Question about Samsung Televison & Video
Samsung TV Model #TXE2746
The top 1" of the screen has gone black. Who do I turn to for service in Boise, Idaho? What parts are required? Who will provide them? Costs?
4 Suggested Answers
edcarson
  • 10 Answers
SOURCE: "clouds" on 32" Samsung tv screen
My best suggestion is to replace the inverter to the lcd panel.I could look up the part number if you need.Let me know - edcarson
Posted on Feb 18, 2008
  • 16 Answers
SOURCE: Magnavox Color TV Model #27MT3305/17
The problem I was having was that the vertical deflection was collapsing on itself from the top. I'm a tech and I am visiting web sites who experience similar problems with the Magnavox 20 MT4405 in hopes of saving them time and money."Starsong" has the right answer. Replace electrolytic capacitor #2465. It is a
10 microfarad electrolytic capacitor rated at 160 volts. Although the existing capacitor appeared good,in circuit and out, the charge-discharge time was flat as compared with a new capacitor. Plus, when the capacitor is in circuit with full voltage applied, the capacitor leaks too much. The cost of the capacitor should be under $2. It should take under a half an hour to replace. Be certain to let your set rest, unplugged, for at least a half hour before attempting to replace this capacitor. There are high voltage present around the crt even after the set is turned off. The high voltages can cause serious bodily harm. I would suggest a tech discharge the anode on the crt with a high voltage probe passing through a volt meter and running to ground. You will need a soldering iron, solder ******, solder, and I like to use a little flux for good adhesion of component to board.
Posted on Dec 06, 2008
SOURCE: plano tv samsung txe2746
saludos tengo un problema en la fuente de alimentacion y exploto el integrado que esta unido a un disipador de calor precisamente en el serial del integrado quien me podria ayudar facilitando el plano electrico del samsung txe2746.
gracias
Posted on May 12, 2011
Samsung lcd tv has sound but no picture. Samsung TV works for about 10 minutes then screen go black but sound continues
Use a flashlight on the screen when it goes black. If you can see a faint picture then the board that controls the back light has gone bad. If you see no picture then the T-Con board is bad. You can get replacement parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy and fix the TV yourself. It's not that difficult.
Mar 13, 2016 | Samsung LN40B610 LCD TV
Plano tv samsung txe2746
gracias
Jan 07, 2010 | Samsung TXE2746 27" TV
Samsung TX-R3080WH, tv is less than 2 years old and the picture is too dark to see it. some channels, you can "make out" a picture, but for the most part, channels are black. but you can still hear it.
not sure about this model but it sounds like the backlight has gone out. You can call samsung at 1-800-samsung and they may be able to help or give you the # of the nearest service center.
Dec 08, 2009 | Samsung TX-R3080WH 30" TV
Need large nylon gear for fellowes shredder od1500c
Call 1-800-955-0959 they will need serial # of it....hope this will help
Oct 05, 2009 | Fellowes (R) OD1500C High-Performance...
Aspire 1690 - Backlight on screen is failing Rose
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 08, 2009 | Acer AOA150-1690 Aspire Notebook
Picture tube
HELLO
If your tube has gone and you are looking to replace it - my advice is don't bother - it will cost you dear in the end. The best thing to do is try to get another CRT TV set (maybe a different make/model).
It is a skilled job replacing a TV tube and should not be attempted by anyone who does not know what they are doing!!! In the wrong hands a CRT is dangerous and could cause serious injury if dropped or handled incorrectly (it makes one hell of a bang).
I wish you luck with it all the same (:-)
Jan 18, 2009 | Samsung TXE2746 27" TV
Samsung TXE2746
this could be a number of problems first chek the horizontal output transistor this could be shorted and the set could be tring to turn on but cant couse of the short look for bad solder connections if this does not help check or replace the regulator
Nov 02, 2007 | Samsung TXE2746 27" TV
Trouble
I need more info please as i dont understand what your asking?? sorry
Mar 31, 2006 | Samsung TXE2746 27" TV
Televison & Video Logo
49 people viewed this question
Henry  Thomas
Henry Thomas
