Question about Canon PIXMA iP4300 InkJet Photo Printer
Ip4300 is printing everything orange!
Every time i want to print an image that is high resilution, with any programe my printer covers the image with a wonderful tint of orange. all the carterages are clean allingned and full. i don't understand it at all. Please help me its so fustrating.
  • 4 Answers
It sounds like a driver problem, maybe caused by installing some new software that interferes with your printer settings.
Try downloading the latest drivers and software from the Canon website.
Before you install them, un-install all of your printer software then shut down your computer, even if the un-install program doesn't tell you to.
Switch off your printer, then unplug the usb cable from the printer (not the pc).
When the computer restarts, install the new software and drivers exactly the same way as in the original instructions that came with the printer.
Only turn the printer on and plug the usb cable in when the instructions tell you to.
If this doesn't work, the printer may be faulty. If you contact the dealer you bought it from, they may have a warranty running with Canon that lasts more than the guarantee period. It's worth a try, though you may have to pay for a courier to pick up and bring back your printer.
Posted on Nov 18, 2008
The orange light on pixma iP4300 is flashing 5 times. I have cleaned the printhead (gold contacts) with alcohol PJ
Use cotton swabs dipped in hot water or a mixture of hot water and isopropyl alcohol
Use it to clean the print head and the electronic contacts on each ink cartridge
Once done, allow to dry and try again
If the error still persists, you have a damaged print head which needs to be replaced with a new one
Hope this help!
Sep 06, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Orange light flashes 5 times continuously on canon pixma ip4300
Orange light flashes if there is any issue with the printer. Please check all the hardware is functioning properly. Check if there is any paper jam. If printer cartridge is installed properly. Printing head is ok.
Dec 09, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
I need a driver for ip4300 that will help me print on cd
Hey!Go to www.canon.co.za,at the bottom right it says download software,Click on that!Select printers and select the ip4300,Select your windows and your language and download the cd label print program!!Enjoy!!
Nov 05, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Cannon Ip4300 - Orange light flashes on printer.
A possible paper jam has happen on the unit. Did you have an paper jam error before you have this problem?
You must clear any paper jam on the unit, check the unit for any stuck paper or object or check if there was misaligned parts inside.
Let me know for any clarifications.
Thank you for using fixya.
micro-
Dec 12, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
I have ms xl & canon ip4300. I would like to
You need to go to canon.com and download the printing software there. That software has the options to print the way you describe.
Nov 05, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
"Paper Output Slot Jammed" Canon Pixma iP4300
These printers are FULL of very sensitive sensors, and chances are that one of them may have a small piece of paper blocking them. If you can get the covers off by finding the "Triangle" arrow markers, you can inspect all these sensors.
Good luck!!!
Mar 12, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
IP4300 printer problem
the driver of the pixma is set to A5 size. open it (you will find it in configuration panel/printers/) and set back to A4 size
Feb 06, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
CANON ip 4300 - 5100 error & prints skew onto DVD
I had this eror. It was caused by indexing error left to right.Would print some then cancel after starting to make clunking and left to right error gets to large.(white edge up the side of full page print).
There is a toothed print head carriage drive belt and a clear indexing strip above the heavily white greased bar behind print head carriage.
If this clear indexing strip gets grease or anything else on it the print head cannot index.
With print head at full right position,power off, I carefully wiped the clear strip by pinching between clean dry fingers and wiping up and down the strip a few times,maybe use cotton wool buds and IPA or methalated spirit if you can't get your fingers in there without breaking the strip. then with power on print head in change cartridge position,push carriage to far left and wipe right side of clear strip.I pushed carriage full left to right a few times,Then ran print head alignment.Fixed without taking apart.
Jun 23, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
CD printing
there is a small,square button near the right,front corner. think of it as the button for the refrigerator light. It must be depressed by the closed top or maybe something to wedge it down. Duh
Oct 30, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Prints image too small
Your actual computer print settings may need re-setting if this makes sense, check your pc's print settings, not just the printers own settings. Yoou can get help with this by going to control panel, printers and faxes, troubleshooting, help and supposrt, and follow links. Did you try specifying the paper type to your printer in properties or settings or selecting fit to page which can override printer default settings. It may be that your printer has a glitch like spyware too, try unplugging all cords, replug and turn on. This will rest it. Sometimes this does the job, and run antispyware etc just to be sure. Some programs have their own "printer" guide, go to printers annd faxes settings to see if you need to select a program specific printer setting.
Aug 01, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Canon PIXMA  iP4300 InkJet Photo Printer Logo
57 people viewed this question
old marine
old marine
