Question about HP PSC 1315 All-In-One InkJet Printer
Test page reprint
I recently changed ink cartridges and now every time the printer turns on it prints a new test page. I'm going through a lot of paper, how can I stop this from occurring?
That was my problem, too, but noticed the test page. It has 1 2 3 steps to follow. Follow the 1 2 3 steps as indicated; and when you turn on the printer again, your problem solved, i.e. no test page printing.
Posted on Nov 16, 2008
HP PCS1402 keeps printing test sheet on start up
Have u recently changed ur ink cartridge ? If so the printer is printing an alignment page . Turn it off then on , so it prints the alignment page. load the alignment page on the scanner glass and press the "Scan" button to complete the alignment. Once the alignment has completed the alignment page will not be printed again until you change the next cartridge. See your user manual for details.
May 17, 2012 | HP PSC 2355 All-In-One InkJet Printer
The documents are faded even after putting in a new cartridge
  • make sure you are using inkjet papers as inkjet printers work on inkjet papers.
  • Lift the printer access door, then remove the ink cartridges from the printhead.
  • Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  • Close the printer access door.
  • Reprint the picture or document that had the quality problem.
  • if still light prints then proceed further
  • Print Test Page
  • Review the printed test page and verify that:
    • the left color blocks are gray, cyan, and black.
    • the right color blocks are magenta, yellow, and black.
    • each block is completely filled with color.
  • If no---> Clean Printhead, the On/Off light flashes during the cleaning procedure.When the On/Off light glows steady, print test page again.
  • If Yes---->The problem could be caused by the type of paper you are using.
May 28, 2010 | Kodak Office Equipment & Supplies
Printer starts up doing a printer test page
Hi
Maybe there is a some thing in your priter driver page when you go to print go to where it says (print setup) look in there but most printers I know do the same thing I not turn my printer off thats the best way just leave it on standby or you will use lots of ink ever time it stats up and papper
Jan 23, 2010 | HP Photosmart C3180 All-In-One InkJet...
Hi there, I have recently changed the black ink cartridge in my HP Deskjet 3845 printer, but it now prints with purple ink. Can you help?
have you cleaned the print head? done a test page? i had a simlilar problem with a lexmark but it turned out to be a refilled cartridge. if you are using genuine hp cartridges i would recommend printing a test page and checking the solid colours .
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa00224&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=372330
hope this helps!
Jan 19, 2010 | HP Deskjet 3845 InkJet Printer
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
F380
You are using HP's cartridge with the smallest output . So if you are printing 80 pages of text, you will have a problem by the time you reach 95 or 100 pages. If you are printing in color, you only have 1ml/color. Meaning 3 colors. But in order to print a red, it will combine a magenta and yellow to product 1 color. So 3 colors doesn't mean 3 ml worth of colors. Effectively you may only be able to print 10-20 pages of color then your cartridge is empty. The black cartridge has about 4-5ml of ink. So if you print a lot I suggest you get another printer.
Mar 30, 2008 | HP DeskJet F380 All-In-One Printer
Keep printing test sheets
A lot of HP printers print a page to enable the print head alignment and calabration. This normally orcurs when a cartridge has been changed. If the alignment page fails then it will reprint alignment page until it can align.
So, you need to get that page it prints and place it on the glass and press scan, then it will complete alignment and be ready to rock.
See Here
Cheers
Jan 19, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP Photosmart C3100 series
I just got off the HP help line.  After changing my black ink cartridge a test page was printing each time I turned the machine on.  This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink.  I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty.  It turns out that you cant do it.  HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings.  And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer.  The printer was inexpensive sure, but I'm paying for it in wasted ink.
Dec 26, 2007 | HP Photosmart C3180 All-In-One InkJet...
Lexmark x6150 won't print after being stored
If you havent tried this already......try to reprint several times......this has worked for me in similar situations......you may just need to give the ink a chance to do its thing
Dec 12, 2007 | Lexmark X6150 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
46 people viewed this question
Seeker5211
Seeker5211
