Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Memory card is locked slide write position - Nikon D40 Digital Camera with G-II 18-55mm Lens
Hey, itsactually not your camera at all.Take your memory card,there should be a little white thing on the side of it,just push it the other way and wola!!! fixed! simple as that ...hope i helped you. vanessa
Posted on Nov 20, 2008
  • logila2001
    logila2001 Sep 22, 2012
    Gracias. Thanks. It worked for me just right. I solved my problem with my Nikon D5100 and a ScanDisk memory card of 32 GB. God bless you.
SOURCE: Nikon D60 memory card problem. When i turn my
check your sd card, there's a tiny bar on the side that you can "slide" to unlock...
Posted on Aug 24, 2009
SOURCE: cant take photos and the LCD screen says "Memory card is locked. Slide lock to 'write' position"
I don't own this camera but My guess is your memory card is in a LOCK SETTING you need to move the memory card to unlocked " wrirte " so you memory card isn't locked.....
Step 1 remove the card from you're camera
Step 2 there is a small little side on the side of the memory chip move that to the unlock position.
step 3 insert the card and start shooting!
Posted on May 06, 2009
  • 9 Answers
SOURCE: Camera is saying "Memory card is locked. Slide lock to "write" position."
If you remove the card from the camera, there is a little switch on the SD Card. There is typically a label that shows which direction is locked. If not, switch it to the opposite side. This should solve the problem. Otherwise, there could be a problem with your card. I hope this solves the problem.
Posted on May 17, 2009
SGNath
  • 170 Answers
SOURCE: nikon d40 memory card is
First take out the SD Memory card. If the tiny switch on the card (Top right) is in Lock position (marked on the card), slide it up to unlock position.
Posted on Aug 30, 2010
einstein1
  • 194 Answers
SOURCE: memory card is locked
TAKE YOUR MEMORY CARD OUTSIDE THE CAMERA. AND IN THE MEMORY CARD IN RIGHT SIDE A SMALL WHITE SWITCH WILL BE THERE PUSH IT TO DOWN POSITION.
Posted on Mar 25, 2011
Problem nikon d40 memory card is locked. slide lock to write position
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 07, 2014 | Nikon D60 Digital Camera
Camera saying memory card locked slide lock write psition
The Nikon N75 is a film camera. It doesn't use a memory card at all.
If you're referring to some other digital camera that does use an SD/SDHC card, look at the memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 21, 2013 | Nikon Photography
What type of memory card?
Memory Sticks have a slide switch on the back. One position is marked "LOCK" while the unmarked position unlocks the card.
Mar 29, 2013 | Samsung H Computers & Internet
How do you unlock a Locked sandisc
That depends on the type of the SanDisk product.
Memory Sticks have a switch along one side. One position is marked "LOCK", the other position unlocks the card.
MicroSD adapters have a slide switch, just like SD cards.
Mar 23, 2013 | SanDisk 2GB microSD Memory Card
My nikon memory card is locked how to unlock it ?
Apr 21, 2012 | Nikon D5100 Digital Camera with 1855mm...
Says the memory card is protected, reset switch on memory card. Could someone ...
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Feb 28, 2011 | Kodak EasyShare C613 Digital Camera
Nikon d40 memory card is locked. slide lock to write position. pl give me solution quickly my no:8012314307
Aug 30, 2010 | Cameras
Memory card locked
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
May 08, 2010 | Canon PowerShot A450 Digital Camera
Cant take photos and the LCD screen says "Memory card is locked. Slide lock to 'write' position"
Apr 16, 2009 | Nikon D90 Digital Camera with 18-105mm...
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
4,798 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
