I have a HP D4100 printer and it has stopped printing. The Green light is one but the error light is blinking. I have turned it off, replugged it, and restarted the computer but I can not get it to print. Thanks!
SOURCE: HP Photosmart C6180 won't print
HP C6180
won't make a Document copy...because it won't print in black ...will print in color any time from PC.
rebooted...won't print black in alignment or cleaning modes.
Any ideas?
Posted on Jul 14, 2008
geemarie
  • 876 Answers
SOURCE: hp 5550 printer problem
Did it eject the paper? The paper may have been crooked or became so in the printer. Check the Paper jam area first. If there is nothing there, Let's try a simple reset of your printer.
Go to Control panel>printers and faxes>click on your printer icon and under documents click cancel all documents.
Turn the printer off
Remove the paper from the tray
Unplug it from the power source
unplug it from the PC
Now open the paper jam door and gently push the paper roller forward until it clicks
Now do everything in reverse order until you get to turning the printer back on. give it a few minutes and see if it resets itself.
when you reload paper, besure that it is aligned carefully and the holders are pushed into place.
Let me know if this helps. Good Luck!
Posted on Aug 13, 2008
michael464
  • 8 Answers
SOURCE: Incompatible ink cartridge(s) ERROR on HP 4230 All-in-on printer
Try uninstalling and reinstalling the drivers. This can be done by going to the Add and Remove programs, this is located under the Control Panel. You may have to reboot and I would recommend that you do. This will clear out the Print Spooler. The Print Spooler is located under the C Drive and may get corrupted. You can find information about this in Google. Look for repairing spooler on the OS that you are using.
Posted on Dec 31, 2008
gwbm
  • 353 Answers
SOURCE: printer showing error
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and use it to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. This is quite straightforward once you know what to do.
If you decide to have a go at replacing the ink pads yourself, post a new comment, and I will provide further help.
Posted on Feb 27, 2009
JackHeath
  • 1049 Answers
SOURCE: Printer HP deskjet3940 light blinking green
Something is keeping the printer from printing. Either you have a jam, the print belt isn't moving, a dirty/bad sensor, or the logic board has failed. The first can be addressed pretty easily. Check everywhere. The second, you can check by looking at the small white pully on the right side behind the print head, that belt should be snug and the pully intact. (Have those break a lot for some reason.). The dirt might be able to fix by blowing around the sensor areas with a can of compressed air to blow away paper dust. But if the sensors or main logic board are bad there isn't much you can do.
Posted on Mar 09, 2010
Tip
The green light is blinking constantly and the printer won't print
When the green lamp constantly blinking this mean one or both print head are defective.Here we can find which cartridge is defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
This printer can work with only one cartridge.If you don't use color printing just remove the color cartridge.
on Oct 26, 2009 | HP Deskjet 3845 InkJet Printer
I have a ml-2165w laser black printer, when try to print it tells me me disconnect and press on button, the light turns green then blicks then turns red. What do I do>
Dear
There may be some error related to fuser or LSU.
Pl. down load samsung easy printer manager from samsung site or it can found on the disk provided.
run it it show the error detail.
Thanks
Oct 06, 2014 | Samsung ml-2165w - laser printer -...
Green and orange light is still stable and big green light is blinking
Hello
Hello, you name the error really is not on the list, the more like these and here is what it says to do. A greeting and let me know if you have been useful
Formatter internal RAM or ROM error Light pattern 3 LIGTHS ON, STABLE Formatter internal random-access memory (RAM) or read-only memory (ROM) error. Action
  1. Unplug the printer and plug it back in.
  2. Unplug the printer, remove any optional memory, and turn the printer back on.
General fatal error Light pattern 3 LIGTHS BLINK DescriptionGeneral fatal error. Action
  2. Disconnect the I/O cable and print a self-test page. If the self-test is successful, reconnect the I/O cable.
Light pattern: 2 little light stable and big light off
Motor malfuntion. contact hp
Apr 05, 2010 | HP LaserJet 1300 Printer
Canon IP3000 fault
Here are a couple of documents related to your problem (appears to be a print head error);
Error code synopsis;
www.decopac.com/resources/PDFs/iP3000%20Error%20Codes.pdf
Full product manual;
www.soft-manufaktura.ru/manual/hp/iP3000sm.pdf
Doesnt look terminal, at worst may need to replace the Print Head.
Hope this helps.
Dec 09, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Konica Minolta 2400W Magicolor. Error light blinking
Ready indicator Error indicator Condition Action
Green Orange
Blinking Blinking Communication Check The Printer
error cable
____________________________
Print over-run Turn off the printer.
After a few seconds
turn on the printer
change to a lower
resolution.
________________________________________________________
This may help if not...let me know........Whytfang
Mar 25, 2009 | Konica Minolta magicolor 2400 Laser...
HP 2550L printer
Theblack print cartridge is empty or missing. The black-print-cartridgelight is blinking, and then printer stops printing. An error 40208 iswritten to the event log. The printer cannot detect the print cartridgecorrectly. Action
  1. Reinsert or replace the print cartridge.
  2. If the print-cartridge light is still blinking but the Attention light is not on, turn the printer off, and then back on.
  3. If the problem continues, contact HP Customer Care at http://www.hp.com/support/clj2550 or see the flyer that came in the printer box for other contact information.
Mar 24, 2009 | HP LaserJet 2550L Printer
Red light
Logic Error in printer
Aug 12, 2008 | HP PhotoSmart 7660 InkJet Printer
Flashing green light prevents printing.
hi!!!!
try to pull out the cardtridge and put it back properly
sometime the cartrigde is place properly on the printer!!!
try to email me ronaldsuboc@gmail.com
Aug 08, 2008 | Canon S520 InkJet Photo Printer
300 people viewed this question
jasbo
jasbo
