IBOOK G4 I have 2 ibook g4 that I am trying to install OS X 10.4. The first disc installs fine but disc 2 stops at installing media files at 23% then says please try installing again. At the top it says there were errors installing the software. I tried using disk utility and eliminate the fonts, languages etc. Please help!!!
  • 33 Answers
Have you looked at disk #2 to make sure no scratches or sticky fingerprints?? Usually when you get an error on 2nd media its issues with this and or when you boot to fist disk goto utilities and check the hard dirve to see if its not failing at a point also make sure your doing a full restore and not archieve install
Posted on Nov 16, 2008
Apple logo and loading symbol
If you have another MAC computer available, you can create a USB key to solve this problem:
http://www.techrepublic.com/blog/apple-in-the-enterprise/how-to-create-a-bootable-usb-to-install-os-x/
If not, I'm afraid you will have to turn to an authorized apple service center. They will do the repair for you.
Jul 19, 2013 | Apple iBook Laptop G4 iBook 1.33GHz...
I have replaced my harddisk in ibook G4...how to install mac os
The problem appears to be that your ibook is only a G4 processor snow leopard needs an intel processor. The highest system you can instal on it is 10.5 i.e. leopard.
Jun 25, 2012 | Apple iBook 12 iBook G4 1.33GHz,...
I want to know master password, Because I forgot password of ibook G4.
Unfortunately, the only way to recover your password is to make a new one. To do this you will need to re-install your operating system by inserting the OS disc that came with your computer. If you have lost this then you will need to purchase an OS disc. Snow Leopard can be purchased for $40 here from Amazon.com. Hope this helped!
Aug 04, 2011 | Apple iBook G4 Mac Notebook
I recently got a ibook g4 from someone that said the os kept freezing at the startup. I tried reinstalling from the install disk that came with it. It get to the end of the first disk then says there was...
Your hard drive is failing or has some bad sectors.You can get HDD Regenerator software and run it and it most of the time will regenerate the bad sectors causing problems such as yours.If that doesn't work then your hard drive is failing.Also the install disc may be corrupt/scratched causing the error as well.The OS freezing at startup also indicates the hard drive is bad.
Jan 26, 2011 | Apple iBook G4 (Z0AZW13397068) PC Notebook
I have an ibook G4. The display is hard to read and the graphics are terrible. I've tried adjusting the resolution and display with no improvement. It's hard to read. Help please!
Try reseting the PMU and Pram,also check the d.Also check the system with saperate OS installed HDd.It will work fine.Format the HDD and the issue gets solved
Apr 07, 2010 | Apple iBook G4 Mac Notebook
I cant get my ibook g4 to run it turns on with blinking folder
Blinking ? mark folder means that your OS can't be found. Take out your RAM underneath the keyboard and re-insert and try again. Nothing? Install a different new RAM chip and try again. Nothing? Install your disc 1 install disc, power down, wait a few seconds, now press the power button to turn on, now press and hold the option button, until your disc 1 shows up, select it, and bring your pointer to the right arrow on the screen and press enter. Now your booting from the disc 1. Go to disc utility folder at the top of the screen and select your hard drive and then select repair disc permissions. Then shut down and reboot when finished. Nothing? Your hard drive is fu.k.d-Try re-installing the OS. Nothing? Your hard drive is really fu.k.d-You need a new hard drive. Installing a new hard drive in the iBook is a *****. You may want to pay someone to install a hard drive or you can just get a new laptop.
Mar 09, 2010 | Apple iBook G4 Mac Notebook
I picked up a Powerbook G4 12' Aluminum guesing 1.5 from a local college that was going to trash it, and when I press the power button the start up chime rings and turns straight to a blinking ?/Mac OS...
Get the gray OS discs specific for the PowerBook. Your iBook gray discs won't work. You can also install the OS by getting a black label retail version disc of whatever cat you like- Panther or Tiger. If the software installs, but you hear noises or get the spinning beach ball of death, then the hard drive is fu.k.d up. You then have to open up the computer and install a new hard drive and re-install the OS. Good luck old chap. Cheers.
Dec 31, 2009 | Office Equipment & Supplies
On start-up, (from HD or CD) I get the Apple, then "unable to fin
This is the message you see when a version of OS X has been installed on a Mac that needs a later version of OS X at minimum, or when the custom gray install disc for one model of Mac has been used to initialize another model of Mac.
You posted this under "iBook G4," and the platform in the error messages says "PowerBook." Provided you posted in the right place, that confirms the above diagnosis.
Initialize your iBook with the proper gray disc, or a retail OS X installation disc, and it will operate properly.
Nov 13, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
IBOOK G4
You may have a RAM problem.One of the most serious problems that can afflict your Mac is "bad memory" -- the common term for a defective RAM chip.
Apple provides Apple Hardware Test with every new Mac -- it's either on the Mac OS X Install/Restore disc, or on a separate Hardware Test disc.
Here are the instruction on how to run the Apple Hardware Test CD:
http://support.apple.com/kb/TA25668?viewlocale=en_US
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 16, 2008 | Computers & Internet
Apple 12" ibook g4/1.33ghz won't turn on
your hard drive has failed
it needs to be replaced(2.5" ide) on ebay they are pretty cheap
anything else i could help you with?
Jul 22, 2008 | Apple iBook G4 Mac Notebook
Computers & Internet Logo
692 people viewed this question
David Payne
David Payne
