Touchpad cant use
Touch pad error
  • 3 more comments
  • Pat Hansford Nov 16, 2008
    My Dell Inspiron 8100 has this problem from time to time. Sometimes I can correct it by doing a hard reset (take out the battery and unplug power cord.) Also, sometimes I can go to Device Manager, uninstall the PS 2
    mouse and restart the computer. Crazy! It will last for a while then it is gone again. I have a USB touchpad that I can plug in when the touchpad is not working (Most of the time.) Unlike most, I prefer the built-in touchpad. Wish I could find a replacement.
    ladyandbill@verizon.net
  • pawelchabiel Nov 27, 2008
    When I touch the pad there is no answer on the screen. The computer cursor does't move. There is no problem with moving the cursor by mouse.
  • Anonymous Jan 05, 2009
    I can use the touchpad by using the cursor but it does not function the double click tap ,what can be the problem
  • speshstud Mar 18, 2009
    My touchpad isn't responding. It says the mouse is working properly under control panel-mouse, and my USB mouse works. However, I prefer the built-in touchpad. I tried Fn + F7 and Windows + F7. The "Turn Caret Browsing ON/OFF" popped up, but the touchpad still doesn't work. I was told there may be a hotkey, but I can't find anything else about it. Please help.
  • Anonymous May 12, 2009
    Touch pad on laptop not responding
  • 4,806 Answers
Hold Fn key and press F7, if that does not work hold windows key and press F7, if that does not work plug in a usb keyboard
Posted on Nov 16, 2008
The sz series is notrious for having a crappy touchpad - I struggled with mine for years - setn *** back to Sony siad that I needed a new motherboard. Yeah, right... to fix the touch pad.
Well I saced the $699 - and did the black tape fix, and smooth sailing since.
http://doube.org/sztp.html
I am hitting all the forums Sony, so hope you read this.  This is the only recourse I have for you having tried to jack me for 700 dollars.
Posted on Apr 24, 2009
3 Suggested Answers
  • 54 Answers
SOURCE: touch pad scrolling problem
Use alps one as well as check weather your touch pad is lock or not
Posted on Mar 14, 2009
SOURCE: key board and touch pad do not work
Did it shut off on the keypad? Sometimes things are being so frustrating that we forget that the keypad has a shutoff that can get bumped. Make sure it's on.
Posted on Mar 31, 2009
Gateway touchpad
Check the settings for the touch pad. Check device manager for errors with the touch pad. Reinstall the drivers for the touch pad.
Aug 16, 2014 | Gateway NV76R24u Core i5-3210M Dual-Core...
Alienware m14x touchpad problem
try to re-installing the touch pad drivers and check if you have by mistake turn off the touch pad
if it don't work call customer support
Jul 02, 2013 | Computers & Internet
The touchpad above my keyboard is no longer responding as I think i may have deleted something from the hard drive. how do i fix this? When I first recieved the computer the majority of the touch...
sure you deleted something, how else can a driver just go byebye.
NO OS stated is this XP
we cant guess what OS is there ever.
so does mouse work, usb plugged in , that be first.
after checking device manager, for touch pad , driver errors
then know a pad this old can be bad.
it can also be set wrong in control panel, click mouse
and set it as you like.
Feb 18, 2018 | HP Pavilion DV9720US Notebook
CURSOR JUMPS OUT OF PLACE ,
Go to the touchpad properties, touchpad settings, Enable TouchCheck, set the slider to the far left (1/2 Second Delay) this will disable the touch pad while typing and enable it 1/2 second after you stop typing
Jun 01, 2010 | Dell Vostro 2510 Laptop
Asus touch pad too sensitive
There should be settings in the touch pad software on your machine or in the task bar that you can directly access to change all manner of personal idiosyncrasies related to HID. (Human interface device) Try also going into the control panel and looking for input devices, mouse, touchpad and adjusting the settings from within there.
Mar 11, 2010 | ASUS Computers & Internet
I lost my manual and I am getting an F22 display. What does this mean?
CCU/Touchpad/LED assembly error(F-22)*
Hi.This error occurs if the touchpad/DED assembly is not able to transmit/receive data to/from the central control unit (CCU)
Check the following:::
A.Check the touch-pad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touch-pad/LED is responding. If the results are negative, move on to the next step.
B.Unplug washer or disconnect power.(Make sure you unplug the unit for 5 minutes, thsi will reset the panel, and restore proper functions if the damage inst severe)
C.Check Wire Harness connectors to the touch-pad/LED assembly and Central Control Unit (CCU)
***((Ok, if all fails to revive proper functions above, this will confirm a major issue that concerns the wiring harness that is used to link the touch pad to the CCU))
Sep 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Can't disable touch pad
Windows hides rarely used icons. If your does, then the task bar shows a left pointing arrow < . Click it and look for the icone for touchpad.
If you cant find that icon,
In WINDOWS XP
1. Start
2. Contol Panel
3. Right click the Mouse icon.
4. Under the Touchpad ON/OFF thumbnail, put a check mark in the disable option.
5. Use the same procedure to enable touchpad
Aug 22, 2009 | Dell F3534 Touchpad
Error code F7
your problem is with the EOC (Electronic oven control) or touch pad if it is seperate from the control...if the touch pad is seperate...unplug range - access the control panel - remove the wiring/tape wire from touchpad to EOC...plug range back in...leave over night...if f7 code comes back it's the EOC...if the error code clears it's the touchpad...replace the part with the problem...if touchpad built into EOC replace the EOC. Hope this helps...if you have any other questions please feel free to comment again.
Jul 06, 2009 | GE Ovens
Mouse touch pad problem Lenovo Y410 model notebook
Just above my keyboard there is a little black strip with little lights.
they are control buttons and if you tap one of them it turns the touchpad off and on (so it's very easy to do accidentally).
 If you look really closely at the strip in good light (or restart the laptop to see them flash on and off) you'll see that one looks like a touchpad crossed out. Just press this to get your touchpad back.
If it doesnt solve the problem, I have noticed that the touchpad can be knocked out by a Window Update of something called ideacom. If you believe this could be the problem please clarify.
Jan 28, 2009 | Lenovo 3000 Y410 Laptop
Istalling mouseb has turned off touch pad ?
This usually happens so you dont have 2 mice running at once. Unplug the new mouse and your touchpad should come back.
Mar 12, 2008 | Recoton Advent Advent Q2035A 20" TV
Computers & Internet Logo
3,264 people viewed this question
David Payne
David Payne
