Question about Whirlpool LER5636P Electric Dryer
Dryer not heating every cycle
It's taking about 3 cycles to get the clothes dry. It's eaither not as hot or it's only heating every couple of cycles. I just want to make sure it's the heating element and not something else before I purchase a new one.
  • 833 Answers
A fellow once told me to do the simple things first.  Is the filter and the area where the filter goes in completely clear of lint?  Is the outlet discharging air in large or reduced amounts?  Make sure all is clean and flowing alot of air.  Oh, and check this before replacing other parts....turn both breakers off and then back on.  You may be running on 110 volts which will cause half of some heat elements from working at all or from working at full capacity.  If you've still got a problem and the clothes have been spun to mild dampness by your washer, you may need either a new element or new thermostat.
Posted on Nov 15, 2008
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Whirlpool dryer is not drying properly. Have to go through a couple of cycles to dry clothes.
2 things are needed to dry clothes. 1 is good air flow. Check to make sure that the dryer vent is not clogged or partially clogged with lint. Also make sure there are no kinks in the vent hose. With the dryer running you should feel good air flow blowing out of the outside house vent. The 2nd thing a dryer needs heat. Check to see that the dryer feels warm to hot when you reach in to tough the clothes. It is possible that the heat element has partially failed. Another thing to investigate is how well the laundry machine is spinning out the water in the spin cycle. This spin cycle is used to get as much water out as possible prior to placing the clothes in the dryer. The wetter the clothes when they come out of the laundry, the longer it takes to dry them.
Oct 01, 2010 | Whirlpool Dryers
Clothes not dryin
clean out the exhaust vent tubes thoroughly. the moister sensor will shut down the high heat if clogged full of lint
Jun 06, 2010 | Estate EED4100SQ Electric Dryer
Bosch axxis wtl 5410 dryer takes too long to dry.
You should have a cycling thermostat. this is most likely bad or your dryer vent may be clogged. Something is cutting the heat off before it gets hot enough. Both these cause this problem.
Nov 17, 2009 | Bosch Axxis WTL 5410 Electric Dryer
My GE dryer takes 3-4 times as long as I expect it to to dry my clothes. I've read that it should take about 45 minutes to dry a load but after the first cycle the clothes are still damp. It usually takes...
You have checked a lot already ... thanks for the comlete story. Often the questions here hurt for detail.
Are your clothes getting hot?
Two reasons for not getting dry ...
No heat
No air.
You need warm air (heat and air) going through your drier to achieve dryness.
Sounds like you have no heat. Are you properly setup on the control panel (you selected heat)? You have physically inspected the entire exhaust sustem including the outside vent, hose and lint trap - absolutely clear ...
check the heat my friend
Oct 20, 2009 | Dryers
My dryer takes 2 to 3 cycles to dry my clothes.
Check the following areas to combat this issue. in most cases, this will be a Venting issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
Not heating properly, many cycles to dry loads
Check the following to address this issue--
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
2. Thermostat
3. Heating element
Jun 02, 2009 | Maytag SDG3606A Gas Dryer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer heats up but clothes won't dry
Sounds like to me, that you need to check the vent going outside from the dryer. I had the same problem, and found a birds nest in the dryer vent on the outside of my house restricing air flow. If that doesn't fix the problem, look into a new heating element and or thermostats for the dryers. The old ones could just not be getting hot enough anymore. Good luck.
Apr 08, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
57 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
