Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t Washer - "Control Locked"
The control locked light is lit and it will not allow me to do anything else. I have pushed every button and it is not responding. How do I reset this and how did this happen? Help I need to do laundry! Thanks for any assistance.
  • Anonymous Mar 30, 2014
    I have a Kenmore Elite Front Load washer. And the Control lock light is on. I cannot reset the washer. Is there a button reset combination I can use to reset the system. I have already unplugged it for 30 mins and it did not reset.
I pressed and held drain/spin and it unlocked the controls... try it and let me know.
Posted on Jan 01, 2007
  • skinnergregg Dec 24, 2010
    This website is my Christmas present!!! At the end of my Holiday Cheer I was looking for the baseball bat solution.
    Your advice worked like a charm. Thanks and Merry Christmas.
  • robertmgutie Jan 26, 2011
    thank you very much. that solved the problem and i got my wife off my back.
    I actually unplugged the washer for about ten minutes, then when I turned it on the light was still turned on but i pressed the drain/spin for three seconds and when I depressed it the light went off and the washer worked.
    I think it needs to be turned off first, because I had pressed the drain/spin before with no success.
    thank you.
Great solution thanks so much
Posted on Sep 22, 2008
Had the exact same problem, soljution worked, thank you so much. Also had an over flowing hamper of clothes needed to be washed and a repair man is ten days away from being available.
Posted on Jan 19, 2008
Thank you soooo much!  I was frustrated and unable to locate my owner's manual.  Thank heaven for this website, the internet and helpful owner's like you!    Thanks again!
Posted on Oct 22, 2007
Thanks it worked great now i can catch up on the chritmas laundry!
The kenmore elite smart wash quiet pak 9 I opened the door and threw something else in and now a light is on thar says controls locked and it wont do anything
There should be a button on the control panel that says "open door" you need to push that button and wait for the washer to shut off before you open the door. Try pushing that button to see if that resets. My guess is that you broke the safety latch when you opened the door and it will need repair.
Mar 10, 2014 | Kenmore Washing Machines
Control lock lit, no other buttons work
Instructions
    • 1 Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
    • 2 Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
    • 3 Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
Read more: How to Unlock the Control on a Whirlpool Duet ' eHow.com http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html#ixzz2HVS4i8hL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 09, 2013 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Control Locked light on
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the DRAIN/SPIN button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 11, 2010 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite smartwash quietpak 9 HE4t. The control locked light is on. I have tried unplugging for an hour and plugging back in, door is unlocked but no buttons work. What can I DO
The following link explains how to correct a Control Lock problem on a Kenmore Elite:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
Some front panel features differ between models, but the instructions should be listed on the front panel of the washer, and are located in the operator/owner's manual. If these preliminary measures do not work, you may have a mnore serious problem.
If you have any questions, please let me know. I hope this helps you.
Aug 23, 2009 | Kenmore Elite HE5t Washer
How do I unlock controls Kenmore HE4t
Your control panel options may differ slightly from the instructions I have posted, but the instructions should be listed on the front panel. If this does not correct your problem, you may have a more serious issue than a simple operator control problem.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Aug 13, 2009 | Washing Machines
Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Door stuck Locked Control Locked light on
Try unplugging the washer for at 30 minutes to reset the computer, first. If this proves unsuccessful, you can retrieve you clothes by using the manual release. The following link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Once you retrieve your clothes, try running diagnostics on it. You can envoke the diagnostic sequence by selecting DRAIN/SPIN, NO/SPIN and then pressing any button under OPTIONS 4 times (must be the same button). The display should go to "C00" as the washer begins a sequence of tests that checks the fill functions, door lock, dispenser functions, motor speed, spin and drain. Allow the washer to run through the entire sequence and shut off. If anything is wrong an error code should be generated. Hopefully, all you had was a minor glitch. Let me know how things turn out. I hope this helps you.
Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
Adjacent to the "Control Locked" light is the DRAIN/SPIN button. Push it in and hold for 3 seconds. This should unlock the control panel. If it doesn't, let me know.
This is a designed feature of the washer to lock the controls to prevent small children from accidentally turning the washer on or manipulating the controls in any way. The control can be locked by holding the DRAIN/SPIN button in for seconds, and released the same way. If someone leans against the button this can also occur. Hopefully this will be an easy fix for you. I hope this helps.
Jul 24, 2008 | Kenmore Elite 45986 Front Load Washer
Press and hold 'dry' & 'spin', shd unlock OR
Try holding the "end of cycle" button down for 5 or 6 seconds. You must hv done it accidently, it is the child lock device. Pl. rate if helped.
Dec 29, 2007 | Kenmore Elite 45986 Front Load Washer
I had the same problem. If you will hold the "Drain & Spin button" in for approximately 4 to 5 seconds it unlocks the " Control Locked" issue.
Dec 18, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
859 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
