Question about Xerox Phaser 8500/DN Printer
Cant read front display contrast too low?
The printer comes on and you can see the writing on the display only when the printer goes to power save but it is VERY faint. As soon as you hit the button to wake it up to try to do anything, like change the contrast, you can not see the writing on the screen. The back light does come on.
    President:
  • 2,072 Answers
Call ,1-800-835-6100. Have your serial number ready etc. Procede through the prompts. There is a known problem with that display and Xerox will replace it for you. They will send you one and it is real easy to replace.
Posted on Nov 16, 2008
My casio protrek 2500t watch is in power saving mode but even after keeping in dark for hours between 10pm and 6 am the display does not go off.Please help.
I own the same PRW-2500-1A (all black).Check if under the hours reading, PS appears.If yes,power saving function is activated.
Normally, Power Saving Function is enabled automatically (if activated) if the watch stays in complete dark for sometime.If after a couple of hours in the dark the watch comes suddenly under bright light,the display goes on immediately.Hour interval (10pm-6am) has nothing to do with Power Saver.
Try the following:
a)Deactivate and reactivate (or vice versa) the PS.
b)Leave the watch in the dark for a couple of hours .Then,still in the dark,try,using a very low power light (just that you can,barely read) to check if display is blank.If not you may have a problem with the light sensor found at the bottom of the display.Will be a very rare case but you have to take the watch to a CASIO authorized service.
Apr 29, 2016 | Casio Watches
How bellsouth caller id ci 43 contrast adjustments?
If the display is too light or too dark, you should adjust the contrast of the display.
Press either review button until NO CALL or the number of calls displays. Press and hold the READ button approximately 5 seconds until the display reads CONTRAST followed by a number. Release the READ button and use the review up and review down buttons to change the contrast number. When you are finished, press READ again.
From:http://users.javanet.com/u/s/use/caller_id_ci43.htm
Apr 26, 2014 | Canon Office Equipment & Supplies
I just had my Emachines D520 laptop display replaced because it was cracked. The new display is too bright, and the Fn keys that are supposed to control brightness don't work properly. When I use these...
Try going to control panel, then device manager, and try right clicking and updating all drivers that have to do with graphics or your screen. If this doesn't do the trick then try finding the display drivers manually.
Aug 24, 2011 | Acer Computers & Internet
Front display poising backlight and goes dim.
I believe this is most likely due to incorrect voltages at the display. If you have a meter and are familiar with working on electronics, check the voltage at pin 3 of cn501. It should be -28.5. If the voltage is very low, try changing C123 and C124 in the power supply. If the voltage is ok, check R925 and R932, these are both 10 ohm 1/8th watt.
Dec 13, 2017 | Aiwa AV-D97 Receiver
Im a graphic designer and my hp1502 screen is just to bright making me get all my colours wrong ,ive tried adjusting the controls but to nothing works ,is there something in circuit i can adjust to get my...
The best way is through the buttons in front pannel. It will bring an OSD (On screen Display). Adjust the brightness and contrast from there. ( But I guess you have tried it allready )
Then the other solution which i uses to brighten my display is Power Strip.
You can also lessen the brightness/sharpness/contrast.
Chech this link to read about it and a free trial download . Click here.
If helpful, kindly Rate.
Jul 18, 2009 | HP L1702 17" LCD Monitor
Alesissr 18 drum machine lcd does not display
Check if there is a contrast setting... Unfortunately, sometimes the setting can;t be viewed when contrast is too low. Read your manual and find how to get into that mode if it exists and turn it up.
Jul 16, 2009 | Alesis Sr 16 Stereo Drum Machine
The display is blu
locate the contrast control and, reduce the contrast on your lcd display
May 20, 2009 | Toshiba e-STUDIO 16 Printer
Printing issue
In order to proceed with the solution to your problem, we'll need to save the current settings on your Crown printer and then restore the printer to its original factory settings as shipped. Your current settings will be saved, and can be restored after we finish this troubleshooting session. You will need to access the printers front panel in order to perform the following settings.
Procedure to save your current printer settings
Procedure to restore printers original factory settings
Procedure to restore your saved printer settings
1. Make sure the Online light is lit and that the display reads Idle.
2. Press the Online/Offline button to take your printer offline.
3. Press the Menu button once. The display should read Operator Control.
4. Press the Right Arrow button once. The display should read Administration.
5. Press the Select button once. The display should read Communications.
6. Press the Left Arrow button until you see Miscellaneous in the display.
7. Press the Select button once. The display should read Save Defaults.
8. Press the Select button again. The display should read No.
9. Press the Left Arrow button once. The display should read Yes.
10. Press the Select button.
11. A few seconds should pass until the display reads Yes Is Selected.
12. Press the Online button twice to take the printer online while the display reads Idle. Your current printer settings are now saved and you are ready to proceed with returning the printer to its original factory settings.
6. Press the Left Arrow button until you read Miscellaneous in the display.
8. Press the Right Arrow button. The display should read Restore Defaults.
9. Press the Select button once. The display should read Factory Defaults.
10. Press the Select button again. The display should read No.
11. Press the Left Arrow button once. The display should read Yes.
12. Press the Select button. Yes Is Selected will appear in the display.
13. A few seconds will pass and the printers display should read Disk And Flash Sys Loader.
14. Your printer will reboot with the original factory settings and return to Idle.
Try a test print. Does the problem still exist?
10. Press the Right Arrow button. The display should read Custom Defaults.
11. Press the Select button. The display should read NO.
12. Press the Left Arrow button once. The display should read Yes.
13. Press the Select button. Yes Is Selected will appear in the display.
14. A few seconds will pass and the printers display should read Disk And Flash Sys Loader. Your printer settings are now restored to their original saved settings
Try a test print, does the problem still exist?
Sep 24, 2008 | Minolta magicolor 3100 Laser Printer
CANON iR C2105!! no display on the LCD!
try adjusting the contrast, open front door and look under the panel there should be an adjustment screw for the contrast, if it doesnt work I suspect it is the panel itself that is bad.
Sep 12, 2008 | Office Equipment & Supplies
Xerox Phaser  8500/DN Printer Logo
145 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
