We can't get the power to come on.
We have plugged it in and the power will not come on after we push
the button on. This unit comes in four pieces. Stero & amplifier,
tuner & sound processor, stero cassette deck, compack disk changer
1994. We have power up to the amplifier.
  • Anonymous Dec 10, 2008
    i have pluged in the power cord on my sharp xl-mp60 pushed the power button and no power
    Scholar:
  • 146 Answers
Make sure that everything is plug into the right spot. If the amp comes on and nothing else, I will check the power cords. Also check the power buttons for each unit and make sure they are on. Also listen for a click sound from the amp when you turn it on. You will here it about 2 to 7 seconds after you turn it on with the main power button. If you do not here it, then you have a problem with the amp. One of the channels is bad and you will need to take to a repair shop for repair.
Posted on Nov 17, 2008
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
While playing my unit we had a brief power outage. When the power supply returned the " PROTECT PUSH POWER " message comes on. Is there a button that I can push to reset my unit-LBT-X50 .
Your sound system may have a circuit breaker.
Check the rear of the sound system for a circuit breaker that has popped out, Then push it back in.
It may be labelled.
  • circuit breaker
  • protect push power
Otherwise unplug your unit from the wall and wait 5min before you plug it back in, then press the power button on the front of your system and your remote control.
I hope this helps
MobileJB
Jul 13, 2011 | Sony LBT-LX50 CD Shelf System
I have a cd stuck in my cd player there is 2 little metal pieces holding it in there and I don't know how to release it. when I push the eject button it says no disk but there is a disk in there. can you...
Had the same problem, I removed the unit from the car took the top off the unit and pushed eject after I plugged it back into power I never put that cd back into the unit. The two bars come down as you slide the cd in. If you would like to attempt this good luck and hope it works out, you may have to fiddle with things to release the cd try it a few times with another cd before you put it back together.
Apr 07, 2010 | 2005 Chevrolet Malibu
I have a Sharp portable room air conditioner model CV-P10NC. The power plug RESET button and TEST button will not click in order to check out the power plug as the unit will not turn on. They did test O.K....
the fused9G.F.C.I.) cord you speak of is probably the G.F.C.I. built onto these units by design, can you or someone you know get access inside the unit and :Hot-Wire" the units cord and,bypass the power cord ( Just To Test the Unit)and see if it stays operational then replace bad unit cord if this is it.
Sep 12, 2009 | Heating & Cooling
Wont turn on
What power supply are you using? You need the older 6volt unit. Next, look down inside where you plug the power plug in. Many times the tip of the plug will break off and get stuck down inside the hole - if you see a piece of yellow plastic down there, you need to remove it with a small pointed hobby knife (Xacto). After you remove that, then try plugging the power supply in and wait a minute. IF it doesn't automatically come on, THEN push the power button. Okay?
Aug 14, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
Plug into car an power light (green) comes on at bottom unit but the screen does not come on. Yes, I did push the power button on top of unit and nothing?
I found tomtom internet services and followed their instruction to charge the unit for 2 hours and then restart by holding down the power button upto 15 secounds.
Jul 28, 2009 | Tomtom GPS
Problems with Magellan Maestro? 4040 GPS power connection
I also have the same problem - the yellow power jack has broken connections. I fixed it by soldering it back. In my unit, the connection pads under the external power jack were intact and I was able to solder the jack easily. The audio out jack nearby has also come-off the PC board, along with the pads. I am not able to re-solder these back. Since the audio jack is part of the speaker circuit I have lost the text-to-speech function!
Hope you are able to fix yours.
Dec 17, 2008 | Magellan Maestro 4040 GPS Receiver
Hoover Flair S2220 cleaner w/power nozzle disassembly instructions
With the head flipped upside down, take a flat tipped screw driver and carefully pry up the rollers on the front the head. Underneath, you'll find a screw. Remove the screw under each roller, and the front cover will come off with ease. The rollers are just friction fit.
Aug 16, 2008 | Hoover U8185-900 Upright Vacuum
Creative Zen Sleek Photo 20GB
It's probably too late for your nees but for future users, push a pin into the rest hole on the bottom of the player while AT THE SAME TIME holding down the play and power buttons. Yes, I know you need three hands to do this. That should bring up a recovery screen Try "Clean-up" on that screen.
Oct 21, 2007 | Creative Labs Zen Sleek Photo MP3 Player
Toshiba d-r2
If it's 7071, shut the unit off by holding the power button until the time is displayed (instead of the error code). Unplug the unit. When you open the case, you will see a white plastic piece at the front of the dvd drive near the silver plastic hinge on the face of the unit's dvd opening. The white plastic piece slips in the groove of the hinge to stop the units dvd door from being opened while the drive is engaged. Push the white plastic piece in toward the dvd drive; sometimes the mechanism gets sticky. Plug the unit back in and press the power button. This may solve the problem Hope this helps.
Aug 06, 2007 | Toshiba D-R2 DVD Recorder
196 people viewed this question
 Grubhead
Grubhead
