Question about JVC XV-D723 DVD Player
JVC XV D723 Player.
Everytime I try to play a DVD, the machine stops midway through. Other times it won't play anything at all and says "No Disc" when I put a disc in.
5 Suggested Answers
SOURCE: jvc xv-s332 dvd player won't play
on the back is a seitch labelled ntsc/pal. flick it the other way might fix it
Posted on Mar 09, 2008
SOURCE: JVC XV-THA5R multi-region DVD player - fault recognising a disc in and playing
I too have this same problem on my current DVD player, AND strangely enough I had the same problem on my previous player.
Previous player was made multi region and was a Sony S660 (I think that was the model number).
My current DVD player is a Denon and was £550! It is also made multi region and has the same problems! I don't get it!
Posted on Apr 23, 2008
SOURCE: JVC XV-N322 DVD player
Dear friend,
It is a software problem.Reflash ur dvd player.
Posted on Mar 29, 2009
slipnoman
  • 53 Answers
SOURCE: I have a JVC XV-M555
you might have a burnt out lens, bring it to a repair shop to have it looked at
Posted on Aug 19, 2009
fieldy14
  • 456 Answers
SOURCE: ''Bad disc'' error when any disc loaded in JVC XV-N670B DVD Player
There may be a connection to the problem, but it sounds like the laser assembly may need to be replaced as well as/or the mpeg printed circuit board(the printed circuit board) attatched to the laser assy. Good Luck.
Posted on Sep 26, 2009
I have a JVC DVD Player (XV-N670B), (XV-N672S). I recently purchased a BluRay DVD and after inserting the DVD into the player, "Disc Error" appears. Would you tell me if my player can...
Sorry to say, no; this is a model limitation not a fault as such. XV-N670B is a DVD player, and the playable formats are:
DVD-Video, DVD-RW/-R, +RW/+R, CD, CD-R/RW, SVCD/VCD, WMA/MP3/JPEG, DivX. No Blu-ray support.
The JVC XV-BP11 and XV-BP1 do play Blu-Ray discs, as they are specifically Blu-Ray players (according to the JVC website).
I have heard of quite a few Blu-Ray players allowing DVD playback. The XV-BP1 supports the following playable media: BD-R/RE (Blu-Ray), DVD-Video/-R/-RW, R/ RW, CD, USB (again, this is from the same JVC website). You would need to purchase this or a similar Blu-Ray player to enjoy the benefits it has to offer (but it's up to you if you want one of those later on).
DVDs are still good, the 'disc error' message on your DVD player is normal due to the wrong media format inserted. The bonus here is it didn't cost you anything to ask, and you don't need a workshop quote on repairs.
This is the best free advice I can offer.
Mar 07, 2011 | JVC Televison & Video
Sep 26, 2009 | JVC XV-N320 DVD Player
Jvc dvd player no disc error
Hello!
I did have a similar problem. It was solved by cleaning the laser lenses/prisma. You have to dismantle the whole pick-up the to see the laser lenses.
There is one lens which is held by couple wires and below there is prisma/mirror.
I did use ear-cleaner-stick and desinfection liquid (with alcohol) for cleaning. Now it works!
Aug 16, 2009 | JVC XV-N312S DVD Player
JVC - XV-F80 DVD Player
Either the disc or the player likely need a good cleaning. Clean the disc with a soft cloth, clean the player with a good cleaner disc.
Feb 26, 2009 | JVC XV-F80 Multi-disc DVD Player
Does not play any disc
Thats bad..Did you try another disc? If this happens even with a different disc. You will need to get a lens cleaner(costs about 5$) and try cleaning the lens. If it still doesn't work then you will have to replace the lens. The reason why it died suddenly is probably because the lens circuitry somehow got shorted. Try cleaning and if not.. replace.
Nov 14, 2008 | JVC XV-N212S DVD Player
Disc starts to play and then locks up
All regions are not equal, and different DVD players can and will act differently when an improper DVD is loaded....accordianman
Aug 03, 2008 | JVC XV-N320 DVD Player
Dear friend,
May 16, 2008 | JVC XV-N320 DVD Player
Mar 08, 2008 | Televison & Video
Jvc xv-s332 dvd player won't play
Jan 25, 2008 | JVC XV-N322
JVC XV-D723 DVD Player Logo
18 people viewed this question
Top JVC Televison & Video Experts
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
