, 2008
    I have owned this TV for only about one year and the same thing is happening to this TV, blinking red light with a high pitch loud beeping sound as the red light is blinking. I havd to manually turn the TV off as the controller is not functioning properly either. Please advise!
I have experienced this also, 5 times red led blinking when turned on, its a tube flat tv. i think this is all about power supply of the screen, all i did is to adjust the plyback supply and the tv goes ok now.
Posted on Apr 07, 2009
  • 2,326 Answers
It appears in all cases that the power supply needs to be service. The blinking light might indicate that there are shorted parts or the voltage is low or a combination of both.
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Posted on Nov 27, 2008
I DO HAVE THE SAME PROBLEM , ONLY THE RED LIGHT BLINKING ,NO SOUND NO PICTURE '
PLEASE I DO NEED HELP TO FIX IT .THNKS
Posted on Nov 18, 2008
My Vizio M261VP picture and sound went off last night but the power on white light on the corner of the frame kept blinking. Once before I unplugged this unit for a while and this fixed the problem. ...
If its something your comforrtable doing remove the back cover and test the power supply voltages, I think you will find at least one is missing, and in that case replace the power board
Nov 29, 2017 | Vizio M261VP 26" LCD TV
Blue light remains lit but lose picture. no other indicator lights flash. if i unplug the tv it will restart but lose picture again after half hour
I have a toshiba 50hm67 tv and with mine the blue light would come on and I would hear sound first and then the picture would finally come on... this happend for about a month.... next the yellow and blue light would come on but the pic still wouldn't come on until it clicked off and on by itself for about 10 min this went on for about a week. All of a sudden last night the red lights by the power light started blinking. No tv now and when the tv shut off it said lamp not working.
Sep 17, 2010 | Toshiba 56HM66 56" Projection HDTV
Have an old sony HDTV proj tv, and the picture went out last night. I heard sort of a "pop" then no picture
Pop sound shows that some thing went wrong inside TV and most probably any part got busted.
Let me know model number of your Sony TV and does its standby red light blinking? if yes, how many times it blinks between 3 seconds interval.
Nov 30, 2009 | Televison & Video
The input function is not working and the t.v. is on but no picture. Blank screen. Was working last night just fine we tried to hook up Xbox and when the input button was pressed screen went blank. any...
Perform Reset From Front panel of Tv, wait until green light stops blinking, set is running self diagnostic. If that doesn't work, it could be something in the DMD Panel containing the Digital Micromirror Device
Oct 10, 2009 | Mitsubishi Diamond WD-65831 65" Projection...
TV makes a spinning noise coming from the lower right side.
If there is a red light blinking that means that the projection light needs to be replaced.
Jul 26, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
PROTRON 26 TWO YEARS OLD
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com
Jan 20, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
RED BLINKING LIGHT ON HITACHI TV CANNOT TURN ON
Check the resisters, that could be the burnt small, also you may need to replace the ICs
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Sony KDF-42WE655
Bad lamp and/or lamp driver. Try replacing the lamp first.
Aug 20, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
No picture on screen
MYGR8-YOU HAVE TO LIST BRAND NAME AND MODEL #. JOE TV
Nov 30, 2007 | Televison & Video
Akai LCT2715 27 in. LCD Television Logo
1,933 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
