Question about Whirlpool Duet GHW9150P Front Load Washer
Flashing F11 The machine stops and flashes F11 and I can't get the door open or get it to drain. Let me know what you suggest. Thanks
  • ncf705 Nov 16, 2008
    I have the same problem. In the middle of the last two loads, the cycle stops and an F and H flash alterately. I have had my machine for over three years with no problems.
    Genius:
  • 1,028 Answers
Rmove top and ck connectors to rear mounted main control module f11 is code for communication problem between upper main control and lower motor control..most likely upper control problem tech sheet behind lower panel
Posted on Nov 16, 2008
  • oldfixer Nov 16, 2008
    to ncf705 yours is different problem different solution most likely yours is a bad flow meter this is under top left side small round object with 2 small hoses and blue wires attached may try tapping it to verify but even that may only temporarily fix it other possible causes may be siphoning due to low drain hose end or drain hose too tight in standpipe also ck fill hose screens in fill valve
Kemore Elite Front Load washer was flashing F11 and i repeated the drain, spin cycle several times. now flashing dL and F . The door is locked so I am unable to remove wet clothing.
Try lowering the drain hose onto the ground and see if the water comes out. Turn off at the wall and then back on again a few minutes later. See if the door unlocks this time. Most front loaders wont let you open the door if it thinks its still full of water.
Mar 21, 2017 | Washing Machines
F11 code flashing-washer stops
hi!!!!
try to unplug it end then check the control timer if it is broken !!!!
or open it if you know and fix it may be the spring that pull back the pause botton
might be broken go check it?
Sep 19, 2008 | Kenmore Elite 45986 Front Load Washer
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
Problem with AWO3561 wash machine red door light flashing
there is a valve for the door lock if this goes it thinks the door is open and shuts down thinking the door has been opened if the feed pipe become blocked the water pressure sends air pressure to the switch when water is added. spin/drain setting it don't use this sensor switch, but on filling up it will. its usual down to a blocked pipe , or a leak in the line. sometimes it can be the switch, the pipe is located at the bottom around 2 inches from the bottom and the feed wire goes to a sensor , take the pipe off and blow down it best to have some water in the bottom of the drum, so suck and blow on the pipe to loosen anything blocking the pipe. switch don't blow or suck on this as it can damage the sensor. if the sensor is at fault you can only replace it as the valve inside for the switch if you use anything it will pierce the valve , hope this helps you.
Jun 24, 2017 | Washing Machines
My Hotpoint Aquarius WF430 1300 doesn't complete its cycle, it stops after the wash & doesn't go on to the rinse & final spin. It seems to "freeze" after the wash is finished as the lights remain...
If your lights are flashing, use these codes to pinpoint the error.
These codes are reading from the top neon down.
F01....OFF, OFF, OFF, Flash, OFF.
F02....OFF, OFF, Flash, OFF, OFF.
F03....OFF, OFF, Flash, Flash, OFF.
F04....OFF, Flash, OFF, OFF, OFF.
F05....OFF, Flash, OFF, Flash, OFF.
F06....OFF, Flash, Flash, OFF, OFF.
F07....OFF, Flash, Flash, Flash, OFF.
F08....Flash, OFF, OFF, OFF, OFF.
F09....Flash, OFF, OFF, Flash, OFF.
F10....Flash, OFF, Flash, OFF, OFF.
F11....Flash, OFF, Flash, Flash, OFF.
F12....Flash, Flash, OFF, OFF, OFF.
F13....Flash, Flash, OFF, Flash, OFF.
F14....Flash, Flash, Flash, OFF, OFF.
F15....Flash, Flash, Flash, Flash, OFF.
f16....OFF, OFF, OFF, OFF, Flash.
F17....OFF, OFF, OFF, Flash, Flash.
F18....OFF, OFF, ON, OFF, OFF. Fault on control board, check Eeprom.
these are the codes and this is what they mean
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
also try checking this manual
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WFseries_19504110305_Jan05_book.pdf
Mar 05, 2010 | Washing Machines
Clean light flashes constanly. Won't clear out to start new cycle
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 03, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Hotpoint ultima wt741
f11 keeps flashing door won't open
Sep 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
Kenmore he2 front load washer
remove bottom panel open pump port and ck for foreign objects lean washer toward rear wall this will help help keep water toward rear and reduce flooding floor might try opening door first and dipping out as much water as possible with bottom panel removed reach up to lock area there is a tear shaped plastic peace pull it down to release door
Jun 02, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
135 people viewed this question
Dan Webster
Dan Webster
Sal De
