Question about GE Security Simon 3 Wireless Home Security System
What resistor is required?
Just received my new Ge Simon XT and the siren (13-950) should have come with a 4.7k resistor. I want to buy one but turns out I dont know what watt I need, can you help?
  • etiger1 Feb 09, 2009
    Do you just wrap the resistor wire around the wire coverings or do you strip a section of the wire covering off and connect the resistor directly to the copper?
    Also, what size wire should I use to run from the panel to the transformer and the panel to the siren? Is 20 gauge ok?
  • 4 Answers
The 4.7k ohm resistor (1/4 watt is fine) is only needed if you want the siren to be supervised (i.e., the alarm to go off if someone cuts the wires). If the siren is inside your premises (i.e., in the house or the garage) and therefore unlikely to be attacked, you don't need the resistor. (Hardware supervision is disabled by default on the Simon XT, so if you do wire the resistor, it won't do you any good unless you enable hardware supervision in System Configuration.)
Posted on Jul 29, 2009
  • 4 Answers
If the resistor is used on a detection circuit, any standard 1/4 watt resistor will work fine. The function of such resistors are to be placed at the end of the line (most distant part of the detection circuit) and the purpose is simply to prevent a undetected short path in the line from going undetected. Such a circuit allows for the detection circuit (also called a loop) to activate both on a short or open in the circuit.
BIll
Posted on Nov 16, 2008
Hello. there seems to be a beeping noise coming from the control box itself and it says to check status, but i'm afraid to push anything. thank you
Troubleshooting a GE Simon XT: Clear Errors and Alerts ...
? 3:06
https://www.youtube.com/watch?v=AtOCuthlsTo
Oct 3, 2011 - Uploaded by LiveWatch Security
Troubleshooting a GE Simon XT: Clear Errors and Alerts -Wireless Home Security ... Many times the Simon XT panel willbeep to indicate there is something ... How do you turn off the warning beep when you turn on alarm? I find it very useless and annoying. Can't seem to find a way to turn that feature off.
My Simon XT is beeping every 4 hours. How can I stop it ...
help.livewatch.com/.../20399861-My-Simon-XT-is-beeping-every-4-ho...
Aug 28, 2011 - If your panel has been beeping throughout the day and you want to turn off ... Scroll down on the Simon XT until you see "System Programming".Missing: control ‎hello ‎control ‎box
Jan 11, 2016 | GE Security Simon Xt Wireless Control...
Hi there, i have a Simon XT alarm system and i want to delete a sensor or reinstall it - i took it off the window when replacing them and now th system keeps bleeping to tell me it's been tampered
Try these 2 sites:
http://search.aol.com/aol/search?&s_qt=sb&q=Ge+simon+xt+service+manual&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
Jan 15, 2013 | GE Simon XT Wireless Home Security System
Need an extra interior siren
lowvoltagesupply.com
send them an email and they can help or 866-784-2511
Nov 14, 2012 | GE Security Simon 3 Wireless Home Security...
I have a Ge Simon Xt Alarm and i want to hook up a external siren(part 13-950)I received a 4.7 resister with the siren and 50 ft of wire.How do you attach the resister between the red and black wire?Do...
Wire nuts are ok if the siren is indoors. Gel filled connectors are better if you are mounting the siren outside because they keep the connection from corroding. The resistor needs to go between the two wires you are hooking up. The color of the wires you will are are generally red and black. If your siren has a yellow wire, you can use it instead of the red to get constant siren instead of the "whoop, whoop, whoop" sound that sirens usually make. Putting the resistor at the siren will make sure that it is supervised. That means that if someone cuts the wire going to the siren, it will alert you at the panel. If you put the resistor at the panel, nothing will happen if the wire is cut.
May 19, 2011 | GE Security Simon 3 Wireless Home Security...
Just bought a DSC SD 15w siren has six wires. Using a GE Simon XT panel for fire and burglar alarms. Siren Has 6 wires. two red two black and two yellow. Which do I hook up? Do I need some kind of...
hook up red and black wires. Red wires to HW1&2 DC Out Terminal. 1 Black wire to HW1 and 1 Black wire to HW2. Resistor 47 Ohm resistor not needed unless siren supervision is turned on as an option. If needed , should go at the speaker, across red and black wires.
May 11, 2011 | Siren Dsc Sd 15w Ulf Surface Mount Siren...
Hi! Just had ADT install security system and it is a Simon XT. Door units, motion sensors and control unit are in house. They also put a motion sensor in garage, which is detached. My understanding is...
My understanding is that GE does not produce a wireless interior siren any longer. So if yo want to get a siren in the garage a wire will have to be run from the Simon 3 to the location in the garage where you would like to place the siren. PS ADT will not run wires to a detached garage. GL
Nov 16, 2010 | GE Security Simon 3 Wireless Home Security...
How do I turn system beeps off for sirens
My problem started when the electricity went off so now everytime I open the door the siren goes off. I don't have a manual so how can I get this to turn off.
Jun 18, 2009 | GE Security Simon 3 Wireless Home Security...
How do I replace the battery in my Simon XT security system
Here is a very easy to follow video tutorial that may help you.
You can get a replacement battery from here
Simon XT GE Security Security Alarm Battery 6V 1 2AH
Mar 08, 2009 | GE Home Security
GE Security Simon 3 Wireless Home Security System Logo
606 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
