Question about Rancilio Rocky SD Grinder without Doser - ROCKYSD
Grinder setting for the Rocky SD In setting the spacing of the grinders:where are the "grinders" located? (I am assuming that they are under the plastic cover at the bottom of the bean container-right?). How do you see the grinders- unless that cover has to be unscrewed? Thanks for your help Richard
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 13 Answers
Your assumption is correct.
But you do not have to (and you can not) see the grinder wheels to adjust the grinder. The numbers on the bean container indicate the level. All you have to do is to push down the release lever (on the right side) and then turn the container -- towards right for finer grindings (lower number) or to left for coarser coffee. Around 12 is usually suitable for espresso machines.
Willy
Posted on Jan 07, 2009
My Rancilio Rocky Burr coffee grinder w/doser is not grinding the beans they simply remain in the hopper
It is most likely that something is blocking the pathway to the grinder. As the Rocky is a direct drive grinder there is no gear that could be broken.
Try to remove the beans from the hopper and inspect the pathway, move the beans that might be under the 'disk'. If that is not working you might have to open the grinder;
  • remove all coffee beans
  • unscrew the three screws in the bottom of the hopper
  • remove the hopper
Now you can see the grinder wheel and tell if it is turning normally.
This might be a good opportunity to give the grinder a thorough cleaning.
Do not soak it in water, just a stiff small brush (e.g. a toothbrush) is the best tool. And perhaps accompanied by a vacuum cleaner :)
If you have been using very 'oily' beans for a long time they might have clogged the grinding wheels.
Good luck,
Villi
Mar 02, 2015 | Rancilio Coffee Makers & Espresso Machines
The grinder stoped grinding coffee
many grinders have resetable termic fuse, some of them require manual reset, so you should search for termic fuse attached to body of motor(open the grinder from bottom) usualy they are round black termofuses with red reset button.
usualy this happenes when we have loud music and we dont hear that grinder is on and he works long time.
Feb 05, 2011 | Rancilio Rocky Doser Espresso Grinder...
My Rocky is just out of the box yesterday and it seems to have jammed up. It still grinds, but I can't turn the top, at all. It is stuck, so I can't adjust the courseness. I can't see any obvious problem...
  1. stabilize the body of grinder
  2. provide block spin to be in release position
  3. get one 3 legged key for releasing oil filters
  4. put filter legs at upper holder of burrs
  5. start to release carefuly
be gentle at first, go forward and backwards to measure how much strength is required
Oct 31, 2010 | Rancilio Rocky SD Grinder without Doser -...
In the past I have cleaned the grinder blades 4 times however this time I noticed some of the grind mixture winds up on the counter under the main motor of the unit. When I picked up the grinder and shook...
Have you tried to hoover up the grinds from time to time, from the grinder blades. The coffee beans and ground can gather under the blades from over time. It should not be a problem though.
For better crema you may want to replace the blades.You should replace every 3-6 years. Rancilio Rocky Grinder Flat blades
May 07, 2017 | Rancilio Rocky Doser Espresso Grinder...
I disassembled the grinding blades and put it back together but now I can not get a find grind
HI
When you reassemble the removable burr assembly, you first must make sure that there are no grinds left in the main body's threads. These grinds will prevent the burrs from going any farther down. The burrs must touch and then back off to zero the grinder. Don't ever leave them touching though.
Nov 07, 2009 | Rancilio Rocky SD Grinder without Doser -...
I have a Rocky Grinder. The spring that pulls the
no, dont worry. Just return the lever by hand. Replace the spring and it will break again. It is a hassle to replace and not having it will not affect the function
Sep 19, 2009 | Rancilio Rocky Espresso Coffee Grinder -...
Rancilio rocky grinder setting
to get starting point you adjust burrs to touch each other. when they touch each other you have finest grinding, after you hear metal voice you turn back 3 dots and grind only for 1 dose. you check it, if it goes to slow, you go one more back and clean gruinder, THAN you grind 1 dose more. 2 or 3 times and you will get perfect grinding.
Mar 28, 2009 | Rancilio Rocky Espresso Coffee Grinder -...
I just got a used Rocky grinder. It works great but I read about
the grinding itself makes noise. if you have noise in empty spinning than you should consider changing bearings( 2 of them) in the motor.
during opening grinder pay attention to lower holder of burr which spins together with axis, try to be gentle with that part.
Jan 31, 2009 | Rancilio Rocky Espresso Coffee Grinder -...
Replacement portafilter holding fork
i will give you one web adress, i hope it is near you.
http://imp.mallcom.gr/coffee/coffee-rancilio.pdf
www.nuovaricambi.it
Jan 02, 2009 | Rancilio Rocky Espresso Coffee Grinder -...
Rancilio Rocky SD Grinder without Doser - ROCKYSD Logo
225 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
