Question about Classic Electronics DVC 100A Digital Camera
Busy My camera shows that it is recording but when I try to play back either movies or pictures, it comes up "Busy"
0 characters
1 Points
Canon pc 1331
I think your card is damaged. Try connecting to your computer and check available space. Take a backup and format it from your PC, check if it is formatting completely.
If the card is not Class 10 you will also have problem recording movie from a camera. You need a high speed card to record video.
Apr 08, 2014 | Canon PowerShot Digital Cameras
Movie shooting auto stops
Make sure your SD card is Class 10. If not slower card will cause camera to go in busy mode while recording videos.
Apr 07, 2014 | Canon EOS 600D Rebel T3i Digital Camera
Camera wont switch on praktica dcz 8 lm busy light comes on 3 seconds then off and nothing after that
took the memory card out and then turn on the camera. Now see the busy keep coming or its gone. If not showing busy any more then format the memory card and then try to turn on the camera with inserting the memory card. Thanks.
May 23, 2012 | Praktica SlimPix Digital Camera
Movie recording stops after 15 seconds. Memory card has been formatted and the screens shows a busy icon
I had the same problem except it stopped after 31 seconds and the card was not just said busy. I changed the card and the new card kept on recording fine. I eventually stopped the recording with the new card after 2 mins as i did not want to test for the full 43 mins.
Jan 24, 2010 | Canon PowerShot SD960 IS Digital Camera
A little hand with a no sogn through it and the word busy
The busy sign generally comes when:
Image is being recorded to the memory card, or playback mode is starting up.
It possible your memory card is full, please therefore down load your pictures and try again after erasing and reformating the memory card..
Alternatvely, please also reset all the camera ands menu settings to default.
Hope it works for you.
Mar 02, 2009 | Canon PowerShot A530 Digital Camera
Cannon EOS Rebel XS shows busy display stopped working
Just got a brand new camera. Played around with it a few nights to learn all the parts and buttons. Went to a concert tonite. While waiting for the show I took many test shots to see how the camera would work under these contiditions. Used a 75 to 300 Cannon lens. I had just got the settings about right when the show started. All of a sudden the display went dark and "busy" flashed in the view finder. But it would not take any more pictures. Taking the battery out and removing the sd card did not help. The auto focus and flash still worked but nothing else.
This camera is going back to the store if I can't get some help. PLEASE............. vj
Dec 05, 2008 | Canon Digital Rebel / EOS-300D Digital...
Pentax W10 won't download videos only still pictures
Movies need MPEG decoder and a movie program
If you are in XP/Vista try reading the file in MovieMaker
go to Start/programs/accessories
Jan 14, 2008 | Pentax Optio W10 Digital Camera
Can you try with a new or different CF card,if there is read and write error into CF card camera will gives message "busy".
Dec 06, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Sony F55 Recorded Display
The filename (e.g. DSC0012.jpg) shows the image number, the filespec shows the date and time recorded. Most software will give you document info about resolution of the image. I wouldn't worry about what the battery status was when the shot was taken or how many other images were on the Mstick. I guess I'm not sure what you need.
Sep 11, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Classic Electronics DVC 100A Digital Camera Logo
Top Classic Electronics Digital Cameras Experts
Are you a Classic Electronics Digital Camera Expert? Answer questions, earn points and help others
