Question about Canon Office Equipment & Supplies
I loaded both new black40 and color 41 on my IP 1800. Can't get the color recognized as new full one, say low. How to get this done??
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
tryt to unset the cartridge and then
clean the socket of the cardtrige
wipe with cloth use alcohol
Posted on Nov 15, 2008
    Genius:
  • 1,913 Answers
Check u fix xartridge in right position also try after refix again .check there is not any plastic tape on it.
Canon ip 1800 full tank
Reseter Printer Canon IP1880 To reset manually Ink Full Tank, try these methods :
1. Turn on Printer Canon iP 1880
2. Push and Hold resume button about 2 minutes
3. Release resume button
4. Printer will back in normal again
5. Then use the software.
6. Good Luck friend
7. If you want this permanent, Please Download Reset Tool
8. Reset tool support Canon iP2500, iP 1800, iP 1100
For more details visit the following link
http://indoresetter.blogspot.com/2009/04/reseter-printer-canon-ip1880.html
Feb 09, 2011 | Canon Office Equipment & Supplies
Changing print color cartridge
The cartridge you have change are did not much or not compatible with your printer. You just buy a cartridge with the same brand of your previous cartridge that used and to make sure that your printer are recognize it. Because some compatible ink are cannot be recognized by other printer.
Jun 03, 2010 | Canon PIXMA MP160 All-In-One InkJet...
My Canon IP 1800 cannot recognized the Black ink
It sounds like the electrics on the back of the cartridge have failed, replace with a new cartridge, and away you go.
Jun 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
My cannon printer pixma ip1800 cannot detect ink pls help me...
If after you install the cartridge you get a yellow light and error message:
“The following may have run out of color. The function for
detecting the remaining ink level will be disabled since the
ink level cannot be correctly detected. If you want to
continue printing with out this function, press the printer’s
start button. Canon recommends using new genuine Canon
cartridges in order to obtain optimum quality.”
Do not click “cancel printing”. Press printer start button
to start printing. This action will bypass the ink level
detection from the recycled cartridge. It will not damage the
printer! With a recycled cartridge this action needs to be
done one time.
A full recycled cartridge ink level may not display correctly.
It may show empty.
If you want to check the ink level, you can do a “Nozzle
check” by follow the directions below:
Go to menu File select print click on “Property” click
on “Maintenance”
Click on “Nozzle check” to print out the color check.
Click on “Cartridge Alignment” to align the cartridge.
See pictures for above process at Inktelligent ip 1800 topic
Also the refills refered to above are at the IP 1800 inkfilling page
Sep 23, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Oki 3400n
First thing to do (if not yet done so) is to access the printer through the web admin interface by typing the printer's IP address in a browser. This gives a lot more information than the blinking lights.
The Status page of the web admin interface may say "toner low" or "toner empty" or "error on toner sensor" and that will tell us which color cartridge to handle.
Note that the OKI 3400n has the annoying tendency to fail when loading in a new toner cartridge: a color is low or empty, you put in a new color tube and then the printer says error on that very color! This can be fixed by pulling out the drum of that color (the drum is that entire block which includes the color tube and the container below it; avoid touching the shiny green roller), and lightly tapping on that drum to evenly distribute the new powder inside the container.
You may have noticed that the once the color tube is loaded in, what it does is to empty its content into the container below. Which means that it's no use swapping color tube once it's installed because the color tube is empty by then, and is just kept there to prevent the ink powder from spilling out of the container. The caontainer itself has 5 electrical contacts on its side used to measure the powder content and the lifetime of the drum.
Viet
Aug 29, 2008 | Office Equipment & Supplies
Problem with the color - Canon Pixma ip 3000 Ink Jet printer
go 2 printing preferances and make shore all your setting are on normal or higher and try again
Nov 28, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
15 people viewed this question
old marine
old marine
