Question about Proview PL713S 17" Flat Panel LCD Monitor
When energized, screen stays on for about two seconds then blanks
Pl913s is plugged into HP Pavillion Computer. Repeatedly we disconnedted Video cable; the Green Power Light stays on when energized, and the NO INPUT dialogue boxes comes on then goes off when source is removed. I replaced PL with my old monitor and I'm doing this task. I took monitor back to Staples and we plugged it in and each time the screen came on for a moment then died to black. The system has been in my possession approximately 2 years and five months. Is there a warranty fix for this or am I on my own.
    Champion:
  • 293 Answers
Hi...there,
Well, it's seems your monitor backlight inverter are bursted. Usually, the monitor had a 1 year for the screen panel and 3 years for parts and labors. You're still under warranty, send it back to manufacturer for repaired.
Posted on Nov 21, 2008
Why is there a black screen on hp pavillion windows 7 "boot mnr missing"?
Windows 7 - black screen with blinking cursor
  1. Remove any CDs, DVDs, or memory cards from the computer.
  2. Disconnect all devices from the computer except the original mouse, monitor, and keyboard. Leave the power cord connected.
    1. Restart the computer.
    If it starts normally, start plugging devices in one at a time until you find one that may be causing the black screen
    1. Press the F10 key repeatedly during the first startup screen until the Entering setup message displays.
    2. Press the F5 key to restore the defaults. Use the arrow keys to select YES , and press Enter .
    3. Press the F10 key to save the changes and exit. Use the arrow keys to select YES , and press Enter .
      The computer restarts.
    4. If a Windows Error Recovery screen displays when the system restarts, select Start Windows Normally , and press Enter .
  • If this doesn't resolve it, follow the procedure below.
  • Aug 17, 2014 | HP 5188-7103 Compaq Motherboard Gl8e...
    Ato x600 hp pavillion won't boot
    You could try disabling the on board video in BIOS.
    Feb 04, 2013 | HP Pavilion Computers & Internet
    My HP pavillion g series,it turns on but the screen stays blank and dark
    My computer doesn't flicker any colour before it goes blank etc. When i turn it on, the screen is blank/black and It says its on.. by the light being lit up, but nothing happens. :/ I don't understand, whats the problem?
    Apr 26, 2012 | HP Computers & Internet
    HP Pavillion 500series to Panasonic TV with DMI port, hooked the HDMI cable from it to the tv, blank screen, made sure the tv was on HDMI, blank screen, unhooked the monitor, blank screen, hooked the...
    Most laptops have a "toggle":
    * output video only to internal LCD screen,
    * output video only to external HDMI port,
    * output video to both internal & external.
    Set the "toggle" to the best value.
    Jun 15, 2011 | HP Pavilion dv9000z Notebook
    My laptop worked fine on night then in the morning i started having problems. These are the problem that i am having my with my HP Pavillion 6910us Laptop. 1. My laptop comes on but cuts off after 5 to 6...
    Hi
    At some point if you can get the computer to stay up for a while, you should go into control panel and check your
    POWER settings. The other thing you should try if you haven't already is to shut the computer off and pull out the battery. Then after a minute re-install the battery and see
    if that helps.
    Good Luck
    Joe
    ps: If I come up with any ideas I will post.
    Mar 04, 2017 | HP Pavilion Dv6910us Notebook
    Screen stays lit for 2 seconds and then goes blank
    The problem can be bad caps (bulging top) which is more likely, or bad backlight inverter circuits. Check to see if you do have 12vdc or no bad caps, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
    Jan 21, 2010 | Proview PL913S 19" Flat Panel LCD Monitor
    HP Pavillion entertainment dv6000 - Power goes
    it is problem your laptop ram is rough position or demage change it then your laptop is active
    Jul 17, 2009 | Computers & Internet
    I have a HP Pavillion dv6000 that will turn on after a few seconds makes some beeps and the screen stays blank. The previous time it was on today it was fine. Any ideas ?
    hello
    Im almost sure that is the graphic card or motherboard. and they need to be changed.
    sorry...
    what is the exact beep code?
    try to unplug the battery and start the computer with power.
    do you have warranty ?
    Oct 05, 2008 | Computers & Internet
    Hp 6000 notebook screen goes black..... blue control lights go on and off
    if i'm reading this correctly, it sounds like it could be a motherboard/video issue. If that's the case then unfortunately you are probably going to need a new computer if it's out of warranty...
    for now however, try shutting down the computer and removing all power (power cord, battery) for a few minutes, then plug it back in and try to boot.
    Aug 13, 2008 | HP Pavillion ZV6000 Notebook
    Open Questions:
    See all Proview PL713S 17" Flat Panel LCD Monitor Questions
    Proview PL713S 17" Flat Panel LCD Monitor Logo
    108 people viewed this question
    Top Proview Computers & Internet Experts
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Pawan Ambastha
    Level 1 Expert
    Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
