Question about Sylvania DVC-800C DVD Player / VCR Combo
Green blinking "cst in" light/button
Neither dvd nor vhs work. the system turns on, but after a few seconds a green blinking "cst in" light starts blinking and everything shuts down. The dvd player will say "on", then "loading", then shut down just like the vhs. Any help would be appreciated. I've unplugged it over night, unplugged and replugged all the cables...EVERYTHING but the ONE thing that Iam not seeing. The green "CST IN" light remains flashing, even when the system shuts down. Once again, Thanks.
  • lucruz Feb 20, 2008
    I have the same problem, device will not stay on and "CST. IN" light flashes.
  • Anonymous Nov 22, 2008
2 Suggested Answers
SOURCE: CST In light is flashing green
I had the same problem. Aren't three-year-olds great? Mine had jammed several clothing tags into the VCR slot. Clearing them out didn't solve the problem, but I then took the outer case off (with power disconnected of course) and verified that there was no physical damage to the tape heads and that everything internally was clear. I put the case back on, and everything's back to normal.
Posted on Sep 13, 2009
P1102 reser counter
  • I take it you are refilling the toner cartridge...
  • Switch the printer off.
  • Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
  • Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
  • Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
  • Open and close the lid of HP printer once. The light will start blinking.
  • Press the green button. Your HP toner cartridge chip will be reset.
  • Apr 25, 2014 | HEWLETT-PACKARD Hewlett Packard P1102...
    Is not working more
    Jan 29, 2013 | HP DeskJet F4280 All In One Printer InkJet
    I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
    I found this on another website, most likely it is your power supply capacitors.
    1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
    2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
    3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
    4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
    5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
    6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
    Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
    1. DM Module Capacitors have FAILED.
    2. DM Module is defective.
    3. EEPROM Board failure
    4. Power Supply failure.
    Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
    I put a vhs tape in an the vcr turns off by it self a green light keeps flashing by where it says cst in. I have a Hitachi DVD/VCR COMBO DV-PF2U. I also can not get the tape out
    Unplug the power supply for thirty seconds and plug back in, this will reset the processor and might eject the tape. If this fails the next step is remove the top of the combo unit this will give access to the vcr tape, if the tape is spewed in the machine and wrapped around the video head and other mechanical parts use scissors to cut the tape and carefully removing the particles, press power to eject the tape for normal operation. However! if the vcr tape is okay, there may be a loading problem, broken drive belt, bad idler assembly to name a few, this is where a technician will be needed but may not justify cost.
    Jan 23, 2011 | Hitachi DV-PF2U DVD Player/VCR
    When we turn the power on iit only stays on a few seconds then turns off with the cst.in light flashing.. what does this mean and what can we do to fix it?? tks
    I had the same problem. We watched a DVD, and the unit worked fine. We went out for ice cream, came back, and decided to watch a VHS. Instead of taking the VHS, the CST.IN light flashed and the unit cut off after a few seconds. We didn't have a VHS in the unit at the time. After cutting the unit back on several times without success, I looked online for solutions. One person said to hit 'eject' 5 times in a row, but that didn't work for my unit. Someone else said there was a lever inside near the power button that ejected the VHS, so I checked that out next. I washed and dryed my hands well, and used my finger to jiggle the white lever. Then I saw that the tray that the VHS sits on wasn't all the way forward, so I gently pulled and pushed it. I'm not sure which of the two actions worked, but my light is now a steady green and my unit is working fine now. I am so glad because we've had this unit for almost 10 years now, and I really didn't want to have to buy a new one! Good luck!
    Jan 17, 2011 | Emerson EWD2202 DVD Player/VCR
    The cst.in function on my dvd/vcr is blinking and because of it, i can't work my dvd/vcr. What can i do to fix the problem?
    Jan 16, 2011 | Emerson EWD2202 DVD Player/VCR
    Jan 06, 2009 | Sylvania SSD803 DVD Player/VCR
    Se-d1 will not boot
    escient music server...light blinking red...
    cant turn on system...
    tried resetting...nothing
    tried turning system off..for a hour or two...nothing..
    juse blinks will not respond to anything...
    any ideas.
    Jun 28, 2008 | Digital Products Escient SE-D1 FireBall...
    CST.IN Light
    Put a tape in and eject it. It will then work. Just had this problem. CST IN means the VCR thinks it has a tape in. Trust me... Very fixable.
    Jan 19, 2008 | Hitachi DV-PF2U DVD Player/VCR
    Sylvania DVC-800C DVD Player / VCR Combo Logo
    Top Sylvania Televison & Video Experts
    matt martin
    matt martin
    Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
