Question about Kenmore Elite 45986 Front Load Washer
Washer won't spin
I have a kenmore elite top load washer that has stopped spinning. All my clothes are just sopping wet, and have no idea what to do next. This is an older machine, 2003 model, not sure what model # exactly. The troubleshoting guide that comes with the washer offers no help to the issue. All it says is to not use an extension cord and to make sure the lid is closed. I'm just getting frustrated with this and would like some help.
  • rgcmhunt Nov 17, 2008
    The washer will not spin and the clothes have alot of water in them.
  • 370 Answers
Check your drive coupler between the motor and the transmission. You can check this by leaning the machine back and checking with your hand. If it wiggles loosly back and forth its no good. Another sign is rubber pieces all over the floor under the machine. If that seems to be tight then you most likely have a bad clutch.
Posted on Nov 18, 2008
Kenmore washer model 15862400 leaves clothes really wet, why
Possibly a blockage in 1 of the outlet pipes or pump causing water not to drain out properly.
Dec 22, 2012 | Kenmore 24032\24036 Top Load Washer
Clothes still wet after cycle is over
Be sure drain hose is not kinked and no higher than the top of washer to drain pipe. Remove clothes as soon as it stops spinning
Jun 23, 2010 | Kenmore 23822 Top Load Washer
I GOT ERROR CODES F32(LD),F70(OL).HOW I CAN FIX IT?
Kenmore Elite Top load washer machine. Error "OL" does not spin fast enough. Clothes are still very wet. I have checked the machine is sitting on even surface and well balanced from all sides. Any idea(s) ???
Jun 30, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washer sometimes leaves clothes sopping wet - then the next day O
you can remove the bottom access panel to get to the drain pump. there might be something in the coin trap.
Jun 24, 2009 | Kenmore 44072 Front Load Washer
Kenmore Elite Washer 110.24992300 spin problems
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
Clothes coming out of washer still soaking wet
is it a kenmore top load?if so the motor is not kicking in to 2nd gear for high fast spin,does it have a speed control on the head?are you using it on the reg. wash cycle?-mike
Apr 18, 2009 | Washing Machines
Kenmore elite calypso top loader clothes still wet after spin
more than likely the machine has a bad clutch or motor.. in most cases it is cheaper to just buy another top loader.
Mar 06, 2009 | Kenmore 24032\24036 Top Load Washer
Series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Mar 20, 2008 | Kenmore 24622 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
49 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
