Question about Toshiba e-Studio 350 Copier
Problems with Toshiba copier
Hi. I have a Toshiba studio 150 copier. Shows in the panel 4H. I read that you said is the fuser. But the problem is that I dont know how to put the keys-clear and density. Is just put the bottoms and that so. Please help me.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
Just press these keys with sequence and with in 2 or 3 seconds .first press clear,then auto photo mode select key,again clear ,auto photo key,.copier will go dead .now press 14 then start key.problem will bi removed.
clear key,auto photo key,clear,auto photo key,
when display dead 14 start key.
BY MIAN JEE
Posted on Dec 18, 2008
Toshiba E-studio 230 Copier shows this message call for service 631012
Well, first of all Francis, that isn't your error code, that's your meter (the odometer of the copier so to speak). Error codes will show C--- or E---
examples are C447 (fuser error) or E010 (fuser related jam)
Jan 10, 2013 | Toshiba E-studio 230 Copier W/net Print,...
Hello, I turn on my Toshiba E-Studio 166 Photocopy Machine and it shows an Error Code C 41, please how can I fix this problem?
Poor contact of the fuser drawer connector may cause the following
error codes: C41~C46, C4A, CD5, E01, E03. To correct this issue, a
spacer (see SPL p25 item 1 attached) has been added between the
fuser connector and the frame; also the springs (see SPL p24 item 8
attached) have been changed to provide more tension.
This change has been applied since January 2003 production:
e-Studio 550 TA314824
e-Studio 650 WA312627
e-Studio 810 XA311627
Model P-I Before Change After Change
e-ST550 25-1 --- 6LA14365000
e-ST650 SPACER-DRW-CNCT
e-ST810 24-8 6LA08946000 6LA14468000
SPC067-070-140 SPC068-080-160
Jan 26, 2011 | Toshiba e-Studio163 Copier
I have a Toshiba e-studio 150 copier. L-1 error code flashing
hi there is problem L-1 means that u have problem CCD MCU Harness Disconnect
May 12, 2010 | Toshiba E-Studio 161 Copier
Toshiba studio 4511 problem
This could quite literally mean anything from a new drum to fuser unit to power supply etc.
Sep 21, 2009 | Toshiba e-Studio 282 Printer
Toshiba e-studio 150, Problem H4
This is a fuser related error - the fuser is not warming up within a specified time frame. It could be the heater lamp or a thermostat/thermistor that is not working, possibly a bad fan. You can cancel the error code (hopefully the error does not come back) by going into sim mode. press the following keys one after the other "clear" "density select key" "clear" "density select key" then enter 14 and the copy start key. then restart the copier. If error code persists you could remove the fuser unit and look for any foreign matter inside the fuser. dirty thermistor or thermostat can cause this too.
Hope this helps
Apr 05, 2009 | Toshiba E-Studio 161 Copier
Toshiba estudio 350 the error code is wait warming how can i fix this
If wait warming is occur on the panel, and it wouldn't change to ready, then fuser unit is the cause. Need to check the themistor and themostat on fuser unit.
Dec 29, 2008 | Toshiba e-Studio 350 Copier
Hi tohisba e studio 150
This is a fuser error.
First you must enter the simulation mode as follows:
press the keys clear, density select, clear, density select
then press the copy key
use the arrow up and down buttons to select the number 14 in the display
press the copy key
this should fix the problem
c
Aug 06, 2008 | Toshiba e-Studio150 Copier
Error code L
L signal is scaner lock
please chack your copier left side copy board under lock unlock mark
Thanks
Tareq
Mar 05, 2008 | Toshiba e-STUDIO 150 All-In-One Laser...
Hi you have a fuser problem. The fuser does not heatup normaly. Sometimes it can besolved with the following code. Enter Sim mode. "c" - Auto/text/photo - "c" - Auto/text/photo - 14 -start - 00 - start. To exit sim mode press clear all. Turn the machine off and on, check operation. If that does not work check the Termosters, termostats, and heater lamps and wiring harnes.
Hope it helps
Feb 19, 2008 | Toshiba e-Studio120 Copier
Toshiba e-Studio 350 Copier Logo
101 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
