Question about Hayward EC-40 DE Pool Filter with pump
Jet Pump stops after three starts of 20 minutes each and it doesnt want to start back again until the next day or after a few hours
    Problem Solver:
  • 11 Answers
Check motor with hand after it stops for excessive heat. Thermo coupler shuts motor off if overheating, to protect windings. Bad motor bearing can cause overheating, if so should hear bearing noise when running.
Also check start capacitor, by removing and checking with ohm meter, or plug in oposite terminals of capacitor to charge. Place rubber glove on hand, and contact two oposite terminals with screwdriver should produce a small spark.
Posted on Feb 17, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
Why does the Hayward EC-40 looses pressure within a half to hour?
Posted on Jun 25, 2009
  • Julia DiCristina Jun 25, 2009
    Please someone help me I have this problem every year at start up.
  • 547 Answers
Replace moter
Posted on Feb 12, 2009
Engine cranks for about 1 minute to start...once started it will start 1st time all day until a very long period has elapsed usually the next day.
It takes 20 minutes of driving to put back into your battery what charge it took to start the engine in the first place.
If you start the engine 3 times in a day then you would need an hour of driving to recharge the battery. Check your voltage on the battery the next day with a voltmeter, You need at least 12.6v.
Check for a battery trickle leak.You will have to remove each fuse in turn until you find the cause.
Cranking for a whole minute is unhealthy for the battery and there is obviously an underlying fault in the starting system. I would also check the fuel pressure at the port and get a cylinder pressure test
Nov 13, 2015 | Cars & Trucks
I have model 0155671 but it doesnt look like the model online mine has four buttons across set time plus minus next riw is rnd ctd bottom is manual i dont understand when it says select 12 or 24...
A) 12-24 hour choice >> just use the 24 hour display.
That gives you day and night hours
I don't know why these companies offer 12hr-24hr option on timers.
B) Military time vs Regular time (military time does not use am and pm)
1 1am
2 2am
7 7am
11 11am
12 12noon
13 1pm
14 2pm
20 8pm
23 11pm
24 12midnight
C) Utilitec 0155671 is same as Woods 59377
Before Woods made 59377, they made 49566 (which is also called TD1101 and TD1300)
I think you have Woods 49566
Manual for Woods 49566:
http://waterheatertimer.org/pdf/Woods-49556-TD1300.pdf
Add a comment at any time.
D) How to program timer.
Plug timer in until rechargeable battery is charged and display shows.
Unplug timer to program
1) Set current time.
Hold in reset button for two seconds to clear memory
Press and hold TIME button to select 24 hours so there is no problem. Release Time button.
Press and hold SET button.
MO is flashing, and represents MOnday. TU for TUesday. WE TH FI SA SU
Continue holding down SET button, and press ? ? until current day displays.
Release SET button.
Press and hold SET button again, and Hours will flash
Continue holding down SET button, and press ? ? until current hour displays.
Release SET button.
Press and hold SET button again, and Minutes will flash
Continue holding down SET button, and press ? ? until current minute displays.
Release SET button.
Press SET button again and current time and day will display.
2) Program review:
Set up to 20 on-off programs.
You can select individual days, or groups of days, or all days of the week
For example MO-SU is all days of the week
For each ON time, you also must set OFF time.
So program1 ON is set, then program1 OFF is set
Each ON is set for day, hour and minute
Each OFF is set for day, hour and minute (select same days for OFF and that you chose for ON)
For example if you want timer to turn ON all days MO-SU, make sure OFF time is also set for all days MO-SU.
3) Program the timer:
ON
Press arrow? until display shows PROG 1 ON
This is program1 ON.
Press SET button, but do not hold set button down as you did when setting current time.
The days for program1 ON will be flashing on display.
Press ? ? to select day, or groups of days that you want for program1 ON.
Press SET button again, and program1 ON hour will start flashing
Press ? ? to select hour that you want for program1 ON.
Press SET button again, and program1 ON minute will start flashing
Press ? ? to select minute that you want for program1 ON.
program1 ON is set, next you will set program1 OFF
OFF
Press arrow? until display shows PROG 1 OFF
This is program1 OFF.
The days for program1 OFF will be flashing on display.
Press ? ? to select day, or groups of days that you want for program1 OFF.
Press SET button again, and program1 OFF hour will start flashing
Press ? ? to select hour that you want for program1 OFF.
Press SET button again, and program1 OFF minute will start flashing
Press ? ? to select minute that you want for program1 OFF.
program1 ON and OFF are set, next you will set program2 ON by repeating steps above.
If you do not want to set more programs, that is fine.
Timer lets you set up to 20 programs.
Finish programming: when program ON-OFFs are set, press TIME button and current time displays.
4) Last step:
Push manual override button until AUTO is displayed. This will let timer turn lights on and off.
Plug lamp into timer.
Lamp must be turned ON.
Plug timer into wall.
Dec 05, 2010 | Hardware & Accessories
I bought the water resist watch from walmart this evening it doesnt have a name brand on the watch but i think its a casio but it didnt come with the instructions on how to use it, the number on the back...
Thank you for contacting FixYa.
  • There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
  • 2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
  • 3 Press the start button to change minutes.
  • 4 Press the reset button again to switch to hours. You will know it worked when the hour starts blinking instead of the minutes.
  • 5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
  • 6 Press the reset button to switch to the date, starting with the month, and press start to change it.
  • 7 Press reset one last time to switch from month to the day, and again press the start button to switch days.
  • 8 Press the mode button to finish the changes.
  • Sep 14, 2010 | Watches
    Okay my car started having problems starting it had a quarter gas tank and had never gave me any problems. Never has been over heated just had temp gauge replaced transmission flush and perfect inspection....
    try my favorite simple fix. Get some stp fuel treatment or whatever is common for your area, read the label and make sure it removes water from the gas tank/gas pour the entire bottle in then fill up the tank. let the car run for a few minutes drive it if possible. Your problem should clear up shortly.
    Jun 29, 2010 | 2004 Jeep Grand Cherokee
    My van keeps shutting down right after. The vehicle will start 20 times then with no warning it will start then shut off in two seconds then not start again until the next day. It doesn't happen every...
    there is 4 main things that could cause this.... 1. fuel pump heating up and stopping untill it cools off.... 2. the crank position sensor could heat up and not send the computer the propper signals and work once cooled off.... 3. coil pack same as the other 2 and 4. the main computer could be failing.
    the crank position is the least expensive
    the coil packs are a common issue out of those V6s
    the fuel pump can be checked by spraying starter fluid in the intake when the van doesnt want to start and see if that makes it start.
    the computer should be able to be diag. by the dealer but is very expensive and has to be a exact match software wise and year make model and package.
    Jun 12, 2010 | 1998 Dodge Grand Caravan
    6.5 tubbo diesel died and wont start back
    Sounds like the fuel pump got air in the system. You may have to bleed out the air. Then it will run. Check the fuel tank for fuel first.
    Nov 23, 2017 | 1998 GMC Sierra
    Flicker-Blinking on picture
    Too late now but I hope you had it serviced while it was still on parts warranty. With a couple of exceptions, service on those is by major pcb replacement.
    Jun 04, 2007 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
    How do I change time on timex watch?
    These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
    These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
    TIME AND DATE
    1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
    2. Press ADJUST to set SECONDS to zero.
    3. Press START/STOP to select MINUTES.
    4. Press ADJUST to change.
    5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
    6. Press MODE when done.
    7. To display DATE from Time display , press START/STOP.
    8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
    9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
    ALARM AND HOURLY CHIME
    1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
    2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
    4. Press ADJUST to change.. Press MODE when done.
    5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
    CHRONOGRAPH
    1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
    2. With time displayed, press MODE to select Chrono Mode.
    3. Press START/STOP to start.
    4. Press ADJUST to view lap time. Press again to sesume lap timing.
    5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
    6. Repeat for successive laps.
    Have fun! - Not a bad watch for the money! - - Silver Bullet
    Mar 16, 2007 | Timex 5B841 Wristwatch
    Hayward EC-40 DE Pool Filter  with pump Logo
    518 people viewed this question
    Top Hayward Pool & Spa Experts
    Jay Finke
    Jay Finke
    Bill Jordan
    john h
    Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
