Computer won't boot, won't even get to the login area, it says no signal input and to check video cable, post codes it is showing is 49, 50 & 52, 65, 75
  • Michelle
    Michelle Nov 16, 2008
    I tried that but it won't let me go to anywhere where I can change the resolution and it still says no signal input and check video cable. Thanks for your help though.
    Genius:
  • 1,913 Answers
When upower up press F8 key then go to enble vga mode then set resolution in dispaly properties.1024*768.
Posted on Nov 15, 2008
  • kishor khatri
    kishor khatri Nov 16, 2008
    ok enter in enable vga mode and i assume u enterd .then go to run enter "control" then press ok
    then u find display.open it.
    then settings.
    then in left u see display resolution set it with 1024*768.
    If u need any help then email me
    :kish.khatri@yahoo.co.in
TH-50PX77U inputs
Many times a computer's post screens will not show up a TV set, and once the computer itself has loaded the drivers and settings, the set may need to be shut off and turned back on for the HDNI or PC signal to be detected.
It is also possible the settings you selected for display properties cannot be displayed on the TV.
As far as the component video signal, are the connections correct? Sometimes people mistake the composite red, white and yellow for the composite system that divides the red, blue and green video signals.
While also possible, but rare- there may be poorly soldered connections on the "A&D" board (logic board) .
Jul 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
Acer x193w Monitor won't come on flashes blue light you see word "Acer" it goes to flashing Yellow light and keeps repeating that.
you disconnect the monitor from PC
& see: it will show no signal or check signal cable. that means the monitor is OK problem is in PC. may be you PC is not booting properly. if monitor does not come on there may be fault in the main board of your monitor.
Oct 13, 2011 | Acer X193W LCD Monitor
The Hannspree monitor shows start-up along with my computer monitor,but once it gets on desktop, the Hannspree monitor says "no signal input check video cable", but all the cables are connected...
If you have more than one monitor connection it may be outputting the signal to the other connector.
Try booting into safe mode ( tap F8 key untill the menu shows, use the arrow key and enter to select)
if all goes well restart the computer and monitor should work.
Aug 29, 2011 | Hannspree Computers & Internet
NC10 display seems to switch in to a test signal mode when it is booting, it shows different test screens/signals, cycling through every four seconds: red, green, blue, white, multicolour (like tv test...
MAYBE it's your Video Drivers trying to 'talk' to your NC10?
IF they installed incorrectly your NC10 can get lost trying to satisfy and decode your video?
CAN YOU boot into the 'safe mode'? (Link below)
Is your booting complete ~ even though it's poor resolution?
IF SO... delete your current drivers (totally) and reboot! Install the correct drivers...
Anthony
http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?idx=651610&modelname=NP-NC10+%3Fiframe%3Dtrue&modelcode=&session_id=Qlp88jSjpSG5KyyD42BX3Ww4qhmyW0T8pDGmqCqZhsKSJrrqJBTf!-12030426!-799142688!1348839932800&from_osc=&homeid=44969
Dec 11, 2017 | Samsung NC10-14ROBL Notebook
My HP Pavilion a6642p PC has a monitor but the monitior says no signal input
If it says no signal input, then your computer is not putting out a signal. Possibly a bad video card. Also can be a computer that never really boots up and passes the POST. Unless the POST completes, it won't send a video signal.
May 12, 2011 | Computers & Internet
Wenn I connect the coax cable the display show --------, and the Receiver can't detect the digital audio signal, even though I can mesure a PCM signal with the Osilloscope.
http://www.retrevo.com/support/Sony-STR-DH510-Receivers-manual/id/23637ci375/t/2/
Page 71
There is no sound from digital sources (from COAXIAL or OPTICAL input jack). • Check that the INPUT MODE is not set to "ANALOG" (page 52). • Check that the Analog Direct is not being used. • Check that the "A. ASSIGN" function is not used to reassign the audio input of another source to the selected input (page 53). • Set "ARC" to "ARC OFF" when no sound is output from TV OPTICAL IN jack during TV input (page 58).
Feb 07, 2011 | Sony STRDH510
I using windows XP, and the when it gets to the windows login screen (where I choose which name to start windows in), the monitor suddenly cuts out with the message, "no signal input." The weird part is...
It could be one of several things such as:
Loose cable, or bent pins on cable.
Loose video card.
burnt out power for the video card chip on mainboard (smells bad).
Video card is dead.
Remove the monitor cable from the Video card (back of PC),Open your PC case, earth yourself by touching the casing then see if the video card is loose, if so push it in. If not take it out anyway and put it in again, blowing the dust away (or even better use a vacuum cleaner to vacuum all the dirt out of your PC). Make sure it sits correctly.
Put the cable back on making sure it fits tight and that no pins are bent, and turn it on.
If this doesn´t work then try a different video card, even an old one. IF this works your video card is faulty.
Jan 30, 2010 | Computers & Internet
WhenI turn my monitor on, a screen appears saying VGA input - no signal & DVI input - no siganl & then it goes to sleep
Do you have multiple Video cards installed in your computer?
Check the monitor on another computer to verify the Monitor works and so does the cable.
If Monitor works, cable works, and you have 1 video output from your computer, then your Video card is probably no good.
Jan 26, 2010 | Compaq fs740 17" CRT Monitor
Picture Stutters on HD Channels
Hi my name is Roety,
I can help you with your issue ,
 Sounds like a bad signal issue , check it on other inputs to confirm
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Oct 20, 2009 | Vizio GV52LF 52 in. LCD TV
Does not pick up cable satellite signal
Do you have the satelite hooked threu the regular cable input? If so hook it thru one of the video inputs instead; composite video or component video. the picture and sound will be better and you will be by-passing the problem area of your Tv ( the tuner).
Apr 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Computers & Internet Logo
142 people viewed this question
David Payne
David Payne
