Question about Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum
Hoover Floormate SpinScrub won't dispense cleaning liquid
My Hoover Floormate Spinscrub will not dispense the cleaning liquid at all. There does not appear to be any obstruction from the clean solution tank down to the bottom of the machine where it comes out above the floor. The only solution in the owners manual is to make sure that the tank is securely locked in position (which it is). Any suggestions?
  • 1 more comment
  • dnyes Oct 29, 2008
    My foormate 500 will not spin to scrub
  • Anonymous Dec 17, 2008
    my floormate is brand new today and it won't dispense solution
  • Anonymous Mar 19, 2014
    Leaking from resivour tank
I had the same problem and was preparing to take it back, the last thing I tried was to 'reseat' the handle -- I removed it then snapped it very firmly back into place. That did it, it's working beautifully now!
Posted on Feb 07, 2009
Try putting a bungee cord around the tank after you place it in its spot - which will keep it snugly in its place. It worked for me.
Posted on Nov 09, 2008
Try using a bungee cord wrapped around the tank tightly.
Posted on Mar 14, 2007
Hi, how do I check my hoover floormate deluxe spinscrub's filter and motor?
Hi Mike! To check the filter on the Floormate deluxe, remove the dirty water tank and pull up on tank lid to separate from the base. Check foam filter for debris, if filter has debris, rinse it with water. To prevent internal damage make sure you are using only the Hoover Floormate detergent. If the machine is still noisy and smells bad we recommend taking it in to a Hoover authorized service center. Follow the link to find the nearest service center to you. Hope this helps! Service Center Locator
Oct 20, 2014 | Hoover Vacuums
HOOVER FLOORMATE SPINSCRUB WILL NOT PICK UP WATER
First make sure that you are getting suction from the bottom of the machine. Most of the time the squeegee is worn out which does not allow it to pick up the water like it use to. Turn over the machine and inspect the squeegee. If it looks worn or bent then it may be time to replace it. You may also consider replacing the filter. These are the two most common parts that wear out.
here is a link the parts for your a h3030 floormate
Hoover H3030 Parts Link
http://www.usavacuum.com/category-s/86.htm
Jan 16, 2010 | Hoover H3030 FloorMate SpinScrub 500...
Brushes won't spin on FloorMate
you need to replace the belt or make sure the brushes are locked into place.
Jun 18, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Troubleshoot floormate spinscrub 800 floor cleaner
The brushes are not designed to scub the floor, they only lightly touch the floor. Make sure the front nozzle is put on correcdtly. Make sure your filter is dry and clean. I wet filter will give poor suction down to the nozzel. Down load the manuel at Hoover.com. The model is located on the back of the unit. H3000, or H3010
May 24, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover spinscrub water keeps coming our
Check the machine where the water tank is installed, you will see a pipe stem this stem should have an o-ring gasket on it. also look at the plunger in the tank for proper seating.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Jan 18, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Hoover 3010 FloorMate Plus not dispensing liquid
With the tank off, can you see if the rod in the handle is hitting the spot where the tank sits on, if not then there is a problem in the handle. If it is, then the reservior asm may be bad, it is what the tank sits on.
Jun 14, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Need instructions for operation
The last time I checked, manuals were available on www.hoover.com.
Mar 21, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum Logo
1,744 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
