My toshiba A75 won't charge - Computers & Internet
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
If the charge light is on you need a new battery.
Posted on Nov 15, 2008
I need recovery xp cdToshiba Satellite A75-S2112 Notebook
Call Toshiba and order a new CD.
They will charge you for it.
Sep 25, 2013 | Toshiba Satellite A75-S2112 Notebook
I cannot charg the battery I have toshiba satellite laptop A75-S206 ; and i can,t charg the battery tanks @ regard
Borrow a different 19V charger from a friend see if its just your charger if not then the DC jack most likely is damaged common issue with Toshiba and Acers. Good thing is Toshiba does not solder the DC jack it fits in a sleeve and plugs into the board.The Dc jack should run you around $5-$15 dollars the repair is a tare down to the boards right corner. Look on utube for "A75 tare down" should be a video floating around show you where the screws are. Shop would charge right around $100-$125 dollars if more they are ripping you off.
Oct 27, 2011 | Toshiba Satellite A75-S206 Notebook
I need a cd driver for a75-s206
You can download the Drivers for Toshiba Satellite A75-S206
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 28, 2010 | Toshiba Satellite A75-S206 Notebook
Battery not charging
It should be marked on the fuse or the board either next to or under the fuse. Before you replace it, find out what blew it. Otherwise, you could blow something else out.
Feb 21, 2009 | Toshiba Satellite A75-S209 Notebook
Screen black & with no power
hi there,
you can follow this instruction and try to your laptop to resolved the problem.
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with Toshiba Satellite M35X and Toshiba Satellite A70/A75 notebooks. If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it’s still under warranty, it would be fixed at no charge to you.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. Toshiba Satellite M35X and Toshiba Satellite A70/A75 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system board with a magnifying glass. In most cases you get the power problem because of a bad connection between the DC jack and the system board, you’ll see a crack between the DC jack connector and the system board.
Here is an example of Toshiba Satellite M35X power jack. The crack occurs between the DC jack pin and the system board.
satellite-m35x-crack.jpg satellite-m35x-contact.jpg In some cases the connection is good, but the DC jack is bad itself. You can find a new DC jack for Toshiba Satellite M35X and Toshiba Satellite A70/A75 laptops here. Search for DC jack M35X or DC jack A75.
How to resolder laptop power jack yourself.
UPDATE:
Sometimes, after you replace the jack, you can see that the system board doesn’t get power at all. The battery will not charge and the power LED will not light when you plug in the AC adapter. So, here’s a possible explanation.
When a connection between the positive pin and the motherboard breaks (cracks), the power jack gets loose. You can feel it when you plug in the adapter plug. A loose power jack can damage the trace inside the hole in the system board. Take a look at the picture.
power-jack.gif As you see, the positive pin goes through the hole in the system board and you solder it on the top side. Right? What if the trace between the top side and the bottom side is broken somewhere inside the hole? I’ve seen it before a few times. In this case everything looks nice and clean on the top side. When you plug in the AC adapter, you get normal voltage readings between “+” and “-“ pins on the top side, but the power DOESN’T go to the motherboard at all, because there is no connection between the top and bottom sides. Test with a multimeter if there is a connection between the top and the bottom.
If the trace inside the hole is broken you still can fix it. You can run a wire to connect the top and the bottom sides. Be careful not to short something on the board.
Update:
Here’s another solution to fix the power jack problem, it shows how to relocate the power jack outside the laptop base. Check it out here: Toshiba Satellite A75 failed power jack workaround.
When you repair a loose power jack, it’s a good idea to check the jack on both sides of the motherboard. When you remove the top cover from a Toshiba Satellite A70/A75 laptop you can see only points where the jack is soldered to the motherboard as it shown on the second picture in this post, but you cannot see the jack itself as it shown on the first picture.
Removing the motherboard from Satellite A70/A75 laptop is a good idea because the jack itself might has a broken “+” pin, as it shown on the picture below. If the “+” broke off the base, you’ll have to replace the jack.
Feb 15, 2009 | Toshiba Satellite A75-S229 Notebook
Satellite A100 won't swich on- will be similar to A75
remove the battery , then insert it again, then leave it for charging for some times then check
Oct 26, 2008 | Toshiba Satellite A75-S209 Notebook
Toshiba A75-S229
Try updating your bios and any associated hardware drivers. Your BIOS can be download from this link http://cdgenp01.csd.toshiba.com/content/support/downloads/1a70v15.exe
Jul 06, 2007 | Toshiba Satellite L25-S119 Notebook
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
