Question about KitchenAid 24 in. KUDP01IL - Multiple Color Built-In Dishwasher
Milky liquid residue on washed dishes
Tried hotter water, less detergent, cleared bottom if knife keeping sprayer from rotating. This is 11/2 yrs old and we are very disillusioned with the brand
  • dehand Nov 23, 2008
    I'm searching for an answer for the same issue. It's not anything to do with hard water or spotting, it's almost as if dirty water is not draining. The dishes and the inside of the unit are coated with a milky white substance.
  • activechick1 Nov 30, 2008
    I have the same issue and have tried everything to switching detergents, Hot water, rinse only etc....please help.
  • 833 Answers
This sounds like hard water spots.  Use Jet Dri or a similar product to reduce it. Use the recommended amount of detergent.
Posted on Nov 15, 2008
Why does my LG top load washer have mold in the detergent area?
This is a common issue, they make cleaning products to remove this gunk. Hot water and bleach will kill it as well.
Feb 01, 2017 | LG Washing Machines
How do I stop baumatic dishwasher leaving a sticky residue on glasses and other articles on the top shelf?
Make your dishwasher more effective with these quick tips: 1. Check the sprayer arm. When I opened the dishwasher door during a wash cycle, I learned that some of my utensils are too tall, and they blocked the sprayer arm from rotating. Problem solved! Also look at the holes on the sprayer arm to make sure they are not clogged. Use a toothpick if you need to dislodge anything.
2. Check the drain. Look inside the bottom of the dishwasher and remove any food or objects from the filter. Run the garbage disposal to clear it out before turning on the dishwasher since they share the same drain.
3. Don't overuse detergent. It's a mistake to assume you should always fill up the detergent cup. Check the manual and your detergent. On mine, filling it to the first line (about a third) is enough. Too much detergent can leave residue and etch your glasses.
4. Check your water temperature. If it takes a long time for the hot water to reach your kitchen sink, that means the dishwasher isn't getting enough hot water at the beginning either, and that makes it harder to wash away the food particles and grease. If you need to, turn on the dishwasher after you've used hot water at the kitchen sink.
5. Clean the inside of your dishwasher. Grease, detergent residue, and calcium deposits build up inside your dishwasher. You can use vinegar to wash them away. On a regular basis (every few months or so), run a wash cycle while your dishwasher is empty. Don't use detergent, but turn on the dishwasher and let it run for a few minutes until water starts to fill up the bottom. Then add one or two cups of white vinegar to the water and let it finish the cycle.
Sometimes using a dishwasher is an experiment in finding the right combination for hard or soft water, the detergent, and a rinse aid.
Best of luck
BBBBB
Nov 30, 2014 | Baumatic Dishwashers
Soap covered dishes?
Use a liquid or gel detergent. Make sure the water entering the unit is at least 120-140?F and the water pressure is not compromised in the house. Also make sure the unit's sprayer arms can freely move.
Sep 06, 2012 | Frigidaire Gallery Series FGBD2451KF Full...
The dishwasher detergent dispenser is gumming up and dishes are not as clean as they use to get.
Purchase a dishwasher cleaner tablet(s)
You may need to remove and back flush the spray arms
Ensure there is nothing blocking the water intake in the bottom
Your issues seems to be low water flow. These are the simple and inexpensive solutions try the first.
Sep 21, 2017 | Kenmore Dishwashers
My Kenmore UltraQuiet 8269644 has been performing poorly. Have cleaned various filters and traps. The spray bars tend to clog with food refuse and now it is leaving a white film on dishes - either...
Your sprayer arms may be clogged.
The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
Also, dishwasher detergents need HOT water, so be certain the water is at 140 degrees. Make sure your detergent is fresh!
Finally, the bottom of the door INSIDE the washer often get covered with gunk. Be sure and gently wash the bottom of the door INSIDE. You can open the door, spray some window cleaner on the bottom and then gently brush away the 'gunk.' Rinse with hot water from a pitcher or your sink sprayer and this can eliminate some of the residue that is showing on your dishes.
I hope this helps. If it does, please come back to Fixya and rate my answer
Jun 12, 2011 | Dishwashers
I have a hotpoint HDA 3700 dishwasher that is about four or five years old. I has stopped rinsing thourghly, do you have a suggestion where I should start looking?
Make sure your water temperature is hot enough to dissolve the detergent, because the unrinsed residue could be undissolved detergent. If, however, it's food residue, you probably need to check your sprayer arms. The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
I hope this helps. If it does, please come back to Fixya and rate my answer.
Jun 10, 2011 | Hotpoint 24 in. HDA3700G Built-in...
The water supply arm for middle sprayer is not held in place by clip that is attached to bottom of dish rack. Does not meet up with water outlet on back of washer and also impedes movement of sprayer arm....
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 11, 2011 | KitchenAid KUDS40CVSS Builtin Dishwasher
Residue on dishes/glasses - Hard water? How to clean?
heatman101
Mar 01, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
My dishes come out with cloudy film on them.
From Whirlpool:
*Film is due to either etching or silica film. Silica film is a milky, rainbow-colored deposit and etching is a cloudy film. Sometimes there is a water/chemical reaction with certain types of glassware.
o Silica film and etching are permanent and cannot be removed. Both can occur in any automatic dish washing machine and result from a water/chemical reaction with certain types of glassware. They are caused by some combination of:
+Soft or softened water.
+Alkaline washing solution.
+Insufficient rinsing.
+Dishwasher overloading.
+Heat of drying.
+Long/hot cycles.
To slow the down this process:
*Use a minimum amount of detergent but not less than 1 tablespoon per load.
*Use a liquid rinse aid.
*Under load the dishwasher to allow thorough rinsing.
*Do not use heated drying.
*Wash glasses by hand.
Do the following:
1. do you use a rinse agent
2. clean out the drain.
3. if you have a food disposal, run hot water through it and turn it on to clear it out before you turn on the dishwasher. The dishwasher drains into that sink. If you notice food or dirty water backing up into you sink when the dishwasher is draining, then the sink could have a minor clog and is backing up and being re-sprayed onto your dishes.
Source(s):
Use SANIVAC to clean lime deposits and extend the life of your dishwasher. If you have heavy water.
Run your dishwasher empty and pour in a cup of bleach and a cup of white vinegar to get the residue out.....run a regular cycle.......How hot is your hot water tank set on? The hotter the water the better a dishwasher washes and rinses, be careful it's not to hot as your shower and other sinks also will get this hot water......cut your dish soap down and make sure to use a Jet Rinse Aid. Again, be sure to use a liquid soap, and rinse agent, powders will cause a caustic reaction. Hope this helps. Let me know if there is anything else I can help you with.
JimmyC
Sep 30, 2009 | Bosch Dishwashers
Dishwasher
Check to see if you have any switches on your dishwasher that could by pass a rinse cycle. Use a hotter temparture when washing, Check your water level,check your filters on your inlet hose top and bottom. When it gets to a rinse cycle you should hear it drain out and bring in fresh water. you could change to a liquid detergent. Dont over load your dishwasher. make sure you are using rinse aid and try adjusting it up one setting. Shiney glasses means your rinse add is working. NZL
Jan 04, 2007 | Kenmore 18 in. 14432 / 14439 Built-in...
KitchenAid 24 in. KUDP01IL - Multiple Color Built-In Dishwasher Logo
191 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
