Question about Whirlpool Refrigerators
Model ED25TEXHW01 stopped working
It gets electricity but niether compressor nor fan are working. Inside temp. is 60 deg F
  • saba_mahania Nov 16, 2008
    I checked the white and red wires that go into the fan first and then to compressor. Niether one is getting any electricity. I checked the electicity going into the frig at the first stage and it does get electricity. But not the fan and compressor. They are not getting any.
    -Saba
    Sergeant:
    Champion:
  • 251 Answers
Time to by a new one or have a tech come out and service it Helping u Shaun
Posted on Nov 15, 2008
Intermittent colling in Samsung Window AC
so your reported figures show that the unit is operating as planned
the closer to ambient temp the shorter it runs for
the further away from ambient temp the longer it runs for
when the desired temp is reached , the compressor will stop but the fan will continue to run to circulate air past the thermostat so that it will switch back on when the room temp reaches too high temp
and that is why it is recommended to set the temp at 25 C as that is the most economical temp to run it at
Oct 30, 2017 | Heating & Cooling
The compressor and fan won't come on but there is power supply working for the lights
Without your MAKE & model number; all I can do is tell you what can cause this symptom.
At the end of the defrost cycle the defrost control is supposed to get a signal from either a 60 deg bi-metal thermostat or thermistor (depending upon make & model) That signal starts the clock either mechanical or electronic that signeals the compressor to start. The fan automatically will run when the compressor runs. If the defrost thermostat or thermistor is not working correctly the unit will start a defrost cycle but never finish so it completly defrosts.
The termperature control will also cause this symptom. If the corntacts in the temp control fail the compressor will not restart.
Just from reading your symtoms I think you have a problem with one of the following:
1. Defrost thermostat or thermistor
2. Defrost control
3. Temp control
Most of the time it is either 2 or 1 above in that order.
If you respond with a make and model number I will use that to determine if there is anything you can do at this time to troubleshoot.
Thanks for choosing FixYa,
Kelly
Aug 07, 2011 | Refrigerators
Freezer cuts off and stays off for a long time before it turns back on, all my food in my freezer thawed out and I have to through it all out. My husband thinks it might be the defrost timer or the...
Hi and welcome to FixYa. I am Kelly.
Actually it sounds like the thermostat and the timer are working just fine. What appears to be happening is the timer is starting the defrost cycle but the defrost heater is not working. This will result in a horribly long defrost time until the freezer compartment reaches 60 deg F and the defrost thermostat at that point terminates the defrost cycle.
Defrost element Item 9 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48487&diagram_id=671582#d671582
Detailed view:
http://www.appliancepartspros.com/part_details.aspx?part_id=4070730
Defrost thermostat item 12 above first link
Detailed view:
http://www.appliancepartspros.com/part_details.aspx?part_id=4070255
You should read the resistance of the defrost heater by reading the yellow to blue wire (terminals 2 to 3) on the defrost control when the freezer comparment is below 60 deg F at the evaporator. No resistance = open defrost heating element. This is reading continuity though both the defrost thermostat and the heating element. If you do not get any resistance and you are sure that the freezer is well below 60 deg F then... and only then would the defrost thermostat be suspect.
Defrost control in the overhead of the fresh food compartment is located aft of the lights on the thinner section cand an be manually cycled by rotating the 2 tabs on the face of the timer dial. It will click and stop the compressor and evaportor fan ONCE each turn.
NOTE you must wait 10 to 15 minutes after cycling this so that the compressor will stabilize and restart. Once the comprssor and fan shut off the heater is supposed to turn on and melt the ice on the evaporator until the defrost thermostat reaches 60 deg F and once again provides power to the defrost timer motor to terminate the defrost cycle and restart the compressor.
Defrost timer is item 15 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48487&diagram_id=663054#d663054
Detailed view:
http://www.appliancepartspros.com/part_details.aspx?part_id=4084056
This should be enough information to get you going. I still think that your defrost heater is not working either from failure or a wiring problem.
Kelly
Oct 14, 2010 | Maytag MTF1955GRW Top Freezer Refrigerator
LG LRFC22750ST fridge is 3 years old and the top half has stopped cooling. The freezer seems to work ok. This happened a couple of weeks ago where I opened the door and found the refrigerator half...
During the Automatic defrosting cycle there is a 60 Deg F thermostat on the evaporator that must cycle to terminate the defrost cycle and restart the compressor. If for some reason the defrost heating element is not coming on (failed / open / wire terminal problem) The the unit will just sit not operating until it reaches 60 F in the evaporator section of the freeser compartment. I suspect that you have an Automatic defrost heating element problem. Again that can be from a broken wire / terminal or the element itself has failed. It is possible that the 60 deg F thermostat itself is sticking and not cycling when the temp of the evaporator reaches 60F. It can also be caused by the temperature control that does not complete the circuit and start the unit when the fresh food section reaches cycling temp 34 - 37 deg F.
Your particular unit uses a thermistor and what is listed as a sensor to control the defrost and cycle temp circuits.
Parts list here:
http://www.searspartsdirect.com/partsdirect/part-model/LG-Parts/Refrigerator-Parts/Model-LRFC22750ST/3204/0161000/P0809090/00002?blt=06&prst=&shdMod=
Sensor is Item 903E
I am NOT telling to order anything thing. The only way to find out is to read out the components.
Thanks for choosing FixYa.
Kelly
This requires that the back of the freezer compartment be opened to troubleshoot and repair. Troubleshooting is done via resistance checks from the defrost control board or timer to the compressor. Usually blue wire from the control to the orange wire on the compressor then finding out which component has failed by reading resistance before and after each component.
The only way to find out is to use a meter.
Kelly
Sep 23, 2010 | LG LRFC22750ST French Door 22.4 Cu. Ft....
My question concerns the electric cooling fan attached to the radiator: Should this fan come on automatically with the A/C compressor? After having some work done on the A/C, the fan comes on with...
With a/c on, fan needs to be on all the time, to reduce pressure it the a/c condenser, or a/c will not cool to it's max, with a/c off, fan will only come on with engine temp. between 215 - 200 deg, when it get's down to about 210 deg. fan will shut off. and come back on when it get's back up to 215 -220 deg.
Aug 16, 2010 | 1996 Dodge Caravan
Samsung SRS536 side/side fridge no auto start, now weak cooling
you give a pretty good discription;i would say this machine has leaked gas, the hole is not visable to the human eye therefore the machine is working and working trying to maintain the temp.my advice to you is buy yourself a new fridge,because this one will cost to much money to repair.adrian,,,,,,
Jul 31, 2010 | Samsung Refrigerators
GE fridge does not get cold, 60 deg in freezer 70 deg in fridge, compressor is running condensor fan is running and fan inside of fridge is working
You have either a bad compressor or a refrigerant leak.Some times a compressor runs but doesn't compress the gas.It is more likely the unit has a sealed system leak which would have to be located,repaired,and evacuated,then recharged.(not a simple task).
Jun 01, 2010 | GE Refrigerators
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
Refrigerators Logo
80 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
