I just replaced my LCD screen and when i turn my laptop on you can only see the screen faintly.
Unfortunately i dont think its the backlight because when i tried re-installing my old lcd screen to see if it was just the backlight for the new screen...it didnt work either. i am thinking it has something to do with the wires or something... any ideas?
i know the computer itself works well because when i connect my laptop to my tv screen i can see everything clearly.
Posted on Nov 15, 2008
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Sounds like the backlight may not be working
When i turn on my Acer laptop the screen goes black and i see faint files
Data cable that connects the motherboard to lcd experiencing rusty, do the replacement cables will make your lcd light back
Oct 26, 2016 | Acer Computers & Internet
Laptop screen is very dim. There is a very faint image. The LCD screen is brand new so that's not the problem
As per your description, it is probably your inverter which is faulty.
The inverter is an electrical device which 'lits' the LCD. Without the inverter and the bulbs it powers, the screen would be too faint to be seen correctly.
To test if the inverter is defective, just turn on your laptop in a dark space, then put a flashlight on the screen to see if you have a fainted display. If you can see something, it is the inverter which is defective and should be replaced.
If you are handy, you can also remove the screen cover to see if there is a neon like light which lits up behind the LCD. If you can see the light, it means that the inverter is just working fine and that the is with the LCD itself, but if there is no light coming from behind the LCD, then you need to replace the inverter.
Picture of an inverter.
Replacing the inverter:
1. After removing the screen 'cover', locate a small circuit board (usually below the LCD). Unplug the electrical cables and replace.
Hope this posts helps you.
May 16, 2011 | Computers & Internet
My hp laptop turns on bt the screen will not come on how can i fix it
As per your description, there are two possible causes. Either the LCD is out of order and needs to be replaced, or that the inverter is defective.
The inverter is a electrical device which 'lits' the LCD. Without the inverter and the bulbs it powers, the screen would be too faint to be seen.
If you are handy, you can also remove the screen cover to see if there is a neon like light which lits up behind the LCD. If you can see the light, it means that the inverter is just working fine and that the is with the LCD itself.
In case the inverter is working correctly, try to check the LCD cables. If all cables are well connected, your LCD has to be replaced.
May 09, 2011 | HP Computers & Internet
Screen blank
Look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the back-light stays off even when you open the LCD screen or turn on the laptop. The switch turns off the back-light when you close the LCD display to save the laptop battery power.
If that didn't fix it then there are 3 things that could have gone wrong:
1. Video cable connection from inverter to LCD got loose. To check this, follow instructions from step 3 on how to open the LCD and check if cable is fitted properly.
2. The video inverter is faulty
The screen inverter failure is very similar to the back-light lamp failure. In both cases the screen gets very dark and the image on the screen becomes very faint, barely visible under a bright light. If it's still under warranty, take it for a replacement. You can replace this otherwise - you can find the inverter under the screen, follow the procedure described at point 3 to open up the screen.
3. The LCD monitor is faulty
If it works on an external monitor most likely the LCD is faulty and needs replacement. If it's still under warranty, take it for a replacement. If not, you can do it yourself, it's pretty easy. Remove the rubber covers on the side of the screen, unscrew the screws take the plastic cover off, disconnect the video inverter and put in the new LCD after you connect the video inverter to it.
Feb 09, 2011 | Dell Inspiron 1525 Notebook
My lcd does not display anything when turned on
Feb 04, 2011 | Dell Latitude D810 Notebook
Compaq presario cq61 screen went dark but can still see window faintly through the dark sreen.
If no luck, try to remove battery and drain the power, then replace battery and turn on.
Jan 06, 2011 | Computers & Internet
No display on monitor
If the laptop acts as it would start and there's just no image, look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the back-light stays off even when you open the LCD screen or turn on the laptop. The switch turns off the back-light when you close the LCD display to save the laptop battery power.
Jan 05, 2011 | HP Pavilion dv6000z Notebook
Acer Aspire 5100 Laptop Screen Works Intermittently
Since you have video with an external monitor your lcd panel is going out.This is not hard to repair only costlyhttp://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Apr 06, 2010 | Acer Aspire 5100 Notebook
Blank screen
Oct 18, 2009 | Acer Aspire 3000 Notebook
Compaq presario 900 lcd not working, shows faint image
out put connection from the video card to the LCD monitor is loose or malfunctioning. check the connection that leaves the video card to the monitor, ensure its secure and clean, if still not working then its either the video card or the cable connecting to the LCD.
Dec 11, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
