Question about Dell Dimension 4700 PC Desktop
Cant boot from CD Drive.. cannot be seen in the bios
Hi. My friend gave me his dell 4700 today, and i put my harddrive from my old computer in the dell 4700, and now it wont start. I want to re-install windows on it, and when i press f-12, many people have said select the CD-drive to boot from but its not even there. The only options are "System setup", "Boot to drive partitioning" and "Hard drive diagnostics". I have checked and the DVD drive is correctly connected, and so is my hard drive.
  • 3 more comments
  • ollie_syms Nov 15, 2008
    I've tried that and its still not picking up my hard drive.
    Keep the suggestions coming.
    Thanks for your time.
    So yeah.. I'm guessing its not detecting my hard drive or cd drive for some strange reason.
    And the computer was working fine before my friend gave it to me. It doesnt make sence! :(
  • ollie_syms Nov 16, 2008
    A, B, C lights are green, and the D light is a yellowy orange colour.
    Right i've found the problem. My hard drive has actually died because it is detecting my dvd drive. I actually did manage to load up my hard drive and get onto windows once, but then a blue screen came up saying hardware failure etc. Will need to invest in a new hard drive by the sounds of it, and most likely a SATA one and not a ICE one :)
    Thanks for your time guys.
    New Friend:
I am havig the same problem with the same product. The only difference is that my hdd can be seen in the bios but when i use the same bus cable to connect the dvd rom, the rom is not see. Its shows 'not detected in the bios.
Posted on Sep 21, 2015
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
So now we need to know if power is getting to the cd and hard drive. Without a power supply tester it will be hard so I"d take the power supply out and ask my local pc repair shop to test it for me. If it's good then I'd be thinking motherboard. Since neither the cd or hard drive are detected it wouldn't make since that both ide cables had gone bad. I"ve found some info at http://support.dell.com/support/edocs/systems/dim4700/sm/adtshoot.htm#wp1054081
which has trouble shooting light codes. I"d be interested in what the error code on the lights is. It also has diagrams for those of us that don't know about the inside of pc's.
The way I troubleshoot the motherboard is to take everything off the board, then one at a time reseat the RAM then try to power on the mb and listen of beeps. Then hook up the ide to the cd and listen for beeps. then the hard drive and listen for beeps and look for messages on the screen. Let me know what the status is.
Thanks,
Henry
Posted on Nov 16, 2008
I have the exact problem with the same dell model.
when you say make sure ide cable is connected to the hard drive, do you mean i have to take the computer apart? i have no knowledge of computer hardware, though i'm willing to try with step-to-step instructions.
i went into my bios and set cd-rom to first. the ide, it says, is not present in brackets.
would i need to enable the ide somehow in there? i cant find it in bios.
thanks for your help!
    Cheetah:
  • 84 Answers
Make sure the hard drive is connected to the ide cable that has a blue end. Don't connect anything else to this cable. when the pc is booting up watch the screen for the option to enter setup usually Del, or F2. Once into the bios see if the boot options are set to cd first and ide 0 second. You can also see if the hard drive is being detected in the bios.
Hope this helps. Let me know.
Thanks,
Henry
Posted on Nov 15, 2008
SATA Hitachi 1 Tb HARD DRIVEi AM TRYI8NG TO INSTALL A NEW HARD DRIVE ON MY DELL 4700 AND I CANT FIGURE IT OUT IT IS SAYING NO ( BOOT DEVICE NOT FOUND)\
Dear Jackson,
If you are connected your new hard drive, You just have to go into BIOS and set your old hard drive as first boot device . its all. for BIOS choose f2 or f10. Good Luck.
Nov 20, 2012 | Hitachi 1TB External USB 2.0 Hard Drive
Dell 4700 wont boot up
to boot up:
1.Restart Your computer Press Delete until BIOS setup appears.
2.Go to Advance BIOS setup then Boot sequence.
3.First Boot Your CD-Rom, 2nd Boot the HDD-0.
4.Save The Settings Then restart.
5)when appear "press any key to boot" then click ENTER button of your keyboard it will automatically boot.
Aug 17, 2011 | Dell Dimension 4700 PC Desktop
Dell Dimension 4700
Try resetting the BIOS, see if the drive re-detects
  1. Boot to BIOS F2
  2. turn on all 3 lock lights (NUMLOCK, CAPSLOCK< SCROLL LOCK)
  3. Press ALT+E, then ALT+F then ALT +B and system will reboot and re-detect drives
  4. If HDD is not detected, reseat data and power cable connections, try again
  5. if still no go, then HDD has likely failed
Mar 21, 2010 | Dell Dimension 4700 PC Desktop
Can i boot from usb
I'm sorry but the answer is no.
You only have floppy, hard drive and cd-rom options. With some Dell models the USB is seen as a secondary hard drive from within the BIOS so maybe (if your bios supports it) you can change boot order there.
Usually thats not the case so you mainly have to boot from the CD/DVD to install or run a DOS or linux command.
Regards.
Feb 09, 2010 | Dell Latitude C600 Notebook
Blue Screen Issues
can nit be the motherboard cause you would not be able to boot at all ...probably it was just a real bad virus that affect something ..try to reinstall it clean...first remove the hdd and see it it boots to bios and if it sees the RAM memory ...and even so ..try to get from somewhere some suitable ram memory and replace teh old one ...just to see how it behaves....in most cases I run into when they blow me out and gave blue screen without explanations it was some issues with the ram memory ...so ...first just borrow some of the same size and frequency and see if it boots up ...it might surprise you in a positive way ...
Aug 18, 2009 | Dell Dimension 9100 PC Desktop
Dell Dimension 4700 can not install Windows XP
It looks as though when deleting the OS you might have gotten jacked and the rom drivers were lost.
Jun 25, 2009 | Dell Dimension 4700 PC Desktop
Dell 2400 wont recognize harddrive
I don't know how old the Dell is but I have not seen a BIOS setup routine that did not automatically find and recognize a new hard drive for many years. Perhaps the BIOS is the source of the problem.  Did you try the removed drive in another system? Did you check the CMOS backup battery? If this needs to be replaced, it may not recognize much of anything.
Dec 22, 2008 | Dell Dimension 2400 PC Desktop
Swaping hdd
You have half a dozen reasons why this will not work. The Operating system (XP) does not recognise the different hardware, the Bios doesn't recognise the MBR (the file structure of the harddrive) and you have all the wrong hardware drivers installed.
There is a way to do this if you have the original XP installation disk, install the harddrive, put the XP installation disk in the CD/DVD drive and set the machine to boot from the CD/DVD first. When the machine boots up and goes to install XP follow the instructions as if you are doing a fresh install, when SetUp attempts to format the harddrive it will discover you already have a version of XP installed and will give you the option to repair it, go ahead with the repair and MAYBE SetUp will be able to see and install the correct hardware drivers. If not you are looking at Slaving the harddrive, saving your personal files and then formatting the harddrive and reinstalling XP fresh.
Oct 31, 2008 | Dell OptiPlex GX110 PC Desktop
Fit a new harddrive in an old laptop
Pls try:
1. When the Dell logo screen appears press the F2 key to enter the BIOS?COMS; or
2. There are some Dell Latitude that uses Fn + F1 (while booted).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 30, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Dell Dimension 4700 PC Desktop Logo
335 people viewed this question
Alun Cox
