Question about Plumbing
Handle of the danze faucet keeps shutting off. I can't tighten
Shuts itself off.
    President:
  • 2,976 Answers
Directly under the handle, you should find a ring that you can tighten, to eliminate slipping.
Posted on Feb 17, 2009
New Danze D308340 faucet leaking under handle. Can't remove the capto get to retainer screw, which needs tightening.
is the capp colored red/blue? if yes, take a picky pointy knife (lmao) and peel it off,pick it off,The leak is probable just the adjustment under the handle, the fawcet originaly came with a tiny spud wrench (made like a 2 pick pitch fork, if you cant find one, i use a pair of channel locks pliers, but first wrap rubber glove or cloth around the top of fawcet so you dont scratch it.How old is this fawcet?
Nov 12, 2011 | Plumbing
My Delta type kitchen sink handle is loose and keeps shutting water off. I have to turn it up a lot to keep it going. I could remove Red / Blue plug and do not know what to do beyond to tighten it?
Inside the handle of a Delta kitchen sink faucet is a small setscrew. You need an 1/8th inch allean wrench or Delta faucet tool to lossen the setscrew. Rotat the screw about 3 full turns counterclockwise, this should be emough to remove the hnalde. Under the Delta faucet handle is a white plastic ring with four notches. If you have a Delta faucet tool, you place it in two of the notches and slowly turn the ring clockwise to tighten the Delta ball assemby. This will keep the handle from moving by itself. If you do not have Delta faucet tool, use a pair of needle nose pliers in stead.
Oct 12, 2010 | Plumbing
Bought a home, main kitchen faucet is a Danze NSF
I'm not familiar with a NSF 61/9, but I've used several other models. I believe these are all ceramic disc valve. They almost never wear out. If you remove the handle and the trim cap or bonnet, there should be a nut or adjusting ring you can tighten. Don't over do it. The handle give you quite a bit more leverage than the small tap when it is removed. Here is Danze web site and you can look up your exact model number and see a exploded parts list: www.danze.com
Jul 12, 2010 | Danze Plumbing
My danze kitchen faucet is loose and wobbly i cannot seem to tighten it i no longer have my installation insructions. please help. how do i do it?
You can see the installation manual here:
http://www.ajmadison.com/ajmadison/itemdocs/D403412-chrome_manual[1].pdf
Hope this helps! Remember to rate me, thanks.
May 26, 2010 | Danze D403412 Melrose Single Handle...
Faucet is leaking from the cold water line inside the faucet. it is a danze lazio pull out kitchen faucet
Hello
First shut off water to faucet.There should be a allen screw that holds the faucet together near the top back of the handle,lossen this and pull top off.
Next take some pliers and tighten down the lock nuts to compress the washers,do this gently.
Reassemble,water should stop leaking.
Mar 30, 2010 | Danze D403412 Melrose Single Handle...
How to get the handle off , it is very loose
Should be a little round button to pry out at lower part of handle itself, and likely an Allen key behind it to loosen off and remove, or tighten to snug up handle.
Jan 21, 2010 | Danze D403412 Melrose Single Handle...
My Danze kitchen faucet is a single lever with spray attachment. The lever does not catch (stay at a desired position). I have tried adjusting the screw under the decorative plug but not luck. Therefore I...
That screw just hods the handle on. If you partially unscrew it, you can remove the handle. Inderneath it there will be a large nut holding the faucet together.
It is possible that the nut just needs to be tightened. It is also possible that the stem/washers etc are worn and it needs to be rebuilt. (replace the stem/washers)
When they get worn things loosen up a bit.
Don't forget to shut the water off under the sink first.
Aug 23, 2009 | Plumbing
My Danze Anu Kitchen Faucet
Sounds like you have hard water.  You need to change the inside of the facet.  before doing anything make sure you CAN get the parts for you facet.   Danze are not very expencive you might just get a new facet.  If this is a hard water problem you might want to buy a moen facet with a life time warrinty.  More money but free replacement parts.
Apr 04, 2009 | Plumbing
Handle lowers itself
Remove the handle with an allen wrench. There is a grey retaining ring where the stem is coming out of the housing. Tighten the retaining ring. This will solve your problem. I'm shocked that it's not leaking as well. You might need new washers as well but try tightening the retaining ring first.
Mar 19, 2009 | Plumbing
Plumbing Logo
690 people viewed this question
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
