Question about Dewalt D51256K 16 gauge finish nailer kit
Gun failure constintly leaking air from exhaust wont fire a nail
  • bertobryan45 Nov 19, 2008
    I OIL IT DAILY ITS PROBALLY IS THE O RING THANKS ALOT
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 185 Answers
Bertobryan45
Have you been lubricating it regularly with nail gun oil. We use framing nailers every day at the commercial tree farm I work at and one of the operating instruction is to put 6 to 8 drops of oil in the air hose connection on the nailer before every use. I suspect the O ring on the piston is worn out/
Hope this helps Good luck Loringh PS Please leave a rating if appropriate Thks
Posted on Nov 16, 2008
Nailer wont advance the nails then it shoots blank
Try ez test to check for proper operation. Remove nails and air supply, point nose of gun up then down again. The driver should not move from the top of cylinder position. If driver is moving up then down replace the driver oring. If driver oring seems ok then connect air supply and bump fire the nailer without nails against soft wood and door open so that you can see the driver and feeder moving. Bump fire the gun and make sure that the driver is moving all the way back up to top of cylinder and the feeder is moving rapidly back and forward. If movement seems ok then hold the nose down on soft wood and depress and hold the trigger. This will fire the gun but driver will stay at the bottom position and not return until you release the trigger or lift the gun. When holding the gun with the driver down position, no air should leak out the top or bottom of the gun. If air leaks out bottom, replace lower bumper, if air leaks out the top replace the upper bumper. Good luck
Mar 19, 2015 | Porter Cable Coil Roofing Nailer
Air comes out the nose of my dewalt framing nailer
Again sounds like blown O ring give it a squirt of 3in1 oil and fire it several times (if oil is compatible in your gun). Repair center if that doesn't work. Trash can also get in the air orifice and stop moving parts from moving.
Dec 07, 2013 | Dewalt Air Tools & Compressors
Nail gun no longer fires. Leaks air around trigger when trigger depressed. It is in single fire mode.
You will have to take the gun apart and change the rubber o-ring gasket for the trigger mechanism..Go to a Home Depot or other contractor outlet to get parts or info...The gasket actually keeps the air from leaking so it will nail.
Oct 24, 2013 | Air Tools & Compressors
I have a Bostitch N80S stick framing nailer that leaks air from the trigger area. I replaced the entire trigger valve with a new single fire trigger to see if the old bump fire trigger was the problem
Remove the nails and take off the trigger to expose the trigger valve (usually part # tva6). Connect air and spray soapy water on the valve to determine if the air is leaking from the center of the valve or around the outer edge between the body and valve. If leaking from the center, could be defective valve or debris under oring. Pop out the valve and examine internal parts for cut oring or defect. If leaking from between body, you could have cut orings installing the valve. Make sure that there are no rough edges in the body of the gun. Bump fire or single fire happens with the trigger type not the valve. Bump fire trigger is usually black metal and single fire trigger is light color plastic. Good luck
Apr 10, 2013 | Stanley Bostitch Nail Gun
Miss fires and wont sink nails depth set deep and pressure over 120 psi
If no air is leaking from gun, miss-fire is usually caused by worn or too tight piston oring or lack of lubrication. Easy test. Disconnect airline, remove nails, point nose of gun up then down. Driver should stay in uppermost position. If driver moves up then down within gun replace piston oring and retest. Set pressure to about 100psi. Good luck with repair.
Oct 14, 2012 | Porter Cable Coil Roofing Nailer
Coil nailer wont feed nails, fires no problem
Remove nails from the gun and dry fire the gun by bumping it against thick rubber mat or coiled up rubber hose. As the gun cycles notice the feeder moving back then forward in time with the cycle. Make sure that the feeder is connected to feeder driver with a roll pin and that the check feeder is in place in the latch door. The check feeder is thin metal and should have spring action. The driver should return completely to top of cylinder with some degree of force. There should not be much air leaking out the nose as the gun cycles. If a quantity of air is leaking out nose with each cycle, then lower bumper may have broken/cracked. Replace as needed. If very little air is leaking out nose with each cycle then driver could be bent, piston oring could be worn or lack of lubrication in cylinder. If all lower parts seem good, then only area left to check is head valve. There is a 1/4 inch dia. rubber ring at the very top of head that could restrict air flow out of exhaust port. Adjust as needed. Good luck.
Mar 18, 2011 | Duo Fast DuoFast 1015141 CNP65Y Siding...
Just replaced o rings and piston bumper, but gun still leaks air (out of nozzle) and wont fire at all
Air leaking thru nozzle (where nail exits ) can be caused by two issues. Air leaking past valve rubber at top of cylinder where headvalve seals when under pressure. If leaking at valve rubber seal the piston will usually be pushed down if there are no nails in gun. If the driver stays up while leaking then problem is at cylinder plate. This plate has two orings that seal air pressure. On seals against the body of gun and the other seals against cylinder. Leaks can occur if body of gun is worn, warped or has scratches where oring makes contact. Also look closely at the plate for crackes. Replace parts as needed. Good luck
Feb 27, 2011 | Hitachi NR90AD 3 - 1/2'' Clipped Head...
Aaair leaks out of trigger on paselode phneumatic framing nail gun and wont fire nail
Are you using air tool oil before each use? The air coming into the gun may have water and other debris along with it. Try installing an in-line filter in the hose. Remove the head and try to push the piston down to see if it is stuck. Hope this helps!
Aug 15, 2010 | Garden
Air nailer air leak
No, internal leaks on your Senco require replacing the seals, which can be tricky. You Can try the repair kit they sell, but they're usually for the firing/triggering system and piston stop system.
Nov 11, 2009 | Air Tools & Compressors
Dewalt D51256K 16 gauge finish nailer kit Logo
333 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
