Question about NAD T751 Receiver
Nad 751 suden loss of somthing thier is a loud buzzing like a 1/2
I have changed cables,cd players, The dealer told me with out even looking it was not worth fixing. Something in the front panel they said. Isounds like a resitor or diode is heating up and failing how would I test it?
  • 42 Answers
SOURCE: Laser unit NAD 5100 Monitor Series
Hey, I think you can bye new laser here http://www.pltv.org.uk/laser.htm I have a nad 5300 monitor series, same laser as 5100, you can buy the hole cd player from http://www.miguelovitch.dk Laser work, but problems with cd transport. When i 'help' the cd transport, cd play as expected. And i agree, it is a nice cd player, also i have heard lot of nad cds on quad 405, sounds realy good. Try to visit my site, i also have a lot of free schematic for nad, denon, quad and mora. Also repair notes for amplifiers, tech videos, diy schematics and more.. Also at this moment i am working on a new 'nad cd service movie) including cleaning, maintenance, repair and more on nad 522, 501, 502 c521 and more see you best regards michael miguelovitch http://www.miguelovitch.dk
Posted on Sep 27, 2007
konzzz
  • 255 Answers
SOURCE: No volume control
lower the volume of the cd player
Posted on May 08, 2009
smarthome2
  • 1114 Answers
SOURCE: No signal from sub connected to NAD T760 in test mode.
Try using front pre out to the sub from the receiver. the crossover is in the sub anyway. If this works change your settings on the receiver and test again. If sub is still inop, could be an internal issue with the sub amp. Does your sub amp have an on/auto/off switch or light? check that as well. Hope this helps, if you need further assistance, send a reply and I'll help some more
Posted on May 24, 2009
Grubhead
  • 5309 Answers
SOURCE: my nad amp wont turn on - i've checked plug fuse so it must be something inside - was told it might not be worth fixing but i wuld like toknow what it is so i can at least decide. it's only 2 years ol
Yes it could be the internal fuse. If your lucky it might have just failed on it's own!
Posted on Jun 02, 2009
SOURCE: My NAD cd-player has locked it self! I cannot play
Mine does the same. Press eject and give the front of the draw a sharp tap.. the draw should then open.
Also when loading a disk give the draw a hard shove closed just as it is almost shut - seems to make the disk read ok.
I think both problems are related to a worn / slack tray drive belt... I just haven't been able to find a replacement.
Posted on Jan 29, 2010
Sound distortion with NAD T 514...
You are probably clipping in that midrange. Since the DVD player is fine and CD player is distorting: they are line level outputs, If you are running those through an equalizer- the equalizer should allow you add in a 10db attenuation.
If you are running them straight to the amp, The CD line level output should be about 1.5 volt peak to peak, it may be the line level input of your amp is only 1 volt and the DVD player simply has that level of output so does not clip..
Simply adding into the cable a 0.1 microfarad polyester capacitor for each channel should be enough attenuation to avoid clipping. The midrange is where you hear the most content in large part because that is the range that the human ear is most sensitive to. Which is why that portion clips. The DVD audio is actually recorded to the same specs as CD audio. You can confirm this by playing your CD disk in your DVD player. .
Sep 25, 2012 | Audio Players & Recorders
My NAD C326BEE amp goes into protection mode at moderate volume
The protection only should come on, when the power amplifier has to give more current than it can deliver. (electronic fuse)
If in the music is a lot of subsonic, sound, so low you can't hear and your speakers can't produce, this could cause the problem. Normal CD players will cut of all frequencies beneath 20 Hz, but it could be your PC is giving everything from 1 Hz and above.
I would certainly try to play some music over a CD player and check if that would solve your problem. Not sure if that works, what you could do to suppress the sub sonic in the computer music.
Aug 22, 2012 | NAD C326BEE Amplifier
How to connect an MP3 Player to NAD C320?
You will need a cable with headphone jack (for mp3) and RCA left/right to connect to your NAD 320. You can connect to CD or AUX in the back and then you will need to change the input with remote or with on board buttons to CD or AUX depending where you plugged it.
Jun 20, 2012 | NAD C320 2-Channel Amplifier
I have a NAD C315BEE which is about 2 years old. It has been connected to the same speakers, CD player and wall socket for all that time but has suddenly started making a buzzing noise through the...
I had exactly the same problem and quickly repaired it: One of the two 10000uF 50V 85C caps was open circuit; replacing both of them solved it entirely. If you do this yourself, be very very careful to prevent shock.
Nov 14, 2010 | NAD C315BEE 2Channel Amplifier
No volume control
May 08, 2009 | NAD C320 2-Channel Amplifier
Is there a reset button for the NAD Surround Sound Receiver T 751
The only reset that i know of is to unplug it for 15 to 20 minutes. Hope this helps.
Dec 03, 2008 | NAD T751 Receiver
NAD T751 constant buzz
It is a known problem with this model. The source of the buzz is the Dsp power supply. On the DSP board itself there is a 2200my\f/16v capacitor that is defective . Usually the capacitor will turn brown and swells due to overheating. Replace it with a higher temp rating capacitor with the same capacitance and voltage specifications.
Sep 26, 2008 | NAD T751 Receiver
NAD CD player C 542
SORRY but you need to get this to your dealer,don,t think anything is stuck in there just a faulty drawer mecanisim.
hope this helps.
CABLE GUY.
Aug 04, 2008 | NAD C542 CD Player
Buzz in the speakers of a system with a Panasonic CQ-VA70EU
check your speaker polarity and recheck all pos and neg grounds
Dec 15, 2007 | Panasonic CQ-VA707W Car Video Player
Discs will not play.
Could be some dirt on laser lenses. Try to clean it.
Sep 25, 2007 | NAD C541 CD Player
NAD T751 Receiver Logo
138 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
